AS1911Z-T
AS1911Z-T
    AMSOSRAM(艾迈斯半导体)
    SOT23-6
    IC SUPERVISOR ACT HIGH SOT23-6
AS1911Z-T 数据手册
AS1910 - AS1915 D u a l - Vo l ta g e M i c r o p r o c e s s o r S u p e r v i s o r y C i r c u i ts w i t h M a n u a l R e s e t a n d Wa t c h d o g D a ta S he e t 1 General Description The AS1910 - AS1915 microprocessor supervisory circuits were designed to generate a reset when one of the two monitored supply voltages falls below a factorytrimmed threshold, and to maintain the reset for a minimum timeout period when both supplies are above their reset thresholds. Guaranteed to be in the correct state for VCC higher than +1.0V, these devices are ideal for multiple-voltage systems with strict monitoring requirements. The AS1913/AS1914/AS1915 feature factory-trimmed thresholds to monitor a primary voltage between 1.8 and 3.6V, and a secondary voltage between 0.9 and 2.5V. For the AS1910/AS1911/AS1912, a secondary monitoring voltage can be user-adjusted via an external resistor divider down to 0.6V. The devices are available with the reset output types listed in Table 1. Table 1. Standard Products Model AS1910/AS1913 AS1911/AS1914 AS1912/AS1915 Reset Output Type Active-Low Push/Pull Active-High Push/Pull Active-Low Open-Drain 2 Key Features ! ! Primary VCC Supervisory Range: +1.8 to +3.6V Secondary VCC Supervisory Range: +0.9 to +2.5V (AS1913/AS1914/AS1915) User-Adjustable Threshold Down to +0.63V (AS1910/AS1911/AS1912) Guaranteed Reset Valid Down to VCC = +1.0V Reset Timeout Delay: 215ms Manual Reset Input Three Reset Output Types - Active-High Push/Pull - Active-Low Push/Pull - Active-Low Open-Drain Watchdog Timeout Period: 1.5s Immune to Fast Negative VCC Transients External Components Not Required Operating Temperature Range: -40 to +125°C 6-pin SOT23 Package ! ! ! ! ! ! ! ! ! ! The AS1910 - AS1915 include a manual-reset input for systems that never fully power down the microprocessor. Additionally, these devices feature a watchdog timer to help ensure that the processor is operating within proper code boundaries. The AS1910 - AS1915 are available in a 6-pin SOT23 package. Figure 1. Typical Application Diagram 3 Applications The devices are ideal for portable and battery-powered systems, embedded controllers, intelligent instruments, automotive systems, critical CPU monitoring, and any multi-supply application. VCC 6 I/O Supply Core Supply VCC 5 VCC2 VCC2 3 External Reset MRN AS1913/ AS1915 1 RESETN 4 WDI I/O RESETN CPU GND GND 2 www.austriamicrosystems.com Revision 1.00 1 - 15 AS1910 - AS1915 Data Sheet - P i n o u t 4 Pinout Pin Assignments Figure 2. Pin Assignments (Top View) RESETN/RESET 1 6 VCC GND 2 AS1910 AS1915 5 RESETIN/VCC2 MRN 3 4 WDI Pin Descriptions Table 2. Pin Descriptions Pin Number Pin Name Description 1 Active-Low Reset Output (AS1910, AS1912, AS1913, AS1915). The RESETN signal toggles from high to low when VCC, VCC2, or RESETIN input drops below the factory-trimmed RESETN reset threshold (see Table 4 on page 4), or MRN is pulled low, or the watchdog triggers a reset. This output signal remains low for the reset timeout period after all supervised voltages exceed their reset threshold, or MRN goes low to high, or the watchdog triggers a reset. Active-High Reset Output (AS1911, AS1914). The RESET signal toggles from low to high when VCC, VCC2, or RESETIN input drops below the factory-trimmed reset threshold (see Table 4 on page 4), or MRN is pulled low, or the watchdog triggers a reset. This output signal remains high for the reset timeout period (see tRP on page 5) after all supervised voltages exceed their reset threshold, or MRN goes low to high, or the watchdog triggers a reset. Ground Active-Low Manual Reset Input. Pulling this pin low asserts a reset. This pin is connected to the internal 50kΩ pullup to VCC. This reset remains active as long as MRN is low and for the reset timeout period (see tRP on page 5) after MRN goes high. Note: If the manual reset feature is not used, this pin should be unconnected or connected to VCC. Watchdog Input. If WDI remains high or low for longer than the watchdog timeout period (see tWD on page 6), the internal watchdog timer period expires and a reset is triggered for the reset timeout period (see tRP on page 5). The internal watchdog timer clears whenever a reset is a asserted or when WDI senses a rising or falling edge. Note: To disable the watchdog feature, this pin must be unconnected or connected to a tristate buffer output. RESET 2 GND 3 MRN 4 WDI 5 User-Adjustable Supervised Voltage Input (AS1910/AS1911/AS1912). This highRESETIN impedance pin serves as the input to the internal reset comparator. Connect this pin to an external resistor-divider network to set the reset threshold voltage (down to 0.63V). VCC2 Primary Supervised Voltage Input (AS1913/AS1914/AS1915). This pin serves as the secondary supervised voltage input. Primary Supervised Voltage Input. This pin serves as the primary supervised voltage input. 6 VCC www.austriamicrosystems.com Revision 1.00 2 - 15 AS1910 - AS1915 Data Sheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 3 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Section 5 Electrical Characteristics on page 3 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 3. Absolute Maximum Ratings Parameter VCC, VCC2 to GND Open-Drain RESETN Push/Pull RESET, RESETN MRN, WDI, RESETIN to GND Input Current (VCC) Output Current (RESET, RESETN) Continuous Power Dissipation (TAMB = +70ºC) Operating Temperature Range Junction Temperature Storage Temperature Range -65 -40 Min -0.3 -0.3 -0.3 -0.3 Max +5.0 +7.0 VCC + 0.3 VCC + 0.3 20 20 696 +125 +150 +150 Units V V V V mA mA mW ºC ºC ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020C “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). Derate 8.7mW/ºC above +70ºC Comments Package Body Temperature +260 ºC www.austriamicrosystems.com Revision 1.00 3 - 15 AS1910 - AS1915 Data Sheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics VCC = +2.7 to +3.6V for AS19xx-T/S/R, VCC = +2.1 to +2.75V for AS19xx- Z/Y, VCC = +1.53 to +2.0V for AS19xx-W/V; TAMB = -40 to +125ºC (unless otherwise specified). Typ values @ TAMB = +25°C. Table 4. Electrical Characteristics Symbol VCC Parameter 1 Conditions TAMB = 0 to +85ºC TAMB = -40 to +125ºC VCC = +3.6V, No Load, TAMB = -40ºC to +85ºC VCC = +3.6V, No Load, TAMB = -40 to +125ºC VCC2 = +2.5V TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC AS19xx-T AS19xx-S AS19xx-R AS19xx-Z AS19xx-Y AS19xx-W AS19xx-V AS19xx-Z AS19xx-Y AS19xx-W AS19xx-V AS19xx-I AS19xx-H AS19xx-G AS19xx-F AS19xx-E AS19xx-D Min 1.0 1.2 Typ Max 3.6 3.6 Units V Operating Voltage Range ICC ICC2 VCC Supply Current (MRN and WDI Not Connected) VCC2 Supply Current 5.8 13 µA 21 2 µA 2.994 2.972 2.848 2.827 2.556 2.538 2.255 2.239 2.129 2.113 1.623 1.612 1.536 1.525 2.232 2.111 1.607 1.520 1.339 1.267 1.073 1.071 1.015 1.013 0.804 0.760 3.08 2.93 2.63 2.32 2.19 1.67 1.58 3.154 3.179 3.000 3.024 2.693 2.714 2.376 2.394 2.243 2.260 1.710 1.723 1.618 1.631 2.394 2.265 1.723 1.630 1.437 1.359 V VTH VCC Reset Threshold (VCC Falling) TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC TAMB = -40 to +85ºC TAMB = -40 to +125ºC 2.237 2.313 2.387 2.116 2.188 2.258 1.610 1.665 1.718 1.523 1.575 1.625 1.342 1.388 1.432 1.270 1.313 1.355 1.11 1.05 1.146 1.149 1.084 1.087 0.862 0.816 V VTH2 VCC2 Reset Threshold 0.806 0.833 0.860 0.762 0.788 0.813 www.austriamicrosystems.com Revision 1.00 4 - 15 AS1910 - AS1915 Data Sheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 4. Electrical Characteristics (Continued) Symbol Parameter 1 Conditions Min Typ 60 8x VTH Max Units ppm/ ºC mV V mV Reset Threshold Temperature Coefficient Reset Threshold Hysteresis VRESETINTH RESETIN Threshold RESETIN Hysteresis IRESETIN tRD RESETIN Input Current VCC to Reset Output Delay RESETIN to Reset Output Delay tRP Reset Timeout Period 2 VRESETINTH Falling, TAMB = 0 to +85ºC TAMB = -40 to +125ºC 0.615 0.630 0.645 0.61 8x VTH 0.65 TAMB = -40 to +85ºC TAMB = -40 to +125ºC VCC = VTH to (VTH - 100mV) VRESETIN = VRESETINTH to (VRESETINTH - 30mV) TAMB = -40 to +85ºC TAMB = -40 to +125ºC VCC ≥ 1.0V, ISINK = 50µA, Reset Asserted, TAMB = 0 to +85ºC -25 -100 55 45 140 100 215 +25 +100 nA µs µs 280 320 0.3 0.3 ms VOL RESETN Output Low (Push/Pull or Open-Drain) VCC ≥ 1.2V, ISINK = 100µA, Reset Asserted VCC ≥ 2.55V, ISINK = 1.2mA, Reset Asserted VCC ≥ 3.3V, ISINK = 3.2mA, Reset Asserted VCC ≥ 1.8V, ISOURCE = 200µA, Reset Not Asserted 0.8 x VCC 0.8 x VCC 0.8 x VCC V 0.3 0.4 VOH RESETN Output High (Push/Pull Only) VCC ≥ 3.15V, ISOURCE = 500µA, Reset Not Asserted VCC ≥ 3.3V, ISOURCE = 800µA, Reset Not Asserted V ILKG Open-Drain RESETN Output Leakage Current RESETN Not Asserted TAMB = +25ºC VCC ≥ 1.0V, ISOURCE = 1µA, Reset Asserted, TAMB = 0 to +85ºC 0.8 x VCC 0.8 x VCC 0.8 x VCC 0.8 x VCC 1.0 0.2 µA VOH RESET Output High (Push/Pull Only) VCC ≥ 1.50V, ISOURCE = 100µA, Reset Asserted VCC ≥ 2.55V, ISOURCE = 500µA, Reset Asserted VCC ≥ 3.3V, ISOURCE = 800µA, Reset Asserted VCC ≥ 1.8V, ISINK = 500µA, Reset Asserted V 0.3 0.3 0.4 V VOL RESET Output Low (Push/Pull Only) VCC ≥ 3.15V, ISINK = 1.2mA, Reset Asserted VCC ≥ 3.3V, ISINK = 3.2mA, Reset Asserted Manual Reset Input VIL MRN Input voltage VIH 0.7 x VCC 0.3 x VCC V www.austriamicrosystems.com Revision 1.00 5 - 15 AS1910 - AS1915 Data Sheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 4. Electrical Characteristics (Continued) Symbol Parameter 1 Conditions Min 1 Typ 90 130 Max Units µs ns ns MRN Minimum Input Pulse MRN Transient Rejection MRN to Reset Delay MRN Pullup Resistance Watchdog Input tWD tWDI VIL WDI Input Voltage VIH IWDI WDI Input Current WDI = VCC, Time Average WDI = 0, Time Average Watchdog Timeout Period WDI Pulse Width 2 25 TAMB = -40 to +85ºC TAMB = -40 to +125ºC 1.12 0.80 20 50 1.5 75 2.4 2.60 kΩ s ns 0.3 x VCC 0.7 x VCC 80 -20 -11 160 V µA 1. Over-temperature limits are guaranteed by design and not production tested. Devices tested at +25ºC. 2. Guaranteed by design and not production tested. www.austriamicrosystems.com Revision 1.00 6 - 15 AS1910 - AS1915 Data Sheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7 Typical Operating Characteristics TAMB = +25ºC (unless otherwise specified). Figure 3. Normalized Reset Threshold Delay vs. Temperature 1.06 1.04 1.02 1 0.98 0.96 0.94 -40 -20 0 20 40 60 80 100 120 Figure 4. VOUT vs. VCC; VCC2 = 2.50V, VTH = 1.58V, Active-Low (Typ) 5.50 5.00 4.50 4.00 3.50 3.00 2.50 2.00 1.50 1.00 0.50 0.00 -0.50 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 Reset Threshold (V) e Output Voltage (V)e Temperature (°C) Figure 5. Reset Timeout Period vs. Temperature 250 VCC (V) Figure 6. Supply Current vs. Temperature 10 Reset Timeout Periode (ms) 240 230 220 210 200 190 180 170 160 150 -40 -20 0 20 40 60 80 100 120 VCC Supply Current (µA) e 9 8 7 6 5 4 3 -50 -25 0 25 50 75 100 125 VCC = 1.58V V Version VCC = 3.08V T Version Temperature (°C) Figure 7. VOH vs. ISOURCE; VCC = 3.2V 3.25 3.2 3.15 Temperature (°C) Figure 8. VOL vs. ISINK; VCC = 3.2V 0.5 0.45 0.4 0.35 VOUT (V) ] VOUT (V) e 0 0.2 0.4 0.6 0.8 1 1.2 3.1 3.05 3 2.95 2.9 0.3 0.25 0.2 0.15 0.1 0.05 0 0 1 2 3 4 5 6 7 ISOURCE (mA) ISINK (mA) www.austriamicrosystems.com Revision 1.00 7 - 15 AS1910 - AS1915 Data Sheet - D e t a i l e d D e s c r i p t i o n 8 Detailed Description The AS1910 - AS1915 supervisory circuits were designed to generate a reset when one of the two monitored supply voltages falls below its factory-trimmed trip threshold (see VTH on page 4 and VTH2 on page 4), and to maintain the reset for a minimum timeout period (see tRP on page 5) after all supplies have stabilized. The integrated watchdog timer (see Watchdog Input on page 10) helps mitigate against bad programming code or clock signals, and/or poor peripheral response. An active-low manual reset input (see Manual Reset Input on page 10) allows for an externally activated system reset. RESET/RESETN Whenever one of the monitored voltages falls below its reset threshold, the RESET output (AS1910, AS1912, AS1913, AS1915) asserts low or the RESETN output (AS1911, AS1914) asserts high. Once all monitored voltages have stabilized, an internal timer keeps the reset asserted for the reset timeout period (tRP). After the tRP period, the RESET or RESETN output return to their original state (see Figure 10). Figure 9. Functional Diagram of VCC Supervisory Application 6 VCC AS1913/AS1914/AS1915 Reset Timeout Delay Generator 1 RESETN/ RESET + – 0.63V 1.26V 5 VCC2 VCC 3 MRN 4 WDI Watchdog Transition Detector Watchdog Timer 2 GND Figure 10. Reset Timing Diagram VCC 1V VTH VTH 1V RESETN tRP tRD RESET GND tRP tRD www.austriamicrosystems.com Revision 1.00 8 - 15 AS1910 - AS1915 Data Sheet - D e t a i l e d D e s c r i p t i o n Figure 11. Functional Diagram of RESETIN Supervisory Application 6 VCC AS1910/AS1911/AS1912 Reset Timeout Delay Generator 1 RESETN/ RESET + – 0.63V 5 RESETIN 3 MRN 1.26V VCC 4 WDI Watchdog Transition Detector Watchdog Timer 2 GND RESETIN The AS1910/AS1911/AS1912 feature a user-adjustable supervisory voltage input (RESETIN). The threshold voltage for RESETIN is between 0.61 and 0.65V (0.63 typ). Figure 12. Voltage Monitoring Circuit VMONITOR R1 5 R2 RESETIN AS1910/ AS1911/ AS1912 VCC ≥ VRESETIN To monitor a voltage higher than 0.63V, connect a resistor divider network to the circuit as shown in Figure 12. For the circuit shown in Figure 12, the threshold at VMONITOR is: VMONITOR_TRIP = 0.63V [(R1 + R2)/R2] Note: Since RESETIN is powered by VCC, VRESETIN must not be larger than VCC. (EQ 1) www.austriamicrosystems.com Revision 1.00 9 - 15 AS1910 - AS1915 Data Sheet - D e t a i l e d D e s c r i p t i o n Watchdog Input The integrated watchdog feature can be used to monitor processor activity via pin WDI, and can detect pulses as short as 50ns. The watchdog requires that the processor toggle the watchdog logic input at regular intervals, within a specified minimum timeout period (1.5s, typ). A reset is asserted for the reset timeout period. As long as reset is asserted, the timer remains cleared and is not incremented. When reset is deasserted, the watchdog timer starts counting (Figure 11). Note: The watchdog timer can be cleared with a reset pulse or by toggling WDI. Figure 13. Watchdog Timing Relationship VCC tRST RESETN tRP tWD tRP WDI The RESET signal is the inverse of the RESETN signal. The watchdog is internally driven low during most (87.5%) of the watchdog timeout period (see tWD on page 6) and high for the rest of the watchdog timeout period. When pin WDI is left unconnected, this internal driver clears the watchdog timer every 1.4s. When WDI is tri-stated or is not connected, the maximum allowable leakage current is 10µA and the maximum allowable load capacitance is 200pF. Note: The watchdog function can be disabled by leaving pin WDI unconnected or connecting it to a tri-state output buffer. Manual Reset Input The active-low pin MRN is used to force a manual reset. This input can be driven by CMOS logic levels or with opendrain collector outputs. Pulling MRN low asserts a reset which will remain asserted as long as MRN is kept low, and for the timeout period (see tRP on page 5) after MRN goes high (140ms min). The manual reset circuitry has an internal 50kΩ pullup resistor, thus it can be left open if not used. To create a manual-reset circuit, connect a normally open momentary switch from pin MRN to GND (see Figure 1 on page 1); external debounce circuitry is not required in this configuration. If MRN is driven via long cables or the device is used in a noisy environment, a 0.1µF capacitor between pin MRN and GND will provide additional noise immunity. www.austriamicrosystems.com Revision 1.00 10 - 15 AS1910 - AS1915 Data Sheet - A p p l i c a t i o n I n f o r m a t i o n 9 Application Information Watchdog Input Current The watchdog input is driven through an internal buffer and an internal series resistor from the watchdog timer (see Figure 11 on page 9). When pin WDI is left unconnected (watchdog disabled), the watchdog timer is serviced within the watchdog timeout period (see tWD on page 6) by a low-high-low pulse from the counter chain. For minimum watchdog input current (minimum overall power consumption), pull WDI low for most of the watchdog timeout period, pulsing it low-high-low once within the first 7/8 (87.5%) of the watchdog timeout period to reset the watchdog timer. Note: If WDI is externally driven high for the majority of the timeout period, up to 160µA can flow into pin WDI. Interfacing to Bi-Directional CPU Reset Pins Since the reset outputs of the AS1912 and AS1915 are open drain, these devices interface easily with processors that have bi-directional reset pins. Connecting the processor reset output directly to the AS1912/AS1915 RESETN pin with a single pullup resistor (see Figure 14) allows the AS1912/AS1912 to assert a reset. Figure 14. AS1912 or AS1915 RESETN-to-CPU Bi-Directional Reset Pin VCC VCC 6 VCC CPU RESETN 1 RESETN AS1912/ AS1915 Reset Generator GND GND 2 Fast Negative-Going Transients Fast, negative-going VCC transients normally do not require the CPU to be shutdown. The AS1910 - AS1915 are virtually immune to such transients. Resets are issued to the CPU during power-up, powerdown, and brownout conditions. Note: VCC transients that go 100mV below the reset threshold and last ≤ 55µs typically will not assert a reset pulse. Valid Reset to VCC = 0 The AS1910 - AS1915 are guaranteed to operate properly down to VCC = 1V. For applications requiring valid reset levels down to VCC = 0, a pulldown resistor to active-low outputs (push/pull only) and a pullup resistor to active-high outputs (push/pull only) will ensure that the reset line is valid during the interval where the reset output can no longer sink or source current. Watchdog Tips Careful consideration should be taken when implementing the AS1910 - AS1915 watchdog feature. One method of supervising software code execution is to set/reset the watchdog input at different places in the code, rather than pulsing the watchdog input high-low-high or low-high-low. This method avoids a loop condition in which the watchdog timer would continue to be reset inside the loop, preventing the watchdog from ever timing out. Figure 15 shows a flowchart where the input/output driving the watchdog is set high at the beginning of the routine, set low at the beginning of every subroutine, then set high again when the routine returns to the beginning. If the routine should hang in a subroutine, the problem would quickly be corrected, since the I/O is continually set low and the watchdog timer is allowed to time out, causing a reset or interrupt to be issued (see Watchdog Input Current on page 11). This method results in higher averaged WDI input current over time than a case where WDI is held low for the majority (87.5%) of the timeout period and periodically pulsing it low-high-low. www.austriamicrosystems.com Revision 1.00 11 - 15 AS1910 - AS1915 Data Sheet - A p p l i c a t i o n I n f o r m a t i o n Figure 15. Example Watchdog Programming Flowchart Start Set WDI High Program Code Subroutine or Program Loop Set WDI Low Return www.austriamicrosystems.com Revision 1.00 12 - 15 AS1910 - AS1915 Data Sheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 10 Package Drawings and Markings The devices are available in a 6-pin SOT23 package. Figure 16. 6-pin SOT23 Package Notes: 1. 2. 3. 4. 5. 6. All dimensions are in millimeters. Foot length measured at intercept point between datum A and lead surface. Package outline inclusive of mold flash 7 metal burr. Package outline inclusive of solder plating. Compliant with EIAJ SC74A. PKG ST 0004 Rev A supersedes SOT23-D-2005 Rev C. Symbol A A1 A2 b C D E E1 L e e1 α Min 0.90 0.00 0.90 0.30 0.09 2.80 2.60 1.50 0.30 Max 1.45 0.15 1.30 0.50 0.20 3.05 3.00 1.75 0.55 0.95REF 1.90REF 0º 8º www.austriamicrosystems.com Revision 1.00 13 - 15 AS1910 - AS1915 Data Sheet - O r d e r i n g I n f o r m a t i o n 11 Ordering Information The devices are available as the standard products shown in Table 5. Table 5. Ordering Information Model Marking Reset Output Type Thresholds Delivery Form Package AS1910S-T AS1910R-T AS1910Z-T AS1910V-T AS1911S-T AS1911R-T AS1911Z-T AS1911V-T AS1912S-T AS1912R-T AS1912Z-T AS1912V-T AS1913TZ-T AS1913SF-T AS1913VD-T AS1914TZ-T AS1914SF-T AS1914VD-T AS1915TZ-T AS1915SF-T AS1915VD-T ASH3 ASH4 ASH5 ASH6 ASH7 ASH8 ASH9 ASIA ASIB ASIC ASID ASIE ASIF ASIG ASIH ASII ASIJ ASIK ASIL ASIM ASIN Active-Low Push/Pull Active-Low Push/Pull Active-Low Push/Pull Active-Low Push/Pull Active High Push/Pull Active High Push/Pull Active High Push/Pull Active High Push/Pull Open Drain Open Drain Open Drain Open Drain Active-Low Push/Pull Active-Low Push/Pull Active-Low Push/Pull Active High Push/Pull Active High Push/Pull Active High Push/Pull Open-Drain Open-Drain Open-Drain 2.93V, Adjustable 2.63V, Adjustable 2.32V, Adjustable 1.58V, Adjustable 2.93V, Adjustable 2.63V, Adjustable 2.32V, Adjustable 1.58V, Adjustable 2.93V, Adjustable 2.63V, Adjustable 2.32V, Adjustable 1.58V, Adjustable 3.08V, 2.313V 2.93V,1.05V 1.58V, 0.788V 3.08V, 2.313V 2.93V,1.05V 1.58V, 0.788V 3.08V, 2.313V 2.93V,1.05V 1.58V, 0.788V Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 6-pin SOT23 www.austriamicrosystems.com Revision 1.00 14 - 15 AS1910 - AS1915 Data Sheet Copyrights Copyright © 1997-2007, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information Headquarters austriamicrosystems AG A-8141 Schloss Premstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com Revision 1.00 15 - 15
AS1911Z-T 价格&库存
很抱歉,暂时无法提供与“AS1911Z-T”相匹配的价格&库存,您可以联系我们找货
