9C-11.2896MEEJ-T
9C-11.2896MEEJ-T
    TXC(台晶)
    HC49S
    陶瓷谐振器 ±10ppm ±10ppm HC49S 11.2896MHz
9C-11.2896MEEJ-T 数据手册
Quartz Crystals SMD HC-49S 9C SERIES Features > Surface mount type crystal units. Quartz Crystals > A great number of standard frequencies. > High frequency pullability and low equivalent series resistance. > Highly mass production capability. > The best choice of PC, STB, LCDM, and Cable Modem. > RoHS Compliant / Pb Free. Electrical Specifications Item / Type 9C 3.2 ~ 90 MHz Frequency Range Frequency Tolerance (at 25 ºC) Frequency Stability Over Operating Temperature Range Operating Temperature Range ± 10 ppm, or specify ± 10 ppm (-20 ~ +70 ºC), or specify - 40 ~ + 85 ºC 7 pF Max. Shunt Capacitance (C0) 1 ~ 500 μW (100 μW typical) Drive Level 18 pF, or specify Load Capacitance ± 3 ppm / year Max. Aging (at 25 ºC) Storage Temperature Range - 55 ~ + 125 ºC Equivalent Series Resistance(ESR) Fundamental 3rd Overtone 3.2 ~ 3.686 MHz 200 Ω Max. 27 ~ 30 MHz 100 Ω Max. 3.686 ~ 5 MHz 150 Ω Max. 30 ~ 50 MHz 80 Ω Max. 5 ~ 10 MHz 80 Ω Max 50 ~ 90 MHz 60 Ω Max. 10 ~ 14 MHz 40 Ω Max. 14 ~ 30 MHz 30 Ω Max. Dimensions Units:mm Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com 04 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: TXC Corporation: 9C-10.000MEEJ-T 9C-11.0592MEEJ-T 9C-11.2896MEEJ-T 9C-12.000MEEJ-T 9C-12.288MEEJ-T 9C13.560MEEJ-T 9C-14.31818MEEJ-T 9C-14.7456MEEJ-T 9C-15.360MEEJ-T 9C-16.000MEEJ-T 9C-16.384MEEJ-T 9C-18.432MEEJ-T 9C-19.200MEEJ-T 9C-20.000MEEJ-T 9C-22.000MEEJ-T 9C-22.1184MEEJ-T 9C-24.000MEEJ-T 9C-24.576MEEJ-T 9C-25.000MEEJ-T 9C-26.000MEEJ-T 9C-27.000MEEJ-T 9C-28.63636MEEJ-T 9C30.000MEEJ-T 9C-35.328MEEJ-T 9C-36.000MEEJ-T 9C-48.000MEEJ-T 9C-50.000MEEJ-T 9C-8.000MEEJ-T 9C8.192MEEJ-T 9C-16.000MEEK-T 9C-37.500MEEE-T 9C-13.824MEEK-T 9C-27.000MDDI-T 9C-25.000MFIQ-T 9C26.000MDDI-T 9C-16.000MEIJ-T 9C-17.1776MFHK-T 9C-25.600MEEJ-T 9C-25.000MEEE-T 9C-3.579545MDHJ-T 9C-6.78881MEEK-T 9C-8.000MEEE-T
9C-11.2896MEEJ-T
PDF文档中包含以下信息: 1. 物料型号:型号为EL817。
2. 器件简介:EL817是一款光控继电器,由发光二极管和光敏三极管组成,用于检测光信号并控制电路的通断。
3. 引脚分配:EL817有5个引脚,包括发光二极管的正负极和光敏三极管的集电极、发射极和基极。
4. 参数特性:包括工作电压、工作电流、响应时间等。
5. 功能详解:EL817通过检测发光二极管发出的光信号来控制光敏三极管的导通和截止,实现电路的自动控制。
6. 应用信息:广泛应用于自动控制系统、安全报警系统等领域。
7. 封装信息:EL817采用DIP封装形式。
9C-11.2896MEEJ-T 价格&库存
很抱歉,暂时无法提供与“9C-11.2896MEEJ-T”相匹配的价格&库存,您可以联系我们找货
