MAGNUM
Single & Double Row
Filtered Connectors
Top & Bottom Marking Strips
Double Row Terminal Blocks (TB100, TB200, TB300, TB345 SERIES)
TOP MARKER STRIPS
Top mounting marker strips are available in white (opaque)
plastic. Two cover clips are supplied with each marker
strip.
All top marker strips must be ordered separately. Consult
factory for special legends.
Example: 12 position cover, TB200, .032” x .312”, with no
legends . . . Part No. is X20312.
Base & Rail Mount
Connectors
Euro-MAG Series
PCB – Spring Clamp
Example: 12 position cover, TB200HB, .060” x .500”, with
no legends . . . Part No. is X23312HB.
Part Numbering System
Series
Top Marker Strip
Poles
133 - TB100 (.060 thk x .500w)
103 - TB100 (.032 thk x .312w)
233 - TB200 (.060 thk x .500w)
233TB - TB200HB (.060 thk x .500w)
203 - TB200 (.032 thk x .312w)
203HB - TB200HB (.032 thk x .312w)
333 - TB300 & TB345 (.060 thk x .500w)
303 - TB300 & TB345 (.032 thk x .380w)
02 to 36 (TB100)
02 to 30 (TB200/TB200HB)
02 to 24 (TB300/TB345)
X
Note: Marking Strips are not available on
TB400 Series.
Space for marking
two sides
Space for marking
one side
BOTTOM MARKER STRIPS;
Bottom mounting marker strips are made of black PVC,
.030” thick. Space is available to handle most marking situations. All marker strips must be ordered separately.
Power Distribution Blocks
To order, specify part number, required legends and (BF)
bottom forward, (BR) bottom reverse, (TF) top forward, or
(TR) top reverse. Consult factory for specials.
Example: 13 position strip, TB100 with no legends, space
for marking one side . . . Part No. is X10513.
Position for legends (one side, two sides) can be specified
standard. Standard legend height is .125”. Standard legends are 0-99 and A-Z. Special legends are available on
special order. Drawing(s) must be submitted to ensure
accuracy of part required.
TB200
TB200HB
TB300
TB345
TB400
1.13”
1.38”
1.37”
1.62”
1.62”
1.81”
1.58”
1.81”
1.58”
1.81”
N/A
N/A
Series
WIRE MANAGEMENT PRODUCTS
Dim. A
Dim. B
TB100
Bottom Marker Strip
Poles
Orientation
105
101
205
201
295
291
305
301
02 to 36 (TB100)
BF – bottom forward
BR – bottom reverse
TF – top forward
TR – top reverse
X
36
TB100 – marking one side
TB100 – marking both sides
TB200 – marking one side
TB200 – marking both sides
TB200HB – marking one side
TB200HB – marking both sides
TB300 & TB345 – marking one side
TB300 & TB345 – marking both sides
Note: Marking Strips are not available on TB400 Series.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
X10506BF X20512BF X20506BF X20504BF
很抱歉,暂时无法提供与“X20504BF”相匹配的价格&库存,您可以联系我们找货
