6032-410-000
6032-410-000
    DIGILENT(迪芝伦)
    BOARDORBITBOOSTER
6032-410-000 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com Orbit BoosterPack™ Reference Manual Revised June 5, 2013 This manual applies to the Orbit BoosterPack rev. A Overview The Digilent Orbit BoosterPack™ is an add-on board for the Texas Instruments Stellaris® LaunchPad microcontroller evaluation kit. The Orbit greatly expands the input/output capabilities of the LaunchPad, as well as introducing Digilent Pmod™ expansion connectors. Features include: • • • • • • Two 1x6 Digilent Pmod™ connectors 3-axis accelerometer 2 256 Kbit I C EEPROM 2 I C temperature sensor 128x32 pixel OLED display Analog potentiometer The Orbit BoosterPack. 1 Orbit BoosterPack Hardware Description The following gives a basic description of the input/output hardware contained in the Orbit BoosterPack and how to use it. Refer to Appendix A for a table showing pin definitions. 1.1 OLED Graphic Display The Orbit board provides a 128x32 pixel, organic LED (OLED), graphic display panel. The graphic display panel used is the WiseChip/Univision UG-23832HSWEG04. This display uses the Soloman Systech SSD1306 display controller. The UG2832 has a power on/power off sequence that should be followed. Failure to follow the power on/power off sequence can shorten the life of the display. The Orbit provides two FETs for software control of the two power supplies for the display. The VDD_OLED control is used to turn on/off the power to the logic of the display. The DOC#: 6032-502-000 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 5 Orbit BoosterPack™ Reference Manual VBAT_OLED control is used to turn on/off power to the OLED display itself. These two pins have pull-up resistors to turn off their respective power supplies when not being driven. The pins are made to be outputs and are driven low to turn on the power supplies. Power on sequence: Apply power to VDD Send Display Off command Initialize display to desired operating mode Clear screen Apply power to VBAT Delay 100ms Send Display On command Power off sequence: Send Display Off command Power off VBAT Delay 100ms Power off VDD The display has a D/C pin (display or command select) that is used to determine whether bytes sent to the display are interpreted as commands or as display data. The D/C pin is driven high for display buffer access and is driven low for command access. This pin is shared with VBUS detection on the LaunchPad. If VBUS is present, the pulldown resistor acts as a pull-up resistor in conjunction with resistor 6 (R6) on the LaunchPad. Please see the note in the Orbit BoosterPack Schematic available from www.digilentinc.com. The D/C pin is also a non-maskable interrupt (NMI) pin on the LaunchPad, and is “locked” on the device's powerup. In order to unlock the D/C pin to be used as a general purpose output, 0x4C4F434B must be written to GPIOLOCK register. For more information, please see the LM4F120H5QR Datasheet at: www.ti.com. The RES pin is used to reset the SG1306 display controller. The RES pin is driven low for reset and driven high for normal operation. The low-going reset pulse must be a minimum of 3μs (microseconds) for the display controller to reset correctly. The UG2832 is a serial device that is accessed using SPI. It is however, a write-only device. It is not possible to read back either the display buffer contents or any kind of status from the panel. The maximum SPI clock frequency supported by the UG2832 is 10MHz. Digilent has a library for use with the Orbit BoosterPack that provides functions for initializing the display and rendering simple text and graphics onto the display. This library can be used as is or as a starting point for a more sophisticated graphics library and is available at www.digilentinc.com. 1.2 Digilent Pmod Connectors Two 1x6 pin female Digilent Pmod connectors are provided for functional expansion of the Orbit BoosterPack. They are labeled JA and JB respectively. Header JA has signals routed to the Synchronous Serial Interface (SSI) Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 5 Orbit BoosterPack™ Reference Manual peripheral on the LaunchPad. These signals can be used with Pmods that use standard 3 or 4 wire SPI communication protocol. 1.3 Discrete Digital I/O Devices Pushbuttons: There are two pushbutton switches labeled BTN1 and BTN2. A read to the corresponding GPIODATA register bits will return a '0' when the button is released and a '1' when the button is pressed. Slide Switches: There are two slide switches labeled SW1 and SW2. A read to the corresponding GPIODATA register bits will return a '0' when a switch is down (toward the LEDs) and a '1' when a switch is up (toward the OLED display). LEDs: There are four LEDs, labeled LD1 – LD4. An LED will be illuminated when the corresponding GPIODATA register bit is set to a '1' (given the corresponding direction bit has been set in the GPIODIR registers) and off when set to a '0'. 1.4 I2C Bus 2 2 The I C bus from the LaunchPad microcontroller board is brought onto the Orbit BoosterPack. There are three I C devices on the board: a 256 Kbit EEPROM, a temperature sensor, and an accelerometer. In addition, there is a 2 2 connector for taking the I C bus off of the board to connect to additional external I C devices. 2 2 2 I C Connector: Connector J5 can be used to extend the I C bus off of the board to connect to additional external I C 2 devices. J5 is a standard 2x4 pin header connector with 0.100” spaced pins. It provides access to the I C signals, SCL 2 and SDA, plus VCC3V3 and GND. The VCC3V3 can be used to power external I C devices. 2 The I C bus uses open collector drivers to allow multiple devices to drive the bus signals. This means that pull-up resistors must be provided to supply the logic high state for the signals. The Orbit BoosterPack provides 2.2 K-ohm pull-up resistors. Generally, only one set of pull-up resistors are used on the bus. 2 Digilent has several small I/O modules available that can be connected using the I C connector. These include a 4channel, 12-bit A/D converter, serial character LCD panel, 3-axis gyroscope, real-time clock/calendar, and I/O expander. 2 EEPROM: A 256Kbit (32Kbyte), I C EEPROM is provided using a Microchip 24LC256. This EEPROM, IC3, is located on the bottom side of the board. 2 The seven bit I C device address for the EEPROM is '1 0 1 0 A2 0 0', where A2 is an external pin. Pin A2 is pulled 2 high through a 10 K-ohm resistor and a cuttable trace at JP7. Therefore, the 'as-is' seven bit I C device address for the EEPROM is '1010100', or 0x54. Cutting the trace between pins 1 and 2 of JP7 and loading a two-pin header with a shorting block on pins 2 and 3 of JP7 will make the 10 K-ohm resistor acts as pull-down. In this case, A2 must be set to '0' in software. For complete technical documentation on the 24LC256, refer to the data sheet available from www.microchip.com. Temperature Sensor: A digital temperature sensor is provided using a Microchip TCN75A 2-Wire Serial 2 Temperature Sensor. The temperature sensor, IC4, is an I C device, and is located next to BTN1. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 5 Orbit BoosterPack™ Reference Manual The TCN75A is rated for an accuracy of +/-1ºC and has selectable resolution from 0.5ºC down to 0.0625ºC. The seven bit device address is '1001111', or 0x4F. Note that the last three bits set to '1' because external pins A2, A1, and A0 are pulled high by 10 K-ohm resistors and cuttable traces at JP2, JP4, and JP6. The TCN75A provides an alert output that can be programmed for various functions. For complete technical documentation on the TCN75A, refer to the data sheet available at www.microchip.com. Accelerometer: A 3-axis accelerometer is provided using an Analog Devices ADXL345. This accelerometer, IC2, is located to the right of BTN2. The silkscreen shows the axis configuration. 2 The 7 bit I C device address for the accelerometer is '0011101', or 0x1D. The ADXL345 has two output pins for setting configurable interrupts, which include activity, inactivity, and DATA_READY. For complete technical documentation on the ADXL345, refer to the data sheet available at www.analog.com. 1.5 Potentiometer A potentiometer (pot) is provided on the board to be used as an analog signal source or analog control input. The pot is a 1 K-ohm trimmer pot connected between the VCC3V3 supply and ground. The wiper of the pot is connected to analog input AIN0. Appendix A: Orbit BoosterPack Pinout Table Connector # Pin # Port and Bit Function Description J1 J1 1 2 PB5 VCC3V3 LD4 Power supply User LED J1 3 PB0 JB_03/RX Pmod connector B pin 3/Rx UART1 J1 4 PB1 JB_02/TX Pmod connector B pin 2/Tx UART1 J1 5 PE4 INT2_ACL Accelerometer Interrupt Output J1 6 PF5 /RES_OLED OLED reset J1 7 PB4 INT1_ACL Accelerometer Interrupt Output J1 8 PA5 JA_02/MOSI Pmod Connector A pin 2/Serial Out J1 9 PA6 SW2 Slide switch J1 10 PA7 SW1 Slide switch J2 1 - GND Ground J2 2 PB2 SCL I C clock J2 3 PE0 BTN2 Push button J2 4 - - - Not connected J2 5 - - - Not connected J2 6 - - - Not connected J2 7 - - - Not connected Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. 2 Notes SSI0 I2C0 Page 4 of 5 Orbit BoosterPack™ Reference Manual J2 8 PA4 JA_03/MISO Pmod Connector A pin 3/Serial In SSI0 J2 9 PA3 JA_01/SS Pmod Connector A pin 1/Slave Select SSI0 J2 10 PA2 JA_04/SCK Pmod Connector A pin 4/Serial Clock SSI0 J3 1 - - - Not connected J3 2 - GND Ground J3 3 PD0 SCK_OLED OLED serial clock SSI3/SSI1 J3 4 PD1 /CS_OLED OLED chip select SSI3/SSI1 J3 5 PD2 BTN1 Push button J3 6 PD3 SDI_OLED OLED serial data in J3 7 PF1 VBAT_OLED OLED VBAT enable J3 8 PE2 VDD_OLED OLED VDD enable J3 9 PE3 AIN Potentiometer AIN0 J3 10 - - - Not connected J4 1 - - - Not connected J4 2 - - - Not connected I2C0 2 J4 3 PB3 SDA J4 4 PF0 JB_04/RTS J4 5 PF1 JB01/CTS I C data Pmod connector B pin 4/Request to Send Pmod connector B pin 1/Clear to Send J4 6 PC6 LD1 User LED J4 7 PC7 LD2 User LED J4 8 PD6 LD3 User LED J4 9 PD7 /DC_OLED OLED data/command select J4 10 - Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. SSI3/SSI1 UART1 UART1 Not connected Page 5 of 5
6032-410-000 价格&库存
很抱歉,暂时无法提供与“6032-410-000”相匹配的价格&库存,您可以联系我们找货
