RE3-25V101MF3#
RE3-25V101MF3#
    ELNAAMERICA
RE3-25V101MF3# 数据手册
RE3 RE3 MINIATURE CAPACITORS MINIATUREALUMINUM ALUMINUMELECTROLYTIC ELECTROLYTIC CAPACITORS Standard Capacitors ● GREEN CAP ® ® Anticleaning solvent 250V Max. Guarantees 2000 hours at 85℃. RJ4 High temperature RE3 Marking color : White print on a blue sleeve Specifications Item Performance Category temperature range (℃) ー40 to +85 Tolerance at rated capacitance (%) ±20 Leakage current (µA) (20℃,120Hz) Rated voltage (V) 6.3 to 100 160 to 450 Leakage current (µA) Less than 0.03CV or 4 whichever is larger (after 1 minute) Less than 0.01CV or 3 whichever is larger (after 2 minutes) CV≦1000 : Less than 0.1CV+40 (after 1 minute) CV>1000 : Less than 0.04CV+100 (after 1 minute) (20℃) C : Rated capacitance (µF) V: Rated voltage (V) Tangent of loss angle (tanδ) Rated voltage (V) 6.3 10 16 25 35 50 63 100 160 200 250 315 350 400 450 tanδ (max.) 0.28 0.24 0.20 0.16 0.14 0.12 0.10 0.08 0.20 0.20 0.20 0.24 0.24 0.24 0.24 (20℃,120Hz) 0.02 is added to every 1000µF increase over 1000µF. Rated voltage (V) Characteristics at high and low temperature Impedance Z−25℃/Z+20℃ ratio Z−40℃/Z+20℃ (max.) 6.3 10 16 25 35 50 63 100 160 200 250 315 350 400 5 4 3 2 2 2 2 2 4 4 4 4 4 4 450 4 12 10 8 5 4 3 3 3 15 15 15 10 10 10 10 (120Hz) The initial specified value or less Within ±20% of initial value Percentage of capacitance change 200% or less of the initial specified value Tangent of the loss angle Shelf life (85℃) Test time : 1000 hours ; other items are the same as those for the endurance. Voltage application treatment : According to JIS C5101 -1 Applicable standards JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985) Outline Drawing Unit : mm Coefficient of Frequency for Rated Ripple Current Rated voltage (V) Sleeve Vent (except φ5) φd±0.05 copper clad steel wire (tinned) Frequency (Hz) CV (µF×WV) All CV value ≦1000 1000< ≦1000 1000< All CV value 6.3 to 16 25 to 35 F±0.5 φD+0.5max. MINIATURE ALUMINUM 2000 hours Test time Leakage current Endurance (85℃) (Applied ripple current) L+α max. φD F φd α 5 2.0 0.5 6.3 2.5 0.5 2.0 15min. 8 3.5 0.6 1.5 10 5.0 0.6 2.0 50 to 100 160 to 450 5 min. 12.5 5.0 0.6 50・60 120 1k 10k 100k 0.8 0.8 0.8 0.8 0.8 0.8 1 1 1 1 1 1 1.1 1.5 1.2 1.6 1.2 1.3 1.2 1.7 1.3 1.9 1.3 1.5 1.2 1.7 1.3 1.9 1.3 1.6 Part numbering system (example : 16V1000µF) 16 7.5 0.8 2.5 18 7.5 0.8 RE3 Series code ̶ 16 Rated voltage symbol V 102 M Rated capacitance Capacitance symbol tolerance symbol ̶ H4 # Casing symbol Optional symbol Taping(Forming) symbol Casing symbol Casing Casing Size Size φD×L (mm) Symbol φD×L (mm) Symbol 12.5×25 Ⅰ6 5×11 E3 16×25 J6 6.3×11 F3 16×31.5 J7 8×11.5 G3 16×35.5 J8 10×12.5 H3 18×31.5 K7 10×16 H4 18×35.5 K8 10×20 H5 18×40 K9 12.5×20 Ⅰ5 CAT.No.2015/2016E 96 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. RE3 RE3 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS ® ® Standard Ratings Rated voltage (V) 6.3 Item Case Rated capacitance (µF) ESR φD×L (mm) (Ω) 1 ̶ ̶ 2.2 ̶ 3.3 4.7 10 Rated ripple current Case ESR (mArms) φD×L (mm) (Ω) ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 10 ̶ 22 16 Rated ripple current Case ESR (mArms) φD×L (mm) (Ω) ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 33.2 ̶ ̶ ̶ ̶ ̶ ̶ 5×11 15.1 33 ̶ ̶ ̶ ̶ ̶ 5×11 47 ̶ ̶ ̶ 5×11 8.5 99 5×11 100 ̶ ̶ ̶ 5×11 3.8 146 ̶ 25 Rated ripple current Case ESR (mArms) φD×L (mm) (Ω) ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 35 Rated ripple current Case ESR 50 Rated ripple current Case (mArms) φD×L (mm) φD×L (mm) (Ω) (mArms) ̶ ̶ ̶ ̶ 5×11 ̶ ̶ ̶ ̶ ̶ 5×11 ̶ ̶ ̶ ̶ ̶ ESR 63 Rated ripple current Case ESR 100 Rated ripple current Case Rated ripple current (Ω) (mArms) (Ω) (mArms) 21 ̶ ̶ ̶ 5×11 90.5 31 ̶ ̶ ̶ 5×11 60.3 30 5×11 60.3 38 ̶ ̶ ̶ 5×11 40.2 40 45 (Ω) 199 (mArms) φD×L (mm) ESR φD×L (mm) 133 21 5×11 56.5 38 5×11 49.4 40 5×11 42.3 45 5×11 35.3 45 5×11 28.2 50 5×11 26.5 55 5×11 23.2 59 5×11 19.9 66 5×11 16.6 66 6.3×11 13.3 75 75 5×11 12.1 82 5×11 10.6 87 5×11 9.1 98 5×11 7.5 100 6.3×11 6.0 130 10.1 92 5×11 8.0 100 5×11 7.0 107 5×11 6.0 126 6.3×11 5.0 140 8×11.5 4.0 180 7.1 110 5×11 5.7 118 5×11 4.9 130 6.3×11 4.2 155 6.3×11 3.5 170 10×12.5 2.8 230 5×11 3.3 160 6.3×11 2.7 199 6.3×11 2.3 214 8×11.5 2.0 260 10×12.5 1.7 300 10×20 1.3 370 6.3×11 1.5 264 8×11.5 1.2 349 10×12.5 1.1 443 10×12.5 0.91 443 10×16 0.75 470 12.5×20 0.60 620 220 5×11 2.1 200 6.3×11 1.8 240 330 6.3×11 1.4 270 6.3×11 1.2 290 8×11.5 1.0 383 10×12.5 0.81 510 10×12.5 0.70 542 10×16 0.60 595 10×20 0.50 710 12.5×25 0.40 760 470 6.3×11 0.99 322 8×11.5 0.85 417 8×11.5 0.71 457 10×12.5 0.57 545 10×16 0.49 664 12.5×20 0.42 887 12.5×20 0.35 900 16×25 0.28 1000 10×12.5 0.40 791 0.13 1380 0.47 546 10×16 0.33 10×20 0.27 996 12.5×20 0.23 1210 12.5×25 0.20 1400 16×25 0.17 1300 18×40 2200 10×20 0.23 1010 10×20 0.20 1080 12.5×20 0.17 1350 12.5×25 0.14 1660 16×25 0.12 1950 16×35.5 0.11 2340 ̶ ̶ ̶ ̶ ̶ ̶ 3300 10×20 0.16 1230 12.5×20 0.14 1430 12.5×25 0.12 1690 16×25 0.10 2030 16×35.5 0.090 2510 18×35.5 0.080 2810 ̶ ̶ ̶ ̶ ̶ ̶ 4700 12.5×20 0.12 1710 12.5×25 0.11 1780 16×25 0.092 2100 16×31.5 0.078 2650 18×35.5 0.071 2990 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 6800 12.5×25 0.093 1930 16×25 0.083 2200 16×35.5 0.073 2580 18×35.5 0.063 3290 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 10000 16×25 0.076 2450 16×35.5 0.070 2700 18×35.5 0.063 3130 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 15000 16×35.5 0.062 2860 18×35.5 0.058 3100 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 22000 18×40 0.053 3340 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ESR Rated ripple current Case ESR Case ESR ESR ESR ESR ESR (mArms) (Ω) (mArms) (Ω) (mArms) (Ω) (mArms) (Ω) (mArms) (Ω) (mArms) φD×L (mm) Rated ripple current (Ω) φD×L (mm) Rated ripple current Case φD×L (mm) Rated ripple current Case φD×L (mm) Rated ripple current Case φD×L (mm) Rated ripple current Case φD×L (mm) Rated ripple current (Ω) (mArms) 1000 8×11.5 Rated voltage (V) 160 φD×L (mm) 200 250 315 350 400 450 0.47 6.3×11 706 15 6.3×11 706 15 6.3×11 706 15 6.3×11 847 15 6.3×11 847 15 6.3×11 847 15 8×11.5 847 18 1 6.3×11 332 22 6.3×11 332 22 6.3×11 332 22 6.3×11 398 22 6.3×11 398 22 6.3×11 398 22 8×11.5 398 25 2.2 6.3×11 151 32 6.3×11 151 32 6.3×11 151 32 8×11.5 181 38 8×11.5 181 38 8×11.5 181 38 10×12.5 181 43 3.3 6.3×11 101 40 6.3×11 101 40 8×11.5 101 48 10×12.5 121 53 10×12.5 121 53 10×12.5 121 54 10×16 121 59 4.7 6.3×11 8×11.5 70.6 56 10×12.5 84.7 65 10×12.5 84.7 65 10×16 84.7 71 10×20 84.7 76 12.5×20 39.8 123 10 8×11.5 70.6 48 8×11.5 70.6 56 33.2 81 10×12.5 33.2 94 10×16 33.2 101 10×20 39.8 115 10×20 39.8 115 12.5×20 39.8 123 22 10×16 15.1 151 10×20 15.1 170 12.5×20 15.1 182 12.5×20 18.1 182 12.5×25 18.1 197 12.5×25 18.1 197 16×25 18.1 226 33 10×20 10.1 202 12.5×20 10.1 223 12.5×25 10.1 243 16×25 12.1 277 16×25 12.1 277 16×25 12.1 277 16×31.5 12.1 304 47 12.5×20 7.06 266 12.5×25 7.06 265 12.5×25 7.06 295 16×25 8.47 330 16×25 8.47 330 16×31.5 8.47 361 16×35.5 100 12.5×25 3.32 422 16×25 3.32 483 3.32 528 18×31.5 3.98 567 18×31.5 3.98 567 ̶ ̶ ̶ 18×35.5 1.51 882 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 220 16×31.5 1.51 783 330 18×35.5 1.01 1080 ̶ 16×31.5 8.47 380 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ (Note) Rated ripple current : 85℃, 120Hz ; ESR. : 20℃, 120Hz NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 97 CAT.No.2015/2016E MINIATURE ALUMINUM Item Case Rated capacitance (µF) 650
RE3-25V101MF3#
物料型号:文档中提到了多种型号,例如6.3x11、8x11.5、10x12.5等,这些型号与电容器的尺寸有关。
器件简介:文档描述的是小型铝电解电容器,它们具有不同的额定电压、电容值和尺寸。
引脚分配:文档中没有明确提到引脚分配,但通常电解电容器有正负两个引脚。
参数特性:文档列出了电容器的多种参数,包括额定电压、电容值、电容公差、漏电流、损耗角的正切值等。
功能详解:文档中没有提供电容器的具体功能详解,但通常电解电容器用于平滑电源线电压、储存能量等。
应用信息:文档建议在设计前获取ELNA的技术规格,以确保组件适合使用。
封装信息:文档提供了不同尺寸的电容器的封装信息,如φD×L (mm)。
RE3-25V101MF3# 价格&库存
很抱歉,暂时无法提供与“RE3-25V101MF3#”相匹配的价格&库存,您可以联系我们找货
