7S-22.1184MAHE-T
7S-22.1184MAHE-T
    TXC(台晶)
    SMD-4
    陶瓷谐振器 ±30ppm ±30ppm 22.1184MHz SMD-4
7S-22.1184MAHE-T 数据手册
Think of Frequency Think of Quartz Crystals Series SMD Glass Sealing Crystals 2.5 x 2.0 x 0.75 mm 7S Series come visit our site http://www.txccorp.com Features 0 T24cTQ M .4 pads SMD glass sealed Crystal. .Applications for NB, DSC, USB, Variety of compact portable consumer products reference clocks. .High reliable environmental performance. .Contains Pb in sealing glass exempted by RoHS directive. Electrical Specifications Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type 7S Frequency Range 12 ~ 64 MHz Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 20 ppm, or specify Frequency Stability Over Operating Temperature Range ± 10 ppm, ± 20 ppm, or specify Operating Temperature Range -10 ~ + 70 ℃, or specify Shunt Capacitance (C0) 3 pF Max. Drive Level 1 ~ 50 μW ( 10 μW typical) Load Capacitance 8 pF, 10 pF, or specify Aging (at 25 ℃) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Equivalent Series Resistance(ESR) Fundamental 12 ~ 13 MHz 200 Ω Max. 20 ~ 27 MHz 80 Ω Max. 13 ~ 16 MHz 150 Ω Max. 27 ~ 64 MHz 60 Ω Max. 16 ~ 20 MHz 100 Ω Max. Dimensions Units: mm 14
7S-22.1184MAHE-T 价格&库存
很抱歉,暂时无法提供与“7S-22.1184MAHE-T”相匹配的价格&库存,您可以联系我们找货
