9HT7
kHz Crystal
Features
Frequency range : 32.768 kHz
SMD : Plastic package
External dimensions (mm)
L : 6.9 x W : 1.4 x H : 1.4
RoHS compliant
Contains Pb, exempted by RoHS directive
Applications
Small mobile devices
Consumer products
Electrical Characteristics
Item
Symbol
9HT7
f0
32.768 kHz
∆f/f0
±20 ppm
CL
7pF, 9pF, 12.5pF
Operating Temperature Range
TOTR
-40°C ~ +85°C
Storage Temperature Range
TSTR
-55°C ~ +125°C
TM
25°C ± 5°C
Temperature Coefficient
β
-0.04ppm/°C2 Max.
Motional Capacitance
C1
1.9 fF Typ.
Motional Resistance (ESR)
R1
65 kΩ Max.
Drive Level
DL
1 μW Max.
∆f/f0
±3 ppm Max.
C0
0.8 pF Typ.
Nominal Frequency
Frequency Tolerance
Load Capacitance
Turnover Temperature
Aging
Shunt Capacitance
Conditions
at 25°C
at 25°C
at 25°C ± 3°C,first year
Dimensions
Internal Connection
The tilted cut is the INDEX MARK.
Do not connect pin2 & pin3 to
external device.
(Unit: mm)
Rev. 1.03
Page 1
www.txccrystal.com
9HT7
kHz Crystal
Ordering Information
9HT7
- 32.768K
D Z F - T
Frequency Tolerance (at 25°C)
D
± 20 ppm
Packaging Method
T
Tape & Reel
Load Capacitance
Frequency Stability (over Temp.)
Z
Standard for kHz
Y
C
F
7 pF
9 pF
12.5 pF
Packing
(Unit: mm)
Reflow Profile
Total time : Max. 200 sec.
Solder melting point : 220°C
Rev. 1.03
Page 2
www.txccrystal.com
很抱歉,暂时无法提供与“9HT7-32.768KDZF-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.164411+0.53878
- 10+3.6034410+0.46621
- 25+3.4064625+0.44072
- 50+3.2649450+0.42241
- 100+3.13048100+0.40501
- 250+2.96013250+0.38298
- 500+2.83777500+0.36714
- 1000+2.720291000+0.35195
