7C-40.000MCB-T
7C-40.000MCB-T
    TXC(台晶)
    SMD-4
    有源晶振 40MHz 2.5V SMD-4
7C-40.000MCB-T 数据手册
come visit our site http://www.txccorp.com SMD Crystal OscillatorsCMOS Output 5.0 x 3.2 x 1.2 mm 7C Series Oscillators Series Think of Frequency Think of Features .Small SMD seam sealed clock crystal oscillator units. 5.0 H 2 C TX AY O B .High precision characteristic covering up to wide frequency range. .Designed for automatic mounting and reflow soldering. .Tri-State function available. .Supply voltage range : 1.8 V ~ 5.0 V. .High stability, low jitter, low power consumption. .Main application : wireless communication set, PDA, and DSC. .RoHS Compliant / Pb Free. Item / Type 7C Output Type CMOS Output Load 15 pF , 30 pF Oscillation Mode Fundamental / 3rd Overtone 1.8 V Supply Voltage 2.5 V , 2.8 V , 3.3 V 5V Frequency Range 1 ~ 150 MHz Frequency Stability ± 20 ppm , ± 25 ppm , ± 30 ppm , ± 50 ppm Operating Temperature Range - 10 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) 0.1 VDD / 0.9 VDD Rise ( Tr ) / Fall ( Tf ) Time 8 ns Max. Current Consumption 1-75 MHz 75-150 MHz 5 mA Max. 10 mA Max. 20 mA Max. 15 mA Max. 20 mA Max. NA Symmetry 40 ~ 60 % Start-up Time 5 ms Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 ps Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max. Dimensions Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications Units: mm 45
7C-40.000MCB-T
1. 物料型号:文档中没有明确指出具体的物料型号,但提到了7C系列。
2. 器件简介:7C系列是小型SMD封装的时钟晶体振荡器,具有高精度特性,覆盖广泛的频率范围,设计用于自动贴装和回流焊接。
3. 引脚分配:文档提供了引脚功能图示,包括: - 1: ENABLE CONTROL - 2: GND - 3: OUT - 4: VDD
4. 参数特性:包括输出类型为CMOS,输出负载为15pF和30pF,振荡模式为基础频率/三次谐波,供电电压范围为1.8V至5V,频率范围为1-150MHz,频率稳定性有多种选择,工作温度范围和存储温度范围,以及电压变化和上升/下降时间等。
5. 功能详解:文档提到了高稳定性、低抖动、低功耗和三态功能。
6. 应用信息:主要应用于无线通信设备、PDA和DSC。
7. 封装信息:封装尺寸为5.0 x 3.2 x 1.2 mm,提供了顶视图、侧视图和底视图,以及建议的布局。
7C-40.000MCB-T 价格&库存
很抱歉,暂时无法提供与“7C-40.000MCB-T”相匹配的价格&库存,您可以联系我们找货
7C-40.000MCB-T
  • 1000+11.203341000+1.44945
  • 2000+10.740862000+1.38962
  • 3000+10.479453000+1.35580
  • 5000+10.159335000+1.31438
  • 7000+9.954007000+1.28782
库存:1570
7C-40.000MCB-T
  • 1+17.085831+2.21051
  • 10+14.8291310+1.91855
  • 25+14.0266525+1.81473
  • 50+13.4459950+1.73960
  • 100+12.89017100+1.66769
  • 250+12.18999250+1.57710
  • 500+11.68609500+1.51191
库存:1570
