RJ4
RJ4
MINIATURE
ALUMINUM
ELECTROLYTIC
CAPACITORS
MINIATURE
ALUMINUM
ELECTROLYTIC
CAPACITORS
105°C Miniature Capacitors
GREEN
CAP
105˚C
2000hours
Anticleaning
solvent
250V Max.
Case size is one rank smaller than Series RJ3.
Guarantees 2000 hours at 105℃.
(φ5 to φ8 : 1000 hours)
Miniaturized
RJ4
RJ3
High temperature
Marking color : White print on a black sleeve
RE3
Specifications
Performance
Item
−55 to +105
Category temperature range (℃)
−40 to +105
6.3 to 100
Rated voltage (V)
160 to 450
±20
Tolerance at rated capacitance (%)
(20℃,120Hz)
CV ≦ 1000 : Less than 0.1CV+40 (after 1 minute)
CV > 1000 : Less than 0.04CV+100 (after 1 minute)
Less than 0.03CV or 4 whichever is larger (after 1 minute)
Less than 0.01CV or 3 whichever is larger (after 2 minutes)
Leakage current (µA)
C : Rated capacitance (µF) ; V : Rated voltage (V)
Rated voltage (V)
Tangent of loss angle
(tanδ)
tanδ(max.)
(20℃)
6.3
10
16
25
35
50
63
100
160
200
250
315
350
400
450
0.28
0.24
0.20
0.16
0.14
0.12
0.10
0.08
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.02 is added to every 1000µF increase over 1000µF.
Rated voltage (V)
Characteristics at high
and low temperature
Impedance Z−25℃/Z+20℃
ratio
(max.) Z−40℃/Z+20℃
(20℃,120Hz)
6.3
10
16
25
35
50
63
100
160 to 250
5
4
3
2
2
2
2
2
4
315 to 450
4
10
8
6
4
3
3
3
3
15
10
(120Hz)
Test time
2000 hours (φ5 to φ8 : 1000 hours)
The initial specified value or less
Percentage of capacitance change
Within ±20% of initial value
Tangent of the loss angle
Shelf life (105℃)
200% or less of the initial specified value
Test time : 1000 hours ; other items are the same as those for the endurance. Voltage application treatment
JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985)
Applicable standards
Outline Drawing
Unit : mm
Coefficient of Frequency for Rated Ripple Current
Rated voltage (V) Rated
Vent (except φ5)
Sleeve
F±0.5
15min.
160 to 450
5
min.
5
2.0
0.5
6.3
2.5
0.5
2.0
8
3.5
0.6
1.5
10
5.0
0.6
2.0
12.5
5.0
0.6
120
1k
10k
100k
0.8
0.8
0.8
0.8
0.8
1
1
1
1
1
1.5
1.2
1.2
1.1
1.3
1.7
1.3
1.2
1.1
1.4
2.0
1.4
1.3
1.1
1.6
Part numbering system (example : 16V2200µF)
RJ4
φD
F
φd
α
50・60
1 to 47
100 to 220
330 to 1000
2200 to 22000
1 to 330
6.3 to 100
L+α max.
Frequency (Hz)
capacitance (µF)
φd±0.05 copper clad steel wire (tinned)
φD+0.5max.
MINIATURE
ALUMINUM
Leakage current
Endurance (105℃)
(Applied ripple current)
16
7.5
0.8
2.5
18
7.5
0.8
Series code
16
Rated voltage
symbol
V
222
M
Rated capacitance
Capacitance
symbol
tolerance symbol
Ⅰ5 #
Casing
symbol
Optional
symbol
Taping(Forming)
symbol
Casing symbol
Size
φD×L (mm)
5×11
6.3×11
8×11.5
10×12.5
10×16
10×20
12.5×20
Size
Casing
Casing
Symbol φD×L (mm) Symbol
12.5×25
Ⅰ6
E3
16×25
J6
F3
16×31.5
J7
G3
16×35.5
J8
H3
18×31.5
K7
H4
18×35.5
K8
H5
18×40
K9
Ⅰ5
CAT.No.2015/2016E
102
NOTE : Design, Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
RJ4
RJ4
MINIATURE
ALUMINUMELECTROLYTIC
ELECTROLYTICCAPACITORS
CAPACITORS
MINIATURE
ALUMINUM
Standard Ratings
Rated voltage
(V)
6.3
Item Case
Rated
capacitance
(µF)
ESR
10
Rated
ripple
current
Case
(mArms) φD×L
(mm)
ESR
16
Rated
ripple
current
Case
ESR
Case
35
Rated
ripple
current
Case
50
Rated
ripple
current
Case
(Ω)
5×11
2.2
5×11
3.3
4.7
5×11
56.5
27
5×11
49.4
10
5×11
33.2
37
5×11
26.5
39
5×11
22
5×11
15.1
54
5×11
12.1
58
5×11
33
5×11
10.1
67
5×11
8.04
71
5×11
7.04
(Ω)
(mArms) φD×L
(mm)
ESR
1
(Ω)
(mArms) φD×L
(mm)
ESR
φD×L
(mm)
(Ω)
(mArms) φD×L
(mm)
25
Rated
ripple
current
(Ω)
(mArms) φD×L
(mm)
ESR
(Ω)
63
Rated
ripple
current
Case
(mArms) φD×L
(mm)
ESR
(Ω)
100
Rated
ripple
current
Case
(mArms) φD×L
(mm)
ESR
Rated
ripple
current
(Ω)
(mArms)
15
5×11
90.5
22
5×11
60.3
21
5×11
60.3
27
5×11
40.2
29
30
5×11
42.4
32
5×11
28.2
32
23.2
43
5×11
19.9
47
5×11
16.6
46
6.3×11
13.3
54
10.6
64
5×11
9.05
70
5×11
7.54
71
6.3×11
78
5×11
6.03
90
6.3×11
5.03
100
6.3×11
6.3×11
199
133
15
6.03
93
8×11.5
4.02
130
47
5×11
8.47
72
5×11
7.06
79
5×11
5.65
84
5×11
4.94
90
4.24
115
3.53
120
10×12.5
2.82
165
100
5×11
3.98
105
5×11
3.32
115
6.3×11
2.65
141
6.3×11
2.32
151
8×11.5
1.99
190
10×12.5
1.66
215
10×20
1.33
265
220
5×11
2.11
140
6.3×11
1.81
166
6.3×11
1.51
190
8×11.5
1.21
247
10×12.5
1.06
314
10×12.5
0.91
314
10×16
0.75
335
12.5×25
0.60
440
330
6.3×11
1.41
195
6.3×11
1.21
210
8×11.5
1.01
271
10×12.5
0.81
360
10×12.5
0.70
384
10×16
0.60
421
10×20
0.50
510
12.5×25
0.40
540
470
6.3×11
0.99
232
8×11.5
0.85
325
8×11.5
0.71
323
10×12.5
0.57
429
10×16
0.50
470 12.5×20
0.42
628 12.5×20
0.35
640
16×25
0.28
715
0.47
398
10×12.5
0.40
457
10×16
0.33
560
10×20
0.27
705
12.5×20
0.23
857 12.5×25
0.20
1000
16×25
0.17
930
18×40
0.13
985
961 12.5×25
0.14
1180
16×25
0.12
1380
16×35.5
0.11
1660
18×35.5
0.08
1990
1000
8×11.5
2200
10×20
0.23
720
10×20
0.20
761 12.5×20
0.17
3300
10×20
0.16
882
12.5×20
0.14
1010 12.5×25
0.12
1200
16×25
0.10
1440
16×35.5
0.09
1780
4700
12.5×20
0.12
1120
12.5×25
0.11
1250
16×25
0.09
1490
16×31.5
0.08
1880
18×35.5
0.07
2120
6800
12.5×25
0.09
1380
16×25
0.08
1570
16×35.5
0.07
1830
18×35.5
0.06
2330
10000
16×25
0.07
1750
16×35.5
0.07
1910
18×35.5
0.06
2220
15000
16×35.5
0.06
2040
18×35.5
0.06
2190
22000
18×40
0.05
2390
Rated
ripple
current
Case
Rated
ripple
current
Case
Rated
ripple
current
Case
Rated
ripple
current
Case
Rated
ripple
current
Case
Rated
ripple
current
Case
Rated voltage
(V)
160
ESR
200
ESR
250
ESR
315
ESR
350
ESR
400
ESR
450
ESR
Rated
ripple
current
(Ω)
(mArms)
Rated
capacitance
(µF)
φD×L
(mm)
0.47
6.3×11
706
11
6.3×11
706
11
6.3×11
706
11
6.3×11
847
11
6.3×11
847
11
6.3×11
847
11
8×11.5
847
13
1
6.3×11
332
16
6.3×11
332
16
6.3×11
332
16
6.3×11
398
16
6.3×11
398
16
6.3×11
398
16
8×11.5
398
18
2.2
6.3×11
151
23
6.3×11
151
23
6.3×11
151
23
8×11.5
181
27
8×11.5
181
27
8×11.5
181
27
10×12.5
181
31
3.3
6.3×11
101
28
6.3×11
101
28
8×11.5
101
34
10×12.5
121
38
10×12.5
121
38
10×12.5
121
38
10×16
121
42
4.7
6.3×11
8×11.5
70.6
40
10×12.5
84.7
45
10×12.5
84.7
45
10×16
84.7
50
10×20
84.7
(Ω)
φD×L
(mArms) (mm)
(Ω)
φD×L
(mArms) (mm)
(Ω)
φD×L
(mArms) (mm)
(Ω)
φD×L
(mArms) (mm)
(Ω)
φD×L
(mArms) (mm)
(Ω)
φD×L
(mArms) (mm)
70.6
34
8×11.5
70.6
40
33.2
58
10×12.5
33.2
66
10×16
33.2
74
10×20
39.8
79
10×20
39.8
79
12.5×20
39.8
87
12.5×20
39.8
87
10×16
15.1
107
10×20
15.1
120
12.5×20
15.1
130
12.5×20
18.1
129
12.5×25
18.1
140
12.5×25
18.1
140
16×25
18.1
160
33
10×20
10.1
143
12.5×20
10.1
160
12.5×25
10.1
12.1
12.1
12.1
196
16×31.5
12.1
215
47
12.5×20
7.06
188
12.5×20
7.06
188
12.5×25
256
16×35.5
100
12.5×25
3.32
299
16×25
3.32
342
18×35.5
1.51
624
10
22
8×11.5
220
16×31.5
1.51
554
330
18×35.5
1.01
764
16×31.5
54
172
16×25
196
16×25
196
16×25
7.06
205
16×25
8.47
234
16×25
8.47
234
16×31.5
3.32
374
18×31.5
3.98
401
18×31.5
3.98
401
8.47
8.47
269
(Note) Rated ripple current : 105℃, 120Hz ; ESR. : 20℃, 120Hz
NOTE : Design,
103
CAT.No.2015/2016E
MINIATURE
ALUMINUM
Item Case
很抱歉,暂时无法提供与“RJ4-450V220MJ6#”相匹配的价格&库存,您可以联系我们找货
