7B-19.200MEEQ-T
7B-19.200MEEQ-T
    TXC(台晶)
    SMD-4
    陶瓷谐振器 19.2MHz ±10ppm ±10ppm SMD-4
7B-19.200MEEQ-T 数据手册
come visit our site http://www.txccorp.com SMD Seam Sealing Crystals 5.0 x 3.2 x 0.9 mm 7B Series Quartz Crystals Series Think of Frequency Think of Features .High precision characteristics covering up to wide frequency range. .0 24 A C TX E Q O .Higher frequency stability and reliability. .Excellent for reducing EMI effect. .The best choice of Bluetooth, wireless communication set, DSC, PDA,mobile phone and USB interface card. .RoHS Compliant / Pb Free. Electrical Specifications Frequency Range 7B 7B(T) 8 ~ 125MHz Frequency Tolerance (at 25 ℃) ± 30 ppm, or specify ± 10 ppm Frequency Stability Over Operating Temperature Range ± 30 ppm, or specify ± 10 ppm Operating Temperature Range -10 ~ +70 ℃, or specify Shunt Capacitance (C0) 5 pF Max. (2 pF typical) Drive Level 1 ~ 200 μW (100 μW typical) Load Capacitance Aging (at 25 ℃) Storage Temperature Range 10 pF, 16 pF, 20 pF, or specify ± 3 ppm / year Max. 6 pF, 9 pF,10 pF,12 pF,16 pF ± 1 ppm / year Max. - 40 ~ + 85 ℃ Equivalent Series Resistance(ESR) Fundamental 3rd Overtone 8 ~ 11 MHz 80 Ω Max. 40 ~ 60 MHz 120 Ω Max. 12 ~ 54 MHz 40 Ω Max. 60 ~ 125 MHz 80 Ω Max. Dimensions Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type Units: mm 7
7B-19.200MEEQ-T
1. 物料型号:7B系列石英晶体振荡器。 2. 器件简介:该系列晶体振荡器具有高精度特性,覆盖广泛的频率范围,具有高频率稳定性和可靠性,非常适合减少电磁干扰(EMI),是蓝牙、无线通信设备、数字无绳电话、个人数字助理、手机和USB接口卡的最佳选择。符合RoHS标准,无铅。 3. 引脚分配:文档中提供了晶体振荡器的顶视图和侧视图,展示了引脚分配和接地(GND)标记。 4. 参数特性:包括频率范围、频率容差、频率稳定性、工作温度范围、并联电容、驱动水平、负载电容、老化率和存储温度范围。 5. 功能详解:文档中提到了基本频率和第三倍频的等效串联电阻(ESR)的最大值。 6. 应用信息:适用于蓝牙、无线通信设备、数字无绳电话、个人数字助理、手机和USB接口卡。 7. 封装信息:晶体振荡器的尺寸为5.0 x 3.2 x 0.9 mm。
7B-19.200MEEQ-T 价格&库存
很抱歉,暂时无法提供与“7B-19.200MEEQ-T”相匹配的价格&库存,您可以联系我们找货
7B-19.200MEEQ-T
  • 1+8.830401+1.13268
  • 10+7.6825610+0.98545
  • 25+7.2654925+0.93195
  • 50+6.9650250+0.89341
  • 100+6.67726100+0.85650
  • 250+6.31488250+0.81001
库存:398
7B-19.200MEEQ-T
  • 1000+5.350981000+0.68637
库存:398
