TDC600-2A
TDC600-2A
    EATON(伊顿)
TDC600-2A 数据手册
Effective June 2017 Supersedes June 2002 Technical Data 2081 TDC600 British plug top fuse fast-acting Dimension-mm 25.4mm +0.8 -0.4 Product features • • • • • • 1/4” x 1” fast-acting, high breaking capacity fuse. Ceramic tube - end caps: silver-plated copper. High breaking capacity 600 Vac Standards BS1362 UL recognized 6.3mm +0.2 -0.05 5.5mm + 0.8 Time-Current Curve Electrical Ratings (Part number and Amperes) 2A 600 Vac 10 A 100 TDC600-2A TDC600-10A Current Rated Voltage (V) Breaking Capacity Power Dissipation (W) 2A 600 200A,600V 10kA, 250V p.f. 0.7 - 0.8 1 Watt @ Rated Current 10A Limits for Pre-arcing Time 1.0 In. 1.6 In. 1.9 In. In MIN MIN MAX 2A, 10A 1000 hours 30 min. 30 min. Color Approvals Blue Asta, BSI 10 Time in Seconds Rated 1.0 0.10 0.010 1 10 100 1000 Current in Amperes Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2081 SB98107 June 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
TDC600-2A 价格&库存
很抱歉,暂时无法提供与“TDC600-2A”相匹配的价格&库存,您可以联系我们找货
TDC600-2A
  • 186+4.98150
  • 583+4.70340
库存:1910
