AV-22.5792MDHV-T
AV-22.5792MDHV-T
    TXC(台晶)
    SMD-4
    陶瓷谐振器 ±20ppm ±30ppm 22.5792MHz SMD-4
AV-22.5792MDHV-T 数据手册
come visit our site http://www.txccorp.com SMD Glass Sealing Crystals 3.2 x 2.5 x 0.8 mm AV Series Features .4 pads SMD glass sealed crystal. .Applications in wireless communication, DSC and USB interface card. .Excellent heat resistance and enviromental characteristics. Automotive Application Series Think of Frequency Think of 0 T26 07 Ks .Contain Pb in sealing glass exempted by RoHS directive. Item / Type AV Frequency Range 9.84 ~ 62.4 MHz Frequency Tolerance (at 25 ℃) ± 30 ppm, or specify Frequency Stability Over Operating Temperature Range ± 50 ppm Max. Operating Temperature Range - 40 ~ 125 ℃ Shunt Capacitance (C0) 3 pF Max. Drive Level 10 μW (typical) ; 100 μW (Max.) Load Capacitance 8 pF, 10 pF or specify Aging (at 25 ℃) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ 125 ℃ Raliability Standard AEC-Q200 Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications Equivalent Series Resistance(ESR) Fundamental 9.84 ~ 12 MHz 200 Ω Max. 12 ~ 20 MHz 120 Ω Max. 20 ~ 62.4 MHz 60 Ω Max. Dimensions Units: mm 27
AV-22.5792MDHV-T
1. 物料型号:SMD封装的玻璃密封晶体AV系列,尺寸为3.2 x 2.5 x 0.8 mm。 2. 器件简介:该系列晶体适用于汽车应用,具有4个SMD焊盘,适用于无线通信、DSC和USB接口卡。 3. 引脚分配:文档中未明确提供引脚分配图,但提到了4个SMD焊盘。 4. 参数特性: - 频率范围:9.84~62.4 MHz - 频率容差(25°C时):±30ppm或指定值 - 工作温度范围内的频率稳定性:最大±50ppm - 工作温度范围:-40~125°C - 并联电容(C0):最大3pF - 驱动电平:典型值10mW,最大值100mW - 负载电容:8pF或10pF,可指定 - 老化(25°C时):最大±3ppm/年 - 存储温度范围:-40~125°C - 可靠性标准:AEC-Q200 5. 功能详解:文档中未提供详细的功能解释,但提到了其在无线通信、DSC和USB接口卡中的应用。 6. 应用信息:适用于无线通信、DSC和USB接口卡。 7. 封装信息:3.2 x 2.5 x 0.8 mm的SMD封装,具有4个SMD焊盘,建议的连接和布局图示在文档中有所描述。
AV-22.5792MDHV-T 价格&库存
很抱歉,暂时无法提供与“AV-22.5792MDHV-T”相匹配的价格&库存,您可以联系我们找货
AV-22.5792MDHV-T
  • 3000+4.198873000+0.54315
  • 6000+4.025426000+0.52071
  • 9000+3.927349000+0.50803
  • 15000+3.8072615000+0.49249
  • 21000+3.7302321000+0.48253
库存:3000
AV-22.5792MDHV-T
  • 1+6.879801+0.88995
  • 10+5.9454310+0.76908
  • 25+5.6203225+0.72702
  • 50+5.3895050+0.69717
  • 100+5.16625100+0.66829
  • 250+4.88523250+0.63194
  • 500+4.68324500+0.60581
  • 1000+4.489441000+0.58074
库存:3000
