7M-48.000MAHV-T
7M-48.000MAHV-T
    TXC(台晶)
    SMD-4
    陶瓷谐振器 48MHz ±30ppm ±30ppm SMD-4
7M-48.000MAHV-T 数据手册
come visit our site http://www.txccorp.com SMD Seam Sealing Crystals 3.2 x 2.5 x 0.7 mm 7M Series Quartz Crystals Series Think of Frequency Think of Features .High precision and high frequency stability. .Extremely good for reducing EMI effect. .The best choice of Bluetooth, wireless communication set, DSC, PDA, and mobile phone. 60 1 2 0 T 1g .RoHS Compliant / Pb Free. Electrical Specifications 7M Frequency Range 10 ~ 64 MHz Frequency Tolerance (at 25 ℃) ± 30 ppm, or specify Frequency Stability Over Operating Temperature Range ± 30 ppm, or specify Operating Temperature Range -10 ~ +70 ℃, or specify Shunt Capacitance (C0) 3 pF Max. Drive Level 1 ~ 200 μW (100 μW typical) Load Capacitance 10 pF, or specify Aging (at 25 ℃) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type Equivalent Series Resistance(ESR) Fundamental 10 ~ 16 MHz 100 Ω Max. 16 ~ 20 MHz 80 Ω Max. 20 ~ 64 MHz 60 Ω Max. Dimensions Units: mm 5
7M-48.000MAHV-T
- 物料型号:7M系列石英晶体谐振器 - 器件简介:该系列谐振器具有高精度和高频率稳定性,非常适合用于蓝牙、无线通信设备、数字无绳电话、个人数字助理和手机等设备,有助于降低电磁干扰(EMI)。 - 引脚分配:文档中提供了晶体的顶视图和侧视图,显示了引脚分配,但未提供具体的引脚功能描述。 - 参数特性: - 频率范围:10~64MHz - 频率容差(25°C时):±30ppm或指定 - 工作温度范围内的频率稳定性:±30ppm或指定 - 工作温度范围:-10°C至+70°C或指定 - 并联电容(Co):最大3pF - 驱动电平:1至200mW(典型100mW) - 负载电容:10pF或指定 - 老化(25°C时):最大±3ppm/年 - 存储温度范围:-40°C至+85°C - 等效串联电阻(ESR):不同频率下的ESR值有所不同,10-16MHz为最大100,16-20MHz为最大80,20-64MHz为最大60。 - 封装信息:尺寸为3.20±0.1mm x 2.5mm x 0.7mm,文档中还提供了建议的布局图。
7M-48.000MAHV-T 价格&库存
很抱歉,暂时无法提供与“7M-48.000MAHV-T”相匹配的价格&库存,您可以联系我们找货
7M-48.000MAHV-T
  • 3000+3.313593000+0.42523
  • 6000+3.176666000+0.40766
  • 9000+3.099229000+0.39772
  • 15000+3.0044015000+0.38555
  • 21000+2.9435821000+0.37775
  • 30000+2.8804630000+0.36965
库存:26019
7M-48.000MAHV-T
  • 1+5.371961+0.68938
  • 10+4.6898010+0.60184
  • 25+4.4357025+0.56923
  • 50+4.2521650+0.54568
  • 100+4.07683100+0.52318
  • 250+3.85553250+0.49478
  • 500+3.69582500+0.47428
  • 1000+3.542981000+0.45467
库存:26019
