8Z-20.000MEEQ-T
8Z-20.000MEEQ-T
    TXC(台晶)
    SMD-4
    陶瓷谐振器 20MHz ±10ppm ±10ppm SMD-4
8Z-20.000MEEQ-T 数据手册
Think of Frequency Think of Quartz Crystals Series SMD Seam Sealing Crystals 2.5 x 2.0 x 0.55 mm 8Z Series come visit our site http://www.txccorp.com Features 80 T4 u01 M .High precision and high frequency stability. .Excellent heat resistance and environmental characteristics. .Applications in PDA, DSC, DVC, and PC. .RoHS Compliant / Pb Free. Electrical Specifications Item / Type 8Z Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Frequency Range 12 ~ 66 MHz Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 30 ppm, or specify Frequency Stability Over Operating Temperature Range ± 10 ppm, ± 30 ppm, or specify Operating Temperature Range -10 ~ +70 ℃, or specify Shunt Capacitance (C0) 3 pF Max. Drive Level 1 ~200 μW Max. (100uW typical) Load Capacitance 8 pF, 10 pF, 12 pF, or specify Aging (at 25 ℃) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Equivalent Series Resistance(ESR) Fundamental 12 ~ 13 MHz 150 Ω Max. 14 ~ 30 MHz 100 Ω Max. 30 ~ 66 MHz 60 Ω Max. Dimensions Units: mm 4
8Z-20.000MEEQ-T
1. 物料型号:文档中没有明确列出物料型号,但提到了“8Z Series”和“Mu01”型号。 2. 器件简介:文档介绍了SMD密封晶体振荡器,具有高精度和高频率稳定性,优秀的热稳定性和环境特性,适用于PDA、DSC、DVC和PC,符合RoHS标准,无铅。 3. 引脚分配:文档中提到了GND和01000.2ND XES0连接,但没有提供完整的引脚分配图。 4. 参数特性:包括频率范围、频率容差、频率稳定性、工作温度范围、等效串联电阻(ESR)、并联电容、驱动电平、负载电容、老化率和存储温度范围。 5. 功能详解:文档提供了晶体振荡器的电气规格,但未提供详细的功能解释。 6. 应用信息:适用于PDA、DSC、DVC和PC。 7. 封装信息:尺寸为2.5 x 2.0 x 0.55 mm。
8Z-20.000MEEQ-T 价格&库存
很抱歉,暂时无法提供与“8Z-20.000MEEQ-T”相匹配的价格&库存,您可以联系我们找货
8Z-20.000MEEQ-T
    • 10+7.5527410+0.97793
    • 25+7.4344125+0.96261
    • 100+7.31608100+0.94729
    • 250+7.19775250+0.93196
    • 500+5.33679500+0.69101
    • 1000+5.247591000+0.67946
    库存:1907
    8Z-20.000MEEQ-T
    • 1+7.539571+0.97622
    • 10+7.4232610+0.96116
    • 25+7.3069625+0.94611
    • 100+7.19066100+0.93105
    • 250+7.07436250+0.91599
    • 500+5.24530500+0.67916
    • 1000+5.157631000+0.66781
    库存:1907
