7A-30.000MAAK-T
7A-30.000MAAK-T
    TXC(台晶)
    SMD5032_2P
    陶瓷谐振器 30MHz ±30ppm ±30ppm SMD-2
7A-30.000MAAK-T 数据手册
Think of Frequency Think of Quartz Crystals Series SMD Glass Sealing Crystals 5.0 x 3.2 x 1.2 mm 7A Series come visit our site http://www.txccorp.com Features 4.3 1 TXC U 29 H .2 pads SMD glass sealed crystal units. .High reliable environmental performance. .Tight tolerance and stability parts are available. .Designed for automatic mounting and reflow soldering. .Reasonable cost and good delivery performance. .The best choice of portable PC, PDA, DSC, and USB interface card. .Contains Pb in sealing glass exempted by RoHS directive. Electrical Specifications Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type 7A Frequency Range 8 ~ 54 MHz Frequency Tolerance (at 25 ℃) ± 30 ppm, or specify Frequency Stability Over Operating Temperature Range ± 30 ppm, or specify Operating Temperature Range -10 ~ +70 ℃, or specify Shunt Capacitance (C0) 5 pF Max. Drive Level 1 ~ 200 μW (100 μW typical) Load Capacitance Series, 6 pF, 10 pF, 16 pF, 20 pF, or specify Aging (at 25 ℃) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Equivalent Series Resistance(ESR) Fundamental 8 ~ 12 MHz 80 Ω Max. 12 ~ 54 MHz 50 Ω Max. Dimensions Units: mm 16
7A-30.000MAAK-T
1. 物料型号:文档中没有明确指出具体的物料型号,但提到了“7A Series”,这可能是系列型号的一部分。
2. 器件简介:文档描述了一种SMD玻璃封装的石英晶体振荡器,具有高可靠性的环境性能,可提供紧密的公差和稳定性部件,设计用于自动贴装和回流焊接。
3. 引脚分配:文档中没有提供具体的引脚分配图,但提到了“2 pads SMD glass sealed crystal units”,意味着该器件有两个SMD焊盘。
4. 参数特性:文档列出了电气规格,包括频率范围(8-54MHz)、频率公差(±30ppm或指定)、频率稳定性(±30ppm或指定)、工作温度范围(-10 - +70°C或指定)、并联电容(最大5pF)、驱动电平(1-200 mW,典型100 mW)、负载电容(系列,6pF, 10pF, 16pF, 20pF或指定)、老化率(最大±3ppm/年)和存储温度范围(-40-+85°C)。
5. 功能详解:文档强调了器件的高可靠性和自动贴装设计,适用于便携式PC、PDA、DSC和USB接口卡等应用。
6. 应用信息:文档提到该器件是便携式PC、PDA、DSC和USB接口卡的最佳选择。
7. 封装信息:文档提供了封装的尺寸信息,包括5.0 x 3.2 x 1.2 mm,并附有顶视图、侧视图和底视图的示意图。
7A-30.000MAAK-T 价格&库存
很抱歉,暂时无法提供与“7A-30.000MAAK-T”相匹配的价格&库存,您可以联系我们找货
7A-30.000MAAK-T
  • 1000+3.139821000+0.40739
