7V-27.000MAHJ-T
7V-27.000MAHJ-T
    TXC(台晶)
    SMD-4
    陶瓷谐振器 27MHz ±30ppm ±30ppm SMD-4
7V-27.000MAHJ-T 数据手册
come visit our site http://www.txccorp.com SMD Glass Sealing Crystals 3.2 x 2.5 x 0.8 mm 7V Series Features .4 pads SMD glass sealed crystal. .Applications in wireless communication ,DSC and USB interface card. .Excellent heat resistance and environmental characteristics. Quartz Crystals Series Think of Frequency Think of 0 T26u01 M .Contain Pb in sealing glass exempted by RoHS directive. Item / Type 7V Frequency Range 9.9 ~ 54 MHz Frequency Tolerance (at 25 ℃) ± 30 ppm, or specify Frequency Stability Over Operating Temperature Range ± 30 ppm, or specify Operating Temperature Range -10 ~ +70 ℃, or specify Shunt Capacitance (C0) 3 pF Max. Drive Level 1 ~ 50 μW (10 μW typical) Load Capacitance 8 pF, 10 pF, or specify Aging (at 25 ℃) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications Equivalent Series Resistance(ESR) Fundamental 9.9 ~ 12 MHz 150 Ω Max. 12 ~ 16 MHz 100 Ω Max. 16 ~ 54 MHz 60 Ω Max. Dimensions Units: mm 15
7V-27.000MAHJ-T
1. 物料型号:7V系列 2. 器件简介:4个焊盘的SMD玻璃封装晶体,适用于无线通信、DSC和USB接口卡,具有出色的耐热性和环境特性。 3. 引脚分配:文档中未明确提供引脚分配图,但提到了4个焊盘。 4. 参数特性: - 频率范围:9.9-54MHz - 频率容差(25°C时):±30ppm或指定 - 工作温度范围内的频率稳定性:±30ppm或指定 - 工作温度范围:-10至+70°C或指定 - 并联电容(C0):最大3pF - 驱动水平:1-5W(典型10W) - 负载电容:8pF、10pF或指定 - 老化(25°C时):最大±3ppm/年 - 存储温度范围:-40至+85°C 5. 等效串联电阻(ESR): - 9.9-12MHz:最大150 - 12-16MHz:最大100 - 16-54MHz:最大60 6. 封装信息:尺寸为3.2 x 2.5 x 0.8 mm,文档中提供了顶视图、侧视图和底视图,以及建议的连接和布局。
7V-27.000MAHJ-T 价格&库存
很抱歉,暂时无法提供与“7V-27.000MAHJ-T”相匹配的价格&库存,您可以联系我们找货
7V-27.000MAHJ-T
  • 1+5.827601+0.75396
  • 10+5.0580610+0.65440
  • 25+4.7841825+0.61897
  • 50+4.5863050+0.59336
  • 100+4.39653100+0.56881
  • 250+4.15766250+0.53791
  • 500+3.98536500+0.51562
  • 1000+3.820561000+0.49429
库存:4259
7V-27.000MAHJ-T
  • 3000+3.318043000+0.42928
  • 6000+3.180926000+0.41154
  • 9000+3.103389000+0.40151
  • 15000+3.0084215000+0.38922
  • 21000+2.9475321000+0.38135
  • 30000+2.8843230000+0.37317
库存:4259
