1300 Henley Court
Pullman, WA 99163
509.334.6306
www.digilentinc.com
PmodCON3™ Reference Manual
Revised April 15, 2016
This manual applies to the PmodCON3 rev. C
Overview
The Digilent PmodCON3 (Revision C) can be used to easily interface with up to four small servo motors that deliver
anywhere from 50 to 300 ounce/inches of torque, such as those used in radio controlled airplanes or cars, as well
as some mechatronics projects.
Features include:
Four standard 3-wire servo motor
connectors
Easily interface with Digilent system boards
Flexible power delivery to servos
Small PCB size for flexible designs 1.0 in ×
0.8 in (2.5 cm × 2.0 cm)
6-pin Pmod port with GPIO interface
Follows Digilent Pmod Interface
Specification Type 1
Example code available in resource center
The PmodCON3.
1
Functional Description
The PmodCON3 allows any Digilent system board to easily interface with a standard 3-wire servo motor consisting
of a signal, positive power supply, and ground power supply wires. The power supply can be sourced either from
the system board or an external power source via screw terminals by selecting the appropriate setting on the
jumper block.
2
Interfacing with the Pmod
The PmodCON3 communicates with the host board via one of the four GPIO pins (the first four pins on the 1×6
header). As mentioned in the Functional Description, it is also possible to select how to power an attached servo
motor by setting the shorting block in the appropriate jumper configuration.
DOC#: 502-082
Copyright Digilent, Inc. All rights reserved.
Other product and company names mentioned may be trademarks of their respective owners.
Page 1 of 2
Header J1
Pin
Number
1
Description
Servo P1
Jumper JP1
Jumper
Setting
VCC
2
Servo P2
VE
3
4
5
6
Servo P3
Servo P4
Ground
VCC
Description
The voltage source for the servos comes from VCC and Ground
The voltage source for the servos come from the + and - screw
terminals
Table 1. Connector J1- Pin Descriptions as labeled on the Pmod.
Standard servo motors use a potentiometer to adjust the angle at which their central shaft rotates to. In order to
adjust the rotation angle, the motor generally needs to receive a “high” voltage pulse that ranges from 1
millisecond to 2 milliseconds, with 1.5 milliseconds as the “neutral” value. These values typically correspond to 0
degrees, 180 degrees, and 90 degrees, respectively, although depending on the manufacturer of the servo motor,
these angles may vary. A signal that is either too narrow or too wide for a servo will cause the servo to try to go
beyond its rotational range and can damage the servo. Always check the manufacturer’s instructions for a servo’s
rotational range.
Servo Position
Set by Pulse
Width
1.5 ms
Pulse
Width
2.0 ms
Pulse
Width
1.0 ms
Pulse
Width
Pulse
Period
Figure 1. Servo control diagram.
Because the pulse length is relatively long, any of the IO pins on a Digilent system board are capable of driving a
servo motor. However, in order to have the servo motor maintain its given angle, a refresh pulse of the same (or
new) angle will need to be provided to the servo motor periodically (20 milliseconds is a safe value). When using
the Servo library available from Digilent, the refresh pulse and the pulse width are automatically taken care of,
allowing the user to simply give the desired angle for the servo motor to rotate to.
3
Physical Dimensions
The pins on the pin header are spaced 100 mil apart. The PCB is 1.0 inches long on the sides parallel to the pins on
the pin header and 0.8 inches long on the sides perpendicular to the pin header.
Page 2 of 2
很抱歉,暂时无法提供与“410-082”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+44.034921+5.69986
