AS1301A-BWLT
AS1301A-BWLT
    AMSOSRAM(艾迈斯半导体)
    WLCSP8
    IC REG CHARG PUMP 5V 50MA 8WLCSP
AS1301A-BWLT 数据手册
AS1301 5V/50mA Low Noise Inductorless Boost Converter D a ta S he e t 1 General Description The AS1301 is a 50mA inductorless boost converter using a double H-bridge charge-pump topology with two external flying capacitors. The AS1301 runs on a 1MHz fixed frequency and is utilized with a low noise regulation scheme to allow usage together with sensitive RF circuitry from the same battery supply. Designed to reside in portable and space limited equipment the 1MHz charge pump converts a 2.7 to 5.25V input to regulated 5V output with 5% accuracy. The shutdown function reduces the supply current to
AS1301A-BWLT 价格&库存
很抱歉,暂时无法提供与“AS1301A-BWLT”相匹配的价格&库存,您可以联系我们找货
