317990279
317990279
    SEEED(矽递科技)
    USBCP2102SERIALCONVERTER
317990279 数据手册
    USB CP2102 Serial Converter SKU 317990279 Description The USB CP2102 Serial Converter is a small adapter required for the RF Explorer 3G+ IoT for Arduino/Seeeduino board to accept firmware upgrades from a computer. It can be used as well as extra Arduino Serial port if a Seeeduino or other small-form factor board is used with the RF Explorer 3G+ IoT board. This USB converter can be also used for any electronic project if a microcontroller need to convert a serial UART signal into a USB compatible COM Virtual port.  Compatible with RF Explorer 3G+ IoT for Arduino firmware upgrade process  Enables USB / UART serial port in any electronic project  Silicon Labs CP2102 USB adapter  USB specification 2.0 compliant with full-speed 12Mbps  Standard USB type A male and TTL 6 pin connector.  6 pins for 3.3V, RST, TXD, RXD, GND, 5V  Baud rates: 300 bps to 1.5 Mbps  Temperature Range: -40 to +85 Ԩ  Compatible Windows/Linux/MacOS/Android 1 x USB CP2102 Serial Converter 1 x Female/Female cable ribbon cable                                            https://www.seeedstudio.com/USB‐CP2102‐Serial‐Converter‐p‐2825.html 4/11/2017
317990279 价格&库存
很抱歉,暂时无法提供与“317990279”相匹配的价格&库存,您可以联系我们找货
