410-116
410-116
    DIGILENT(迪芝伦)
    Digilent Boards - Interface Board
410-116 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodJSTK™ Reference Manual Revised May 24, 2016 This manual applies to the PmodJSTK rev. C Overview The PmodJSTK is designed to be a versatile peripheral module that can be used in a wide variety of projects. It contains a resistive twin axis joystick that includes a center push button along with two additional push buttons. The PmodJSTK also has two programmable LEDs located on the board that can provide additional information to the user. The PmodJSTK is ideally suited for Digilent microcontroller or FPGA based projects that require proportional control from the user, such as robotic applications. Features include:        2-axis resistive joystick with central push button Two additional user push buttons Two user indicator LEDs Small PCB size for flexible designs 1.8“ × 1.3” (4.6 cm × 3.3 cm) 6-pin Pmod connector with SPI interface Follows Digilent Pmod Interface Specification Type 2 Library and example code available in resource center The PmodJSTK. 1 Functional Descriptions The PmodJSTK uses an Atmel® ATtiny24 microcontroller in a MLF20 package to collect information about its peripherals. The twin axis joystick uses two potentiometers to measure the current position in the x and y coordinate directions and stores the information in two 10-bit values ranging from 0 to 1023. 2 Interfacing with the Pmod The PmodJSTK communicates with the host board via the SPI communication protocol in 5 byte chunks. The first four bytes correspond to the two 10-bit values representing the X and Y coordinate directions and the last byte DOC#: 502-116 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 3 PmodJSTK™ Reference Manual indicates the status of the three push buttons. Details on the organization of these bytes are provided a little further down in this document. The PmodJSTK will send its total of 23 bits of information to the system board through 40 clock cycles. The first two bytes received will consist of the 10-bit position of the potentiometer in the x-direction (with the Pmod arranged so that the pin header is facing "up"). The lower 8 bits of this 10-bit value will arrive MSB in the first byte and the remaining two MSB of the 10-bit value will arrive as the last two bits in the second byte. Similarly, the 10-bit position of the potentiometer in the y-direction (with the Pmod arranged so that the pin header is facing "up"). The lower 8 bits of this 10-bit value will arrive MSB in the third byte and the remaining two MSB of the 10-bit value will arrive as the last two bits in the fourth byte. The three bits representing the three push buttons arrive as the last three bits in the fifth byte where a '1' indicates that the button is pressed and a '0' indicates that the button is not being pressed. The organization of the button bits (as labeled on the silk screen of the Pmod) are arranged as follows in the fifth byte. The overall order of bytes that will be sent by the PmodJSTK to the system board will be as follows: 1 X (low) 2 X (high) 3 Y (low) 4 Y (high) 5 Buttons Table 1. Byte order sent by the PmodJSTK to the system board. As per the SPI protocol, the system board also needs to send five bytes of information to the Pmod. The first byte will contain information indicating if the two on-board LEDs should be turned on or off with the remaining four bytes ignored by the PmodJSTK. The last two bits of the first byte sent indicate the status LED2 and LED1, respectively. A pinout table for the PmodJSTK is provided below: Pin 1 2 3 4 5 6 Signal ~CS MOSI MISO SCK GND VCC Description Chip Select (active low) Master-Out-Slave-In Master-In-Slave-Out Serial Clock Power Supply Ground Power Supply (3.3V/5V) Table 2. Pin descriptions for the PmodJSTK. Any external power applied to the PmodJSTK must be within 2.7V and 5.5V; however, it is recommended that the Pmod is operated at 3.3V. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 3 PmodJSTK™ Reference Manual 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1.8 inches long on the sides parallel to the pins on the pin header and 1.3 inches long on the sides perpendicular to the pin header. 4 Additional Information For the most up-to-date reference material, visit Digilent's Wiki at reference.digilentinc.com. The schematics of the PmodJSTK are available here. Additional information about the Atmel ATtiny24 can be found at atmel.com. Example code demonstrating how to get information from the PmodJSTK can be found here. If you have any questions or comments about the PmodJSTK, feel free to post them under the appropriate section ("Add-on Boards") of the Digilent Forum. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 3
410-116 价格&库存
很抱歉,暂时无法提供与“410-116”相匹配的价格&库存,您可以联系我们找货
  • 1+175.991511+22.78027
