1300 Henley Court
Pullman, WA 99163
509.334.6306
www.digilentinc.com
PmodSSD™ Reference Manual
Revised May 24, 2016
This manual applies to the PmodSSD rev. A
Overview
The PmodSSD is a two-digit seven-segment display. Users can toggle through GPIO signals which digit is currently
on at a rate of 50Hz or greater to achieve persistence-of-vision to give the effect of both digits being lit up
simultaneously.
Features include:
Two-digit high brightness seven-segment
display
Easily view a counter or timer
Common Cathode configuration
Small PCB size for flexible designs 1.0“ ×
1.7” (2.5 cm × 4.3 cm)
Two 6-pin Pmod connectors
with GPIO interfaces
Follows Digilent Pmod Interface
Specification Type 1
The PmodSSD.
1
Functional Description
The PmodSSD utilizes a common cathode configuration to display a variety of LED segment combinations. The ten
segment combinations corresponding to digits 0 - 9 are generally the most useful, although other custom
combinations can also be created.
2
Interfacing with the Pmod
The PmodSSD communicates with the host board via the GPIO protocol. A logic level high signal on a particular
anode will light up that respective segment on whichever digit is currently enabled. Users are able to select a
particular digit by driving the Digit Selection pin (C) to a logic high or low voltage.
DOC#: 502-126
Copyright Digilent, Inc. All rights reserved.
Other product and company names mentioned may be trademarks of their respective owners.
Page 1 of 2
Because only one digit can be lit at a particular time, users that want to use both digits to display a particular value
will need to alternately light up the two digits at least every 20 milliseconds (50 Hz). This will correlate to each digit
being lit up for 10 milliseconds each before the other segment needs to be “turned on”. Higher refresh rates can
be achieved by alternating which digit is currently powered at shorter time intervals.
Pin
1
2
3
4
5
6
Signal
AA
AB
AC
AD
GND
VCC
Header J1
Description
Segment A
Segment B
Segment C
Segment D
Power Supply Ground
Positive Power Supply
Pin
1
2
3
4
5
6
Signal
AE
AF
AG
C
GND
VCC
Header J2
Description
Segment E
Segment F
Segment G
Digit Selection pin
Power Supply Ground
Table 1. Pinout description table.
J1 Connector
560
P1 AA
P2 AB
P3 AC
P4 AD
GND
J2 Connector
Vcc
P1 AE
P2 AF
P3 AG
AA1
AB1
AC1
AD1
AE1
AF1
AG1
C1
AA2
AB2
AC2
AD2
AE2
AF2
AG2
C2
P4 C
GND GND
Vcc
Vcc
Figure 1. Seven-segment display connection diagram.
Any external power applied to the PmodSSD must be within 2.7V and 5.25V; however, it is recommended that
Pmod is operated at 3.3V.
3
Physical Dimensions
The pins on the pin header are spaced 100 mil apart. The PCB is 1 inch long on the sides parallel to the pins on the
pin header and 1.7 inches long on the sides perpendicular to the pin header.
Page 2 of 2
很抱歉,暂时无法提供与“410-126”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+85.042421+10.99976
