240-053
240-053
    DIGILENT(迪芝伦)
    HDMICABLE
240-053 数据手册
Page 1 of 6 Digilentinc.com Blog Learn Search Accessories Screws, clips, speakers, battery holders, cables, wires, and other assorted useful parts. Software Defined Radio (SDR) Kit • Contains all the parts needed to construct a complete software radio station with a Xilinx ML605 & an Analog Devices FMCOMMS1 board (boards sold seperately) • Kit includes: ◦ 2 plexiglass covers ◦ cooling fan ◦ mounting hardware ◦ 2 antennae USB A to B cable • Nearly 5 feet in length • Part# 250-059 USB A to mini B cable • Nearly 5 feet in length • Part# 310-054P USB A to micro B cable • Nearly 5 feet in length • Part# 310-053P IR Range Sensor • • • • Measuring range: 10-80 cm Current consumption: 30mA typical Supply voltage: 4.5 - 5.5 V Includes 10" 3-wire cable BNC Oscilloscope Probes (pair) • • • • • BNC-terminated Selectable 1X/10X input attenuation Contraction hook tip 12cm ground clip Localization sleeve adapts to IC testing Mini "Grabber" test hooks • • • • Lightweight and durable construction Two signal connection points for Discovery signal wires Six colors coordinated to Discovery signal wire colors Able to grasp conductors up to 1.27mm in diameter Page 2 of 6 IR Proximity Sensor (2-pack) • Fairchild QRB1134 Phototransistor Reflective Object Sensor • Ideal for use with the PmodLS1 • Part# 240-012 40-pin DIP Socket • • • • Perfect for our C-MOD or anything in the 2x20-pin DIP package Current rating: 1Amp Contact resistance: 20mΩ max Note: This product has pins for through-hole mounting and is not suitable for surface mounting. • Part# 163-053 Desktop Switching Power Supply Learn more about Digilent Design Contest 2014! • 5VDC Switching Power Supply, 4000mA • Suitable for use with the Virtex-II Pro (V2-Pro) • US, EU, UK Plug options available 5V 4000mA Switching Power Supply • • • • 5VDC switching supply, with 4000mA current Comes with US and EU plug adapters For use with Digilent FPGA & Microcontroller boards Part# 240-030 5V 2.5A Switching Power Supply • 5V, 2.5A Switching Power Supply • Suitable for use with the ZYBO™ FPGA board. • Part# 300-031P Heatsink w/ Clip • • • • Self-adhesive backing with clip for easy installation and removal Measures 35mm X 35mm X 10mm Perfect for the Virtex-5 board Part# 6003-170-003 Pmod Clip • • • • • Useful for securely attaching a Pmod to your project or application Works with any Pmod 0.80" in width Can also accomodate a Cerebot Nano Ships with 8-32 nut & screw Part# 240-107 Standoffs • Contains: ◦ 4 hexagonal standoffs (6-32 x 0.375) ◦ 4 machine screws (6-32 x 0.250) ◦ 4 nylon washers • Part# 240-020 Speaker • • • • Nominal Impedance 4 Ohms at 1V (1000Hz) Frequency Bandwidth 880Hz to 10kHZ Max power input 5W Part# 310-027 512Mbytes DDR DRAM • 512Mbytes of fast DDR DRAM Page 3 of 6 • Can be used with the XUPV2P board • Part# D350-000 256Mbytes DDR DRAM • 256Mbytes of fast DDR DRAM • Can be used with the XUPV2P board • Part# 350-001 Battery Holder (4 x AA) • • • • Holds four AA cells Header connector for easy connection to many Digilent boards Polycarbonate construction Part# 163-165 Battery Holder (2 x AA) • • • • Holds two AA cells Header connector for easy connection to many Digilent boards Polycarbonate construction Part# 163-043 Solderless Breadboard Kit - Small • • • • • • Convenient breadboard for constructing small-to-medium circuits Self-adhesive backing - can be affixed to any surface 1x 630 tie point terminal strip 1x 100 tie point distribution strip 1.75 x 4.5 inches Part# 340-015 Solderless Breadboard Kit - Large • • • • • • Large breadboard with rugged steel backing 3x 630 tie point terminal strips 5x 100 tie point distribution strips Four screw terminals for power supply connections 5 adhesive rubber feet Part# 340-002P Analog Parts Kit • Large selection of components designed to create a wide variety of useful experiments & devices • Includes transistors, resistors, capacitors, diodes, sensors, and more • Also includes a variety of useful ICs like Op Amps, convertors, and regulators • Comes with an assortment of lead wires, a solderless breadboard, and a screwdiver • This kit can also be bundled with an Analog Discovery for $20 off! Wire Kit • 140 pieces of pre-trimmed .22ga jumper wires, in various lengths and colors • Contained in hard plastic box • Part# 310-001 XUP Fly Wire Assembly • For use with the XUP USB-JTAG Programming Cable (above) • Breaks out each of the six JTAG signals to individual female headers, the signal name printed on each wire • Allows for use of the Programming Cable with boards utilizing different JTAG connectors. • Part# 250-041 USB to Serial Adapter Cable • Plugs into any USB port and provides a serial connection • Allows newer PCs without their own serial ports to program serial-only system boards Page 4 of 6 • Part# 310-035P UART Crossover Cable • 6", 6-pin crossover cable • Connects newer UART-interface Pmods (PmodBT) to older microcontroller boards (Cerebot 2, Cerebot 32MX4, etc.) • Connects older UART-interface Pmods (PmodCLS, PmodRS232, etc.) to newer microcontroller boards (Coming soon) • For more information on where / how to use this cable, please see this document. • Part# 250-047 VHDCI Male-to-Male Cable • • • • VHDCI male connector on both ends 16" in length Useful for connecting Vmods to VHDCI-equipped system boards (Genesys, Atlys, ...) Part# 250-045P HDMI Cable (Type A to Type A) • 40" in length • Part# 240-053P HDMI Cable (Type A to Type D micro) • 40" in length • Part# 310-051P 6 Pin Cable Connector • • • • • • available in lengths of 6", 12", and 18" designed for use with Digilent peripheral modules can be used to send FPGA signals to an outside device 6-pin connectors are standard 100mil spaced 25mil square connectors allow signals to be routed to and from an FPGA on a Digilent system board Part# 310-009 / 310-034 / 310-010 2x6 Pin Cable • • • • • Designed to connect a 12-pin Pmod to a 12-pin system board connector Can be used to send Digilent System board signals to and from outside devices Uses standard 100mil-spaced 25mil square connectors 7" (18mm) in length Part# 250-032P 2x6 Pin to Dual 6 Pin Cable • Designed for use with Digilent Peripheral Modules that have 2x6 pin connectors • Designed to connect two 6-pin system board connectors to a 12-pin Pmod connector, or to connect a 12-pin system board connector to two 6-pin Pmod connectors • Uses standard 100mil-spaced 25mil square connectors • 7" (18mm) in length • Part# 250-030 6Pin Header & Gender Changer • • • • • Changes gender for any 6 pin female header, female to male Connects any 2 digilent 6 pin cables together Provides easy access for test and measurement Ships in pack of 5 Part# 240-004 PICkit3 Programming Cable Kit • For connecting a chipKIT™ board to Microchip's® PICkit3 debugger/programmer. Page 5 of 6 • Includes a 6" 6-pin cable, a 6-pin gender changer, and a 6-pin right angle male header. • Part# 240-035 2x6 Pin Header • • • • • Acts as a female-to-male gender changer for a 2x6 pin female header or cable Can connect any two Digilent 2x6 pin cables together Provides easy access for test and measurement Ships in pack of 5 Part# 240-062P VHDCI Connector • • • • 2x34 pins, male Right angle type for through-hole mounting Part #: R-HI-008068-2 Part# 163-433P Hirose FX2 Socket Connector • Right angle type for through-hole mounting • Hirose part# FX2-100S-1.27DS • Part# 163-062 Cat 5E Ethernet Cable • Standard RJ-45 connectors • 10' Category 5E ethernet cable • Part# 310-011 Coax Power Cable • 2.1mm female power connector for use with Digilent power supplies • Useful for any Digilent product that can accept power from an outside source • Part# 310-024 6 Pin MTE Cable • • • • • Provides the option to separate 6 signals using MTE connectors 6-pin connectors are standard 100mil spaced 25mil square connectors Can be used with any Digilent board Ideal for testing and verification Part# 310-014P 4-Pin MTE Cable • • • • 9" in length Can be used with any Digilent board Ideal for testing and verification Part# 250-060 4-pin to 2x2-pin MTE Cable • • • • 9" in length Can be used with any Digilent board Ideal for testing and verification Part# 240-021-4P 2 Pin MTE Cable • available in lengths of 9" and 18" Page 6 of 6 • • • • Ships in pack of 5 Can be used with any Digilent board Ideal for testing and verification Part# 240-006 / 240-007 1 Pin MTE Cable • • • • • 6" in length Ships in pack of 5 Can be used with any Digilent board Ideal for testing and verification Part# 240-005 2 Pin MTE Power Cable • Provide power to battery connection on a Digilent Board • Provides access to any 2 signals that are tied to any 100mil spaced pins • Part# 310-025P Protective covers for your XUPV2P board. • • • • Protects both sides of the V2P board Made from durable plexiglas Covers have cutouts for all connectors, buttons, and switches Part# 6003-170-002 European/UK wall plug adapter • • • • • • Digilent, Inc. | convienent way to switch from US wall plug to European or UK wall plugs simple snap-on design used with Digilent Inc.'s switching power supplies US to European wall plug adapter US to UK wall plug adapter Part# 300-008 / 300-009 P.O. Box 428 Pullman, WA 99163-0428 | (509) 334-6306 (voice) http://www.digilentinc.com/Products/Catalog.cfm?NavPath=2,393&Cat=3 (509) 334-6300 (fax) | Contact us 5/2/2014
240-053 价格&库存
很抱歉,暂时无法提供与“240-053”相匹配的价格&库存,您可以联系我们找货
