RVS-35V220MF55U-R
RVS-35V220MF55U-R
    ELNAAMERICA
    CAP 22UF 35V SMD
RVS-35V220MF55U-R 数据手册
RVS RVS VERTICAL TYPE ELECTROLYTIC VERTICALCHIP CHIP TYPEALUMINUM ALUMINUM ELECTROLYTICCAPACITORS CAPACITORS GREEN CAP Chip Type 105°C Standard Capacitors ● ● ● Compatible with surface mounting. Supplied with carrier taping. Guarantees 1000 hours at 105° C. SMD 105˚C 1000hours ® ® Anticleaning solvent RVS High temperature RV2 Marking color : Black print Specifications Item Performance ー55 to +105 ±20 Less than 0.01CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V) Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) 6.3 0.30 10 0.26 16 0.22 25 0.16 (20℃,120Hz) (20℃) 35 0.13 50 0.12 (20℃,120Hz) Rated voltage (V) Zー25℃/Z+20℃ Zー40℃/Z+20℃ CHIP ALUMINUM Characteristics at high and low temperature Impedance ratio (max.) 6.3 4 8 10 3 5 16 2 4 25 2 3 35 2 3 50 2 3 (120Hz) 1000 hours The initial specified value or less Within ±20% of initial value 200% or less of the initial specified value Test time Leakage current Percentage of capacitance change Tangent of the loss angle Endurance (105℃) (Applied ripple current) Shelf life (105℃) Test time : 1000 hours; other items are the same as those for the endurance. Voltage application treatment : According to JIS C5101-1 Applicable standards JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993) Outline Drawing Unit : mm Frequency (Hz) Rated voltage (V) (C) (P) B±0.2 φD±0.5 ( ) : Reference size 4 5 6.3 6.3 8 8 10 10 ● ● ● L A B C 5.3±0.2 5.3±0.2 5.3±0.2 7.7±0.3 6.5±0.3 10±0.5 10±0.5 10.5±0.5 4.3 5.3 6.6 6.6 8.4 8.4 10.4 10.4 4.3 5.3 6.6 6.6 8.4 8.4 10.4 10.4 2.0 2.3 2.7 2.7 3.4 3.0 3.3 3.3 W 0.5 0.5 0.5 0.5 0.5 0.7 0.7 0.7 to to to to to to to to 0.8 0.8 0.8 0.8 0.8 1.1 1.1 1.1 P Casing symbol 1.0 1.5 2.0 2.0 2.3 3.1 4.7 4.7 D55 E55 F55 F80 G68 G10 H10 HA5 50・60 120 1k 10k・100k 0.80 0.80 0.80 1 1 1 1.15 1.25 1.35 1.25 1.40 1.50 Part numbering system (example : 16V47µF) RVS W L φD 6.3 to 16 25 to 35 50 (C) A±0.2 0.4±0.2 0.3MAX Coefficient of Frequency for Rated Ripple Current Series code ̶ 16 Rated voltage symbol V 470 M Rated capacitance Capacitance symbol tolerance symbol F55 Casing symbol U̶ Taping symbol Soldering conditions are described on page 13. Land pattern size are described on page 11. The taping specifications are described on page 14. CAT.No.2015/2016E 58 NOTE : ‌Design, Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. VERTICAL CHIP TYPE ALUMINUM ELECTROLYTIC CAPACITORS ® Standard Ratings 6.3 Rated voltage (V) Item Rated capacitance (µF) Case ESR 10 Rated ripple current Case (Ω) 16 Rated ripple current Case (mArms) φD×L(mm) ESR (Ω) 25 Rated ripple current Case Case Case Rated ripple current (Ω) (mArms) — — — — — — — — — — — — — 4×5.3 905 3 0.33 — — — — — — — — — — — — — — — 4×5.3 603 4 0.47 — — — — — — — — — — — — — — — 4×5.3 424 5 1 — — — — — — — — — — — — — — — 4×5.3 199 7 2.2 — — — — — — — — — — — — — — — 4×5.3 91 10 3.3 — — — — — — — — — — — — — 4×5.3 60 12 4.7 — — — — — — — — — 4×5.3 57 12 4×5.3 46 14 5×5.3 42 17 — — — 4×5.3 43 15 16 5×5.3 27 21 5×5.3 22 23 6.3×5.3 20 26 12 36 6.3×5.3 10 50 22 4×5.3 23 21 5×5.3 20 25 5×5.3 17 28 6.3×5.3 33 5×5.3 15 30 5×5.3 13 31 6.3×5.3 11 40 6.3×5.3 8.0 44 47 5×5.3 11 36 6.3×5.3 9.2 43 6.3×5.3 7.8 47 8×6.5 5.6 66 100 6.3×5.3 61 6.3×5.3 4.3 60 6.3×5.3 3.6 60 6.3×7.7 2.7 91 6.3×7.7 150 — 5.0 8×6.5 — (mArms) φD×L(mm) ESR — — (Ω) 50 Rated ripple current (Ω) 36 (mArms) φD×L(mm) ESR — — (Ω) 35 Rated ripple current φD×L(mm) 4×5.3 (mArms) φD×L(mm) ESR 0.22 10 (mArms) φD×L(mm) ESR RVS 8×6.5 9.0 51 6.5 59 6.3×7.7 6.0 60 — — 6.3×7.7 4.2 63 2.2 84 8×10 2.0 140 180 — — — — 6.3×7.7 2.4 105 8×10 1.8 140 8×10 1.4 155 10×10 1.3 102 6.3×7.7 2.0 105 6.3×7.7 1.7 105 8×10 1.2 155 8×10 0.98 190 10×10.5 0.91 220 6.3×7.7 1.5 105 8×10 1.3 195 8×10 1.1 195 8×10 0.80 190 10×10.5 0.65 300 — — — 8×10 1.1 210 8×10 0.92 210 8×10 0.78 230 10×10 0.57 300 — — — — — — 680 8×10 0.73 210 10×10 0.63 310 10×10 0.54 310 — — — — — — — — — 1000 8×10 0.50 210 10×10 0.43 310 — — — — — — — — — — — — 1500 10×10 0.33 310 — — — — — — — — — — — — — — 8×6.5 330 470 — (Note) Rated ripple current : 105℃ , 120Hz ; ESR : 20℃ , 120Hz NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 59 CAT.No.2015/2016E CHIP ALUMINUM — 2.3 220
RVS-35V220MF55U-R 价格&库存
很抱歉,暂时无法提供与“RVS-35V220MF55U-R”相匹配的价格&库存,您可以联系我们找货
