MIKROE-260
MIKROE-260
    MIKRO
    BOARDEASYTEST
MIKROE-260 数据手册
EasyTEST Board This board helps you to double the number of pins of single IDC10 PORT header, which allows you to monitor signals using oscilloscope probes while the PORT is in operation. Board is also useful when you need to connect two boards to the same PORT at once. Technical Specifications Applications Operating Voltage The EasyTEST Board is an ideal solution for connecting your prototype or development board to oscilloscope or other monitoring devices. Board can be used with both 5V and 3.3V systems. Key Benefits Key features Board features one female and two male IDC10 connectors, connected in Female IDC10 connector is compatible with mikroE development boards Board is clearly marked, which makes it easier to connect with external electronics Flexible solution suitable for all MCU architectures parallel. MIKROE-260 EasyTEST Board http://www.mikroe.com/add-on-boards/various/easytest/ 1/26/2016
MIKROE-260 价格&库存
很抱歉,暂时无法提供与“MIKROE-260”相匹配的价格&库存,您可以联系我们找货
MIKROE-260
  • 1+61.075581+7.38572
库存:1
