AX-8.000MAMV-T
AX-8.000MAMV-T
    TXC(台晶)
    SMD-2
    陶瓷谐振器 8MHz ±30ppm SMD-2 ±100ppm
AX-8.000MAMV-T 数据手册
come visit our site http://www.txccorp.com SMD Glass Sealing Crystals 8.0 x 4.5 x 1.6 mm AX Series Features Automotive Application Series Think of Frequency Think of 1A w M 00 TXC 1 2 . 0 .Reliable glass sealed ceramic package. .Wide operating temperature range. .Superior and reliable performance in harsh environment. .Application : TPMS, ECM, ABS and sensor modules. .Contains Pb in sealing glass exempted by RoHS directive. Item / Type AX Frequency Range 6 ~ 40 MHz Overtone Fundamental Frequency Tolerance (at 25 ℃) ± 30 ppm, ± 50 ppm Max. Frequency Stability Over Operating Temperature Range ± 150 ppm Max. Operating Temperature Range - 40 ~ +150 ℃ Drive Level 10 μW (typical) ; 500 μW (Max.) Load Capacitance 12 pF, or specify Storage Temperature Range - 40 ~ +150 ℃ Reliability Standard AEC-Q200 Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications Equivalent Series Resistance(ESR) Fundamental 6 ~ 10 MHz 150 Ω Max. 10 ~ 12 MHz 100 Ω Max. 12 ~ 40 MHz 80 Ω Max. Dimensions Units: mm 29
AX-8.000MAMV-T 价格&库存
很抱歉,暂时无法提供与“AX-8.000MAMV-T”相匹配的价格&库存,您可以联系我们找货
