RVS
RVS
VERTICAL
TYPE
ELECTROLYTIC
VERTICALCHIP
CHIP
TYPEALUMINUM
ALUMINUM
ELECTROLYTICCAPACITORS
CAPACITORS
GREEN
CAP
Chip Type 105°C Standard Capacitors
Compatible with surface mounting.
Supplied with carrier taping.
Guarantees 1000 hours at 105°
C.
SMD
105˚C
1000hours
Anticleaning
solvent
RVS
High temperature
RV2
Marking color : Black print
Specifications
Item
Performance
ー55 to +105
±20
Less than 0.01CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V)
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
6.3
0.30
10
0.26
16
0.22
25
0.16
(20℃,120Hz)
(20℃)
35
0.13
50
0.12
(20℃,120Hz)
Rated voltage (V)
Zー25℃/Z+20℃
Zー40℃/Z+20℃
CHIP
ALUMINUM
Characteristics at high
and low temperature
Impedance ratio (max.)
6.3
4
8
10
3
5
16
2
4
25
2
3
35
2
3
50
2
3
(120Hz)
1000 hours
The initial specified value or less
Within ±20% of initial value
200% or less of the initial specified value
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
Endurance (105℃)
(Applied ripple current)
Shelf life (105℃)
Test time : 1000 hours; other items are the same as those for the endurance. Voltage application treatment : According to JIS C5101-1
Applicable standards
JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993)
Outline Drawing
Unit : mm
Frequency (Hz)
Rated voltage (V)
(C)
(P)
B±0.2
φD±0.5
( ) : Reference size
4
5
6.3
6.3
8
8
10
10
L
A
B
C
5.3±0.2
5.3±0.2
5.3±0.2
7.7±0.3
6.5±0.3
10±0.5
10±0.5
10.5±0.5
4.3
5.3
6.6
6.6
8.4
8.4
10.4
10.4
4.3
5.3
6.6
6.6
8.4
8.4
10.4
10.4
2.0
2.3
2.7
2.7
3.4
3.0
3.3
3.3
W
0.5
0.5
0.5
0.5
0.5
0.7
0.7
0.7
to
to
to
to
to
to
to
to
0.8
0.8
0.8
0.8
0.8
1.1
1.1
1.1
P
Casing
symbol
1.0
1.5
2.0
2.0
2.3
3.1
4.7
4.7
D55
E55
F55
F80
G68
G10
H10
HA5
50・60
120
1k
10k・100k
0.80
0.80
0.80
1
1
1
1.15
1.25
1.35
1.25
1.40
1.50
Part numbering system (example : 16V47µF)
RVS
W
L
φD
6.3 to 16
25 to 35
50
(C)
A±0.2
0.4±0.2
0.3MAX
Coefficient of Frequency for Rated Ripple Current
Series code
16
Rated voltage
symbol
V
470
M
Rated capacitance Capacitance
symbol
tolerance symbol
F55
Casing
symbol
U̶
Taping
symbol
Soldering conditions are described on page 13.
Land pattern size are described on page 11.
The taping specifications are described on page 14.
CAT.No.2015/2016E
58
NOTE : Design, Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
VERTICAL CHIP TYPE ALUMINUM ELECTROLYTIC CAPACITORS
Standard Ratings
6.3
Rated voltage (V)
Item
Rated
capacitance
(µF)
Case
ESR
10
Rated ripple
current
Case
(Ω)
16
Rated ripple
current
Case
(mArms) φD×L(mm)
ESR
(Ω)
25
Rated ripple
current
Case
Case
Case
Rated ripple
current
(Ω)
(mArms)
4×5.3
905
3
0.33
4×5.3
603
4
0.47
4×5.3
424
5
1
4×5.3
199
7
2.2
4×5.3
91
10
3.3
4×5.3
60
12
4.7
4×5.3
57
12
4×5.3
46
14
5×5.3
42
17
4×5.3
43
15
16
5×5.3
27
21
5×5.3
22
23 6.3×5.3
12
36 6.3×5.3
10
50
22
4×5.3
23
21
5×5.3
5×5.3
17
28
6.3×5.3
33
5×5.3
15
30
5×5.3
13
31
6.3×5.3
11
40
6.3×5.3
8.0
44
47
5×5.3
11
36
6.3×5.3
9.2
43
6.3×5.3
7.8
47
8×6.5
5.6
66
100
6.3×5.3
61
6.3×5.3
4.3
60
6.3×5.3
3.6
60
6.3×7.7
2.7
91 6.3×7.7
150
5.0
8×6.5
(mArms) φD×L(mm)
ESR
(Ω)
50
Rated ripple
current
(Ω)
36
(mArms) φD×L(mm)
ESR
(Ω)
35
Rated ripple
current
φD×L(mm)
4×5.3
(mArms) φD×L(mm)
ESR
0.22
10
(mArms) φD×L(mm)
ESR
RVS
8×6.5
9.0
51
6.5
59 6.3×7.7
6.0
60
6.3×7.7
4.2
63
2.2
84
8×10
2.0
140
180
6.3×7.7
2.4
105
8×10
1.8
140
8×10
1.4
155
10×10
1.3
102
6.3×7.7
2.0
105
6.3×7.7
1.7
105
8×10
1.2
155
8×10
0.98
190
10×10.5
0.91 220
6.3×7.7
1.5
105
8×10
1.3
195
8×10
1.1
195
8×10
0.80
190
10×10.5
0.65
300
8×10
1.1
210
8×10
0.92
210
8×10
0.78
230
10×10
0.57
300
680
8×10
0.73
210
10×10
0.63
310
10×10
0.54
310
1000
8×10
0.50
210
10×10
0.43
310
1500
10×10
0.33
310
8×6.5
330
470
(Note) Rated ripple current : 105℃ , 120Hz ; ESR : 20℃ , 120Hz
NOTE : Design,
59
CAT.No.2015/2016E
CHIP
ALUMINUM
2.3
220
很抱歉,暂时无法提供与“RVS-6V101MF55U-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.307811+0.40231
- 10+2.1976310+0.26729
- 50+1.6191850+0.19693
- 100+1.31868100+0.16039
- 500+1.04141500+0.12666
- 国内价格 香港价格
- 1000+0.687191000+0.08358
- 2000+0.651042000+0.07919
- 5000+0.614875000+0.07479
- 10000+0.5787110000+0.07039
- 25000+0.5425425000+0.06599
- 50000+0.5063750000+0.06159
- 100000+0.47020100000+0.05719
