37156B
37156B
    GREENLEECOMMUNICATIONS(格林利)
    ARBOR-HOLESAW1/2"SHANK3FLATS
37156B 数据手册
ARBOR-HLESAW 1/2" SHNK W/3FLTS BULK Arbors with Replacement High-Speed Steel Pilot Drill Bits Cat No: 37156B UPC No: 783310376262 Description • • • • • The best arbor in the industry ensures a solid connectionwithout any gaps or wobbling Arbors include replaceable, high-speed steel pilot drill Pilot drills have unique split-point tip design Use with Greenlee bimetal hole saws, recessed light holesaws and carbide-grit hole saws (carbide-tipped pilot drillsold separately) Can be used with Greenlee #901 or #904 bit extensions Specifications • • • • • • • Application : Use With Greenlee Bimetal Hole Saws, Recessed Light Hole Saws And Carbide Grit Hole Saws (Carbide-Tipped Pilot Drill Sold Separately), Can Be Used With Greenlee No 901 Or 904 Bit Extensions, 1-1/4 IN - 2.000 IN (31.800 - 50.800 MM) Hole Saws Material : High Speed Steel Pilot Drill Bit Minimum Chuck Size : 1/2 IN (12.700 MM) Package : Bulk Pack Shank Diameter : 7/16 IN (11.100 MM) Type : Hex Shank Weight : 0.500 LB (227.000 GM)
37156B 价格&库存
很抱歉,暂时无法提供与“37156B”相匹配的价格&库存,您可以联系我们找货
