AU-25.000MBE-T
AU-25.000MBE-T
    TXC(台晶)
    SMD-4
    有源晶振 25MHz 3.3V SMD-4
AU-25.000MBE-T 数据手册
come visit our site http://www.txccorp.com Automotive Application Series Think of Frequency Think of SMD OscillatorsCMOS Output 3.2 x 2.5 x 1.0 mm AU Series Features 92 T1 Q2J .Ultra small SMD seam sealed clock crystal oscillator units. .High precision characteristic covering up to high frequency range. H .Designed for automatic mounting and reflow soldering. .Supply voltage rang:1.8V ~ 3.3V. .High stability, low jitter, low power consumption. .RoHS Compliant / Pb Free. Item / Type AU Output Type CMOS Output Load 15 pF Oscillation Mode Fundamental Supply Voltage 1.8 V , 2.5 V , 2.8 V , 3.3 V 1 MHz ~ 70 MHz Frequency Range Frequency Stability ± 25 ppm , ± 50 ppm , ± 100 ppm ± 100 ppm , or specify OperatingTemperature Range - 40 ~ + 85 ℃ - 40 ~ + 125 ℃ Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) 0.1 VDD / 0.9 VDD Rise ( Tr ) / Fall ( Tf ) Time 5 ns Max. Supply Current 10 mA Max. Symmetry 45 ~ 55 % Start-up Time 5 ms Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 ps Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max. Reliability Standard AEC-Q100 Dimensions PAD FUNCTION: 1:ENABLE CONTROL 2:GND 3:OUT 4:VDD Suggested Layout Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications Units: mm 33
AU-25.000MBE-T 价格&库存
很抱歉,暂时无法提供与“AU-25.000MBE-T”相匹配的价格&库存,您可以联系我们找货
AU-25.000MBE-T
  • 3000+13.788903000+1.79042
  • 6000+13.220976000+1.71668
库存:19140
AU-25.000MBE-T
  • 1+22.445801+2.91448
  • 10+19.5167410+2.53415
  • 25+18.4525425+2.39597
  • 50+17.6903250+2.29700
  • 100+16.95960100+2.20212
  • 250+16.03847250+2.08252
  • 500+15.37584500+1.99648
  • 1000+14.740861000+1.91403
库存:19140
