Page 1 of 6
Digilentinc.com Blog Learn
Search
Accessories
Screws, clips, speakers, battery holders, cables, wires, and other assorted useful parts.
Software Defined Radio (SDR) Kit
• Contains all the parts needed to construct a complete software radio station
with a Xilinx ML605 & an Analog Devices FMCOMMS1 board (boards sold seperately)
• Kit includes:
◦ 2 plexiglass covers
◦ cooling fan
◦ mounting hardware
◦ 2 antennae
USB A to B cable
• Nearly 5 feet in length
• Part# 250-059
USB A to mini B cable
• Part# 310-054P
USB A to micro B cable
• Part# 310-053P
IR Range Sensor
Measuring range: 10-80 cm
Current consumption: 30mA typical
Supply voltage: 4.5 - 5.5 V
Includes 10" 3-wire cable
BNC Oscilloscope Probes (pair)
BNC-terminated
Selectable 1X/10X input attenuation
Contraction hook tip
12cm ground clip
Localization sleeve adapts to IC testing
Mini "Grabber" test hooks
Lightweight and durable construction
Two signal connection points for Discovery signal wires
Six colors coordinated to Discovery signal wire colors
Able to grasp conductors up to 1.27mm in diameter
Page 2 of 6
IR Proximity Sensor (2-pack)
• Fairchild QRB1134 Phototransistor Reflective Object Sensor
• Ideal for use with the PmodLS1
• Part# 240-012
40-pin DIP Socket
Perfect for our C-MOD or anything in the 2x20-pin DIP package
Current rating: 1Amp
Contact resistance: 20mΩ max
Note: This product has pins for through-hole mounting and is not suitable for surface
mounting.
• Part# 163-053
Desktop Switching Power Supply
Learn more about
Digilent Design Contest
2014!
• 5VDC Switching Power Supply, 4000mA
• Suitable for use with the Virtex-II Pro (V2-Pro)
• US, EU, UK Plug options available
5V 4000mA Switching Power Supply
5VDC switching supply, with 4000mA current
Comes with US and EU plug adapters
For use with Digilent FPGA & Microcontroller boards
Part# 240-030
5V 2.5A Switching Power Supply
• 5V, 2.5A Switching Power Supply
• Suitable for use with the ZYBO™ FPGA board.
• Part# 300-031P
Heatsink w/ Clip
Self-adhesive backing with clip for easy installation and removal
Measures 35mm X 35mm X 10mm
Perfect for the Virtex-5 board
Part# 6003-170-003
Pmod Clip
Useful for securely attaching a Pmod to your project or application
Works with any Pmod 0.80" in width
Can also accomodate a Cerebot Nano
Ships with 8-32 nut & screw
Part# 240-107
Standoffs
• Contains:
◦ 4 hexagonal standoffs (6-32 x 0.375)
◦ 4 machine screws (6-32 x 0.250)
◦ 4 nylon washers
• Part# 240-020
Speaker
Nominal Impedance 4 Ohms at 1V (1000Hz)
Frequency Bandwidth 880Hz to 10kHZ
Max power input 5W
Part# 310-027
512Mbytes DDR DRAM
• 512Mbytes of fast DDR DRAM
Page 3 of 6
• Can be used with the XUPV2P board
• Part# D350-000
256Mbytes DDR DRAM
• 256Mbytes of fast DDR DRAM
• Part# 350-001
Battery Holder (4 x AA)
Holds four AA cells
Header connector for easy connection to many Digilent boards
Polycarbonate construction
Part# 163-165
Battery Holder (2 x AA)
Holds two AA cells
Part# 163-043
Solderless Breadboard Kit - Small
Convenient breadboard for constructing small-to-medium circuits
Self-adhesive backing - can be affixed to any surface
1x 630 tie point terminal strip
1x 100 tie point distribution strip
1.75 x 4.5 inches
Part# 340-015
Solderless Breadboard Kit - Large
Large breadboard with rugged steel backing
3x 630 tie point terminal strips
5x 100 tie point distribution strips
Four screw terminals for power supply connections
5 adhesive rubber feet
Part# 340-002P
Analog Parts Kit
• Large selection of components designed to create a wide variety of useful
experiments & devices
• Includes transistors, resistors, capacitors, diodes, sensors, and more
• Also includes a variety of useful ICs like Op Amps, convertors, and regulators
• Comes with an assortment of lead wires, a solderless breadboard, and a screwdiver
• This kit can also be bundled with an Analog Discovery for $20 off!
Wire Kit
• 140 pieces of pre-trimmed .22ga jumper wires, in various lengths and colors
• Contained in hard plastic box
• Part# 310-001
XUP Fly Wire Assembly
• For use with the XUP USB-JTAG Programming Cable (above)
• Breaks out each of the six JTAG signals to individual female headers, the signal name printed
on each wire
• Allows for use of the Programming Cable with boards utilizing different JTAG connectors.
• Part# 250-041
USB to Serial Adapter Cable
• Plugs into any USB port and provides a serial connection
• Allows newer PCs without their own serial ports to program serial-only system boards
Page 4 of 6
• Part# 310-035P
UART Crossover Cable
• 6", 6-pin crossover cable
• Connects newer UART-interface Pmods (PmodBT) to older microcontroller boards (Cerebot
2, Cerebot 32MX4, etc.)
• Connects older UART-interface Pmods (PmodCLS, PmodRS232, etc.) to newer
microcontroller boards (Coming soon)
• For more information on where / how to use this cable, please see this document.
• Part# 250-047
VHDCI Male-to-Male Cable
VHDCI male connector on both ends
16" in length
Useful for connecting Vmods to VHDCI-equipped system boards (Genesys, Atlys, ...)
Part# 250-045P
HDMI Cable (Type A to Type A)
• 40" in length
• Part# 240-053P
HDMI Cable (Type A to Type D micro)
• 40" in length
• Part# 310-051P
6 Pin Cable Connector
available in lengths of 6", 12", and 18"
designed for use with Digilent peripheral modules
can be used to send FPGA signals to an outside device
6-pin connectors are standard 100mil spaced 25mil square connectors
allow signals to be routed to and from an FPGA on a Digilent system board
Part# 310-009 / 310-034 / 310-010
2x6 Pin Cable
Designed to connect a 12-pin Pmod to a 12-pin system board connector
Can be used to send Digilent System board signals to and from outside devices
Uses standard 100mil-spaced 25mil square connectors
7" (18mm) in length
Part# 250-032P
2x6 Pin to Dual 6 Pin Cable
• Designed for use with Digilent Peripheral Modules that have 2x6 pin connectors
• Designed to connect two 6-pin system board connectors to a 12-pin Pmod connector, or to
connect a 12-pin system board connector to two 6-pin Pmod connectors
• Uses standard 100mil-spaced 25mil square connectors
• 7" (18mm) in length
• Part# 250-030
6Pin Header & Gender Changer
Changes gender for any 6 pin female header, female to male
Connects any 2 digilent 6 pin cables together
Provides easy access for test and measurement
Ships in pack of 5
Part# 240-004
PICkit3 Programming Cable Kit
• For connecting a chipKIT™ board to Microchip's® PICkit3 debugger/programmer.
Page 5 of 6
• Includes a 6" 6-pin cable, a 6-pin gender changer, and a 6-pin right angle male header.
• Part# 240-035
2x6 Pin Header
Acts as a female-to-male gender changer for a 2x6 pin female header or cable
Can connect any two Digilent 2x6 pin cables together
Ships in pack of 5
Part# 240-062P
VHDCI Connector
2x34 pins, male
Right angle type for through-hole mounting
Part #: R-HI-008068-2
Part# 163-433P
Hirose FX2 Socket Connector
• Right angle type for through-hole mounting
• Hirose part# FX2-100S-1.27DS
• Part# 163-062
Cat 5E Ethernet Cable
• Standard RJ-45 connectors
• 10' Category 5E ethernet cable
• Part# 310-011
Coax Power Cable
• 2.1mm female power connector for use with Digilent power supplies
• Useful for any Digilent product that can accept power from an outside source
• Part# 310-024
6 Pin MTE Cable
Provides the option to separate 6 signals using MTE connectors
Can be used with any Digilent board
Ideal for testing and verification
Part# 310-014P
4-Pin MTE Cable
9" in length
Part# 250-060
4-pin to 2x2-pin MTE Cable
9" in length
Part# 240-021-4P
2 Pin MTE Cable
• available in lengths of 9" and 18"
Page 6 of 6
Ships in pack of 5
Part# 240-006 / 240-007
1 Pin MTE Cable
6" in length
Ships in pack of 5
Part# 240-005
2 Pin MTE Power Cable
• Provide power to battery connection on a Digilent Board
• Provides access to any 2 signals that are tied to any 100mil spaced pins
• Part# 310-025P
Protective covers for your XUPV2P board.
Protects both sides of the V2P board
Made from durable plexiglas
Covers have cutouts for all connectors, buttons, and switches
Part# 6003-170-002
European/UK wall plug adapter
Digilent, Inc.
convienent way to switch from US wall plug to European or UK wall plugs
simple snap-on design
used with Digilent Inc.'s switching power supplies
US to European wall plug adapter
US to UK wall plug adapter
Part# 300-008 / 300-009
P.O. Box 428 Pullman, WA 99163-0428
(509) 334-6306 (voice)
http://www.digilentinc.com/Products/Catalog.cfm?NavPath=2,393&Cat=3
(509) 334-6300 (fax)
Contact us
5/2/2014
很抱歉,暂时无法提供与“240-021-12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+44.043351+5.70096
