RYK-35V221MG5TT-FL
RYK-35V221MG5TT-FL
    ELNAAMERICA
RYK-35V221MG5TT-FL 数据手册
RYK RYK HORIZONTAL CHIP TYPE ALUMINUM ELECTROLYTIC CAPACITORS HORIZONTAL CHIP TYPE ALUMINUM ELECTROLYTIC CAPACITORS Horizontal Type, 125°C Use, For Vibration Capacitors ● ● ● ● ● 125° C high temperature surface mount. Highly resistant to vibration. Available in horizontal configurations only. Supplied with carrier taping. Guarantees 1000 hours at 125° C. 125˚C Vibration SMD Resistance 1000hours ® ® Anticleaning solvent Horizontal type Large capacitance RYK RVK Marking color : White print on a black case Specifications Item Performance ー40 to +125 ±20 Less than 0.02CV (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V) Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) 6.3 0.30 10 0.28 16 0.26 25 0.24 (20℃,120Hz) (20℃) 35 0.20 50 0.19 63 0.18 (20℃,120Hz) Rated voltage (V) Characteristics at high Impedance ratio (max.) CHIP ALUMINUM and low temperature Zー25℃/Z+20℃ Zー40℃/Z+20℃ 6.3 3 5 10 3 5 16 3 5 25 3 5 35 3 5 50 3 5 63 3 5 (120Hz) Endurance (125℃) (Applied ripple current) Shelf life (125℃) Test time Leakage current Percentage of capacitance change Tangent of the loss angle 1000 hours The initial specified value or less Within ±30% of initial value 300% or less of the initial specified value Test time Leakage current Percentage of capacitance change Tangent of the loss angle 500 hours The initial specified value or less Within ±20% of initial value 200% or less of the initial specified value Pretreatment performed JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993) Applicable standards Outline Drawing Unit : mm H1 H0 H 0.1+0.2 −0 L L1 F W 0.1±0.05 6.5 0.1±0.05 6.5 F L0 ● Case size W L0 9.5×24 9.5±0.5 24±1 L1 L H F H1 H0 21±0.5 22±0.5 9.3±0.5 9.3±0.5 9.1±0.3 3.5±0.5 ● 10 Rated voltage symbol Series code V 561 Case size W L0 9.5×19 9.5±0.5 19±1 Land pattern size are described on page 12. M G5T T ̶ Rated capacitance Capacitance symbol tolerance symbol ● L1 L H H1 H0 F 16±0.5 17±0.5 9.3±0.5 9.3±0.5 9.1±0.3 3.5±0.5 The taping specifications are described on page 13. Coefficient of Frequency for Rated Ripple Current Part numbering system (example: 10V560µF) ̶ W L0 Soldering conditions are described on page 11. RYK H1 H0 10 2.0±0.5 L L1 2.0±0.5 0.1±0.05 Case Size : 9.5×19.0 ■ 6 terminals type : Casing symbol G4 1.5±0.3 0.1+0.2 −0 0.1±0.05 H 1.5±0.3 Case Size : 9.5×24.0 ■ 8 terminals type : Casing symbol G5T Casing symbol Frequency (Hz) Rated voltage (V) 10 to 63 FL Tray polarity symbol 120 1k 10k 100k 0.77 0.88 0.96 1 Standard Ratings 6.3 Rated voltage (V) Item Rated capacitance (µF) Case ripple Impedance Rated current Case 10 ripple Impedance Rated current Case 25 16 ripple Impedance Rated current Case 50 35 ripple Impedance Rated current Case ripple Impedance Rated current Case 63 ripple Impedance Rated current Case ripple Impedance Rated current W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) 56 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 9.5×19.0 0.52 204 82 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 9.5×19.0 0.49 210 9.5×24.0 0.37 272 100 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 9.5×19.0 0.40 232 9.5×24.0 0.35 279 ̶ ̶ ̶ 220 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 9.5×19.0 0.40 232 9.5×24.0 0.30 302 ̶ ̶ ̶ ̶ ̶ ̶ 270 ̶ ̶ ̶ ̶ ̶ ̶ 9.5×19.0 0.40 232 9.5×24.0 0.30 302 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 470 ̶ ̶ ̶ 9.5×19.0 0.40 232 9.5×24.0 0.30 302 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 560 9.5×19.0 0.40 232 9.5×24.0 0.30 302 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 820 9.5×24.0 0.30 302 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ (Note) Rated ripple current : 125℃, 100kHz ; Impedance : 20℃, 100kHz CAT.No.2015/2016E 88 NOTE : ‌Design, Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use.
RYK-35V221MG5TT-FL 价格&库存
很抱歉,暂时无法提供与“RYK-35V221MG5TT-FL”相匹配的价格&库存,您可以联系我们找货
