1300 Henley Court
Pullman, WA 99163
509.334.6306
www.digilentinc.com
PmodLED™ Reference Manual
Revised December 17, 2015
This manual applies to the PmodLED rev. A
Overview
The Digilent PmodLED contains 4 individual user LEDs that are driven through logic-level transistors.
Features include:
4 high-bright LEDs
Required driving current of less than 1 mA
Easy-to-see logic level indicators
The PmodLED.
1
Functional Description
The PmodLED utilizes logic-level transistors to light up four individual high-bright LEDs. Each LED can be turned on
through the use of less than 1 mA of current, making this Pmod ideal for users needing small indicator lights.
2
Interfacing with the Pmod
The PmodLED communicates with the host board via the GPIO protocol. A logic high level turns on the LED and
a logic low signal turns off the LED.
DOC#: 502-076
Copyright Digilent, Inc. All rights reserved.
Other product and company names mentioned may be trademarks of their respective owners.
Page 1 of 2
Signal
LD0
LD1
LD2
LD3
GND
VCC
Description
LED 0
LED 1
LED 2
LED 3
Power Supply Ground
Positive Power Supply
Table 1. Pinout description table.
P1
P2
J1 Connector
Pin
1
2
3
4
5
6
P3
P4
GND
Vcc
Figure 1. LED module circuit diagram.
It is recommended that Pmod is operated at 3.3V.
3
Physical Dimensions
The pins on the pin header are spaced 100 mil apart. The PCB is 0.8 inches long on the sides parallel to the pins on
the pin header and 0.8 inches long on the sides perpendicular to the pin header.
Page 2 of 2
很抱歉,暂时无法提供与“410-076”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+64.045001+8.30580
- 5+62.764505+8.13980
- 国内价格 香港价格
- 1+61.763961+7.99470
