BJ-122.880MBE-T
BJ-122.880MBE-T
    TXC(台晶)
    SMD-6
    有源晶振 3.3V 122.88MHz SMD-6
BJ-122.880MBE-T 数据手册
Think of Frequency Think of Oscillators Series SMD LVPECL VCXO Differential Output 7.0 x 5.0 x 1.3 mm BJ Series come visit our site http://www.txccorp.com Features .Voltage Controlled Crystal Oscillator (VCXO). H Y1 0 C J 0 25 CB TX 156. .Fundamental solution. .LVPECL output, output frequencies 50 MHz to 200 MHz. .Excellent low phase noise and jitter. .Tri-State function available. .Applications : SDH/ SONET, Ethernet, Base Stations. .RoHS Compliant / Pb Free. Electrical Specifications Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type BJ Output Type LVPECL Output Load 50 Ω Oscillation Mode Fundamental Supply Voltage (VDD) 3.3 V Frequency Range 50 ~ 200 MHz Operating Temperature Range -10 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) VDD - 1.62 V / VDD - 1.025 V Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 1 nS Max. Supply Current 80 mA Symmetry 45 ~ 55 % Start-up Time 10 mS Max. Absolute Pulling Range ( APR ) * ± 50 ppm Min. , or specify Nominal Control Voltage 0.5 VDD Control Voltage Range 0 ~ VDD Linearity 10 % Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 pS Max. * APR=(Pull Range) - (Frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, and aging.) Dimensions Units: mm 82
BJ-122.880MBE-T 价格&库存
很抱歉,暂时无法提供与“BJ-122.880MBE-T”相匹配的价格&库存,您可以联系我们找货
