RTK-35V151MH11U-R2
RTK-35V151MH11U-R2
    ELNAAMERICA
    CAP 150UF 35V SMD
RTK-35V151MH11U-R2 数据手册
RTK Chip Type 125°C Capacitors ● ● ● ●   ●   RTK VERTICAL CHIP TYPE ALUMINUM CAPACITORSCAPACITORS VERTICAL CHIP TYPEELECTROLYTIC ALUMINUM ELECTROLYTIC ® 125˚C Vibration SMD 105˚C Resistance 1250hours 5000hours Compatible with surface mounting. For Vibration resistance. Supplied with carrier taping. Guarantees 1250 hours at 125℃. (φ8 : 1000 hours) Guarantees 5000 hours at 105℃. (φ8 : 4000 hours) ® Anticleaning solvent RTK Vibration resistance Marking color : Gold print on a brown sleeve RVK Specifications Item Performance −40 to +125 ±20 Less than 0.02CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V) Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) 10 0.28 16 0.26 25 0.24 35 0.20 (20℃,120Hz) (20℃) 50 0.19 63 0.18 (20℃,120Hz) Rated voltage (V) Z−25℃/Z+20℃ Z−40℃/Z+20℃ CHIP ALUMINUM Characteristics at high and low temperature 10 3 5 Impedance ratio (max.) 16 3 5 25 3 5 35 3 5 50 3 5 63 3 5 (120Hz) 105℃ 125℃ φ8 : 1000h, φ10 : 1250h φ8 : 4000h, φ10 : 5000h The initial specified value or less Within ±30% of initial value 300% or less of the initial specified value Test temp. Test time Leakage current Percentage of capacitance change Tangent of the loss angle Endurance (Applied ripple current) 125℃ 500 h Test temp. Test time Leakage current Percentage of capacitance change Tangent of the loss angle Shelf life The initial specified value or less Within ±20% of initial value 200% or less of the initial specified value JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993) Applicable standards Outline Drawing Coefficient of Frequency for Rated Ripple Current Unit : mm Frequency (Hz) Rated voltage (V) 0.4±0.2 0.3MAX 10 to 63 (P1) RTK (C) W2 B±0.2 φD±0.5 ● 1k 10k 100k 0.88 0.96 1 ̶ 16 V Rated voltage symbol Series code 221 M H11 U ̶ Rated capacitance Capacitance symbol tolerance symbol Casing symbol Taping symbol (W3) W1 (P2) ● 120 0.77 Part numbering system (example : 16V220µF) (C) A±0.2 L ● 105℃ 1000h ( ) : Reference size φD L A B C W1 W2 W3 P1 P2 Casing symbol 8 10±0.5 8.4 8.4 3.0 0.7 to 1.1 1.5±0.2 2.0 3.1 4.4 G10 10 10.5±0.5 10.4 10.4 3.3 0.7 to 1.1 1.5±0.2 3.0 4.7 4.4 H11 Soldering conditions are described on page 13. Land pattern size are described on page 11. The taping specifications are described on page 14. Standard Ratings Rated voltage (V) Item Rated capacitance (µF) 10 Case φD×L (mm) ESR 16 Impedance Rated ripple current Case φD×L (mArms) (mm) ( Ω ) (Ω max.) ESR 25 Impedance Rated ripple current Case φD×L (mArms) (mm) ( Ω ) (Ω max.) ESR 35 Impedance Rated ripple current Case φD×L (mArms) (mm) ( Ω ) (Ω max.) ESR 50 Impedance Rated ripple current Case φD×L (mArms) (mm) ( Ω ) (Ω max.) 10 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 22 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 33 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 47 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 8×10 10×10.5 7.1 7.1 0.68 0.58 65 70 8×10 10×10.5 8×10 10×10.5 8×10 10×10.5 8×10 10×10.5 ESR 63 Impedance Rated ripple current Case φD×L (mArms) (mm) ( Ω ) (Ω max.) 32 32 14 14 10 10 6.7 6.7 0.80 0.65 0.80 0.65 0.80 0.60 0.80 0.60 38 45 38 48 40 58 40 58 ESR Impedance Rated ripple current (mArms) ( Ω )(Ω max.) ̶ ̶ ̶ ̶ 8×10 10×10.5 14 14 1.00 0.67 33 48 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 100 ̶ ̶ ̶ ̶ 8×10 4.3 0.68 60 8×10 4.0 0.68 60 10×10.5 3.3 0.55 102 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 220 8×10 10×10.5 2.1 2.1 0.68 0.55 60 111 10×10.5 2.0 0.55 107 10×10.5 1.8 0.55 107 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 330 10×10.5 1.4 0.55 111 10×10.5 1.3 0.55 111 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ (Note) Rated ripple current : 125℃, 100kHz ; Impedance : 20℃, 100kHz ; ESR : 20℃, 120Hz CAT.No.2015/2016E 84 NOTE : ‌Design, Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use.
RTK-35V151MH11U-R2 价格&库存
很抱歉,暂时无法提供与“RTK-35V151MH11U-R2”相匹配的价格&库存,您可以联系我们找货
