CI-148-028-3
CI-148-028-3
    BIVAR
    HDWR INS TAB 0.325 X 0.145 CLR
CI-148-028-3 数据手册
crystal insulators Mylar Mounts • Only 0.005" Thick does not increase component height • Insulates component from PCB • Allows for trace to be run under components Material Specifications: UL Rated 94VTM-2 Mylar Film Dupont EL-21 Clear Oxygen Rating Index: Over 28% UL File #E93687 Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.40) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Note: SR Stands for Self Retaining Part No. C C/C L D W Case Style Price Code CI-148-028 - .148 (3.8) .325 (8.3) .028 (.71) .145 (3.7) VI X HC-80/U CI-148-028 SR* - .148 (3.8) .325 (8.3) * .145 (3.7) VI X HC-80/U CI-148-028-3 .074 (1.9) .148 (3.8) .325 (8.3) .028 (.71) .145 (3.7) VI X HC-80/U CI-148-028-3 SR* .074 (1.9) .148 (3.8) .325 (8.3) * .145 (3.7) VI X HC-80/U CI-192-028 - .192 (4.9) .465 (11.8) .028 (.71) .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U CI-192-028 SR* - .192 (4.9) .465 (11.8) * .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U CI-192-028-3 .096 (2.4) .192 (4.9) .465 (11.8) .028 (.71) .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U CI-192-028-3 SR* .096 (2.4) .192 (4.9) .465 (11.8) * .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U .192 (4.9) .465 (11.8) .050 (1.3) .219 (5.6) II X HC-25/U, HC-42/U & HC-50/U .096 (2.4) .192 (4.9) .465 (11.8) .050 (1.3) .219 (5.6) II X HC-25/U, HC-42/U & HC-50/U CI-192-050 CI-192-050-3 95 www.bivar.com Use with - cage code (FSCM) 32559 © copyright 2004 Bivar Inc.
CI-148-028-3 价格&库存
很抱歉,暂时无法提供与“CI-148-028-3”相匹配的价格&库存,您可以联系我们找货
