DZN-2R5D155H3T
DZN-2R5D155H3T
    ELNAAMERICA
    CAP SUPER 1.5F 2.5V RADIAL
DZN-2R5D155H3T 数据手册
UPGRADE DZN DZN ELECTRICDOUBLE DOUBLELAYER LAYERCAPACITORS CAPACITORS“DYNACAP” “DYNACAP” ELECTRIC High Power Type Capacitors ● ● ● GREEN CAP 70˚C Low ESR ® ® 2.5V 2.7V Low internal resistance allows boosting charge and heavy-current discharge. (ampere level) Pollution-Free ; with no pollutants such as Cd or Pb. High power Unlike batteries, excellent charge and discharge characteristics with no chemical DZN DZ reaction Marking color : White print on a blue sleeve Specifications Item Performance Category temperature range (℃) ー25 to +70 Tolerance at rated capacitance (%) ー20 to +80 Internal resistance at 1 kHz Refer to the following page Characteristics at high and low temperature Percentage of capacitance change Endurance (70℃) Percentage of capacitance change Within ±30% of the value at 20℃ Less than five times of the value at 20℃ Internal resistance 1000 hours Test time Within ±30% of the initial measured value Internal resistance Less than four times of the initial specified value Shelf life (70℃) Test time : 1000 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Outline Drawing Unit : mm φ6.3 to φ18 φd±0.05 copper clad steel wire (tinned) Sleeve Vent φ25, 35 2‒φ2 Sleeve φD+0.5max. φD F φd 6.3 2.5 α 5 min. 15min. 8 10 12.5 3.5 5.0 0.6 2.0 16 7.5 0.8 L+2max. 6.3±1 Vent 18 2.6 6.8 1.5±0.1 Markings (‒) Negative terminal indicated by cross notching Position of printed circuit board holes 7.5 φD+1max. F±0.5 L+αmax. 1 0. ± 10 10 Lug terminal details 0.9±0.1 Thickness : 0.8t 2.1 Part numbering system (example : 2.5V10F) DZN Series code ̶ 2R5 D 106 (Z6)(S) Max. operating voltage symbol Terminal code Rated capacitance symbol Casing symbol T ̶ Taping (Forming) symbol Part number is refer to the following page. EDLC CAT.No.2015/2016E 214 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. Standard Ratings (Series DZN 2.5V) Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h ELNA Parts No. φD×L (mm) Internal resistance (Ω max.) at 1kHz DZN UPGRADE ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP” ® Internal resistance (mΩ max.) (DCR) 2.5 1 0.1 DZN-2R5D105F4T 6.3×14 0.4 1500 2.5 1 0.1 DZN-2R5D105G3T 8×12 0.3 1000 2.5 2.7 0.2 DZN-2R5D275G5ST 8×20 0.3 500 2.5 3.3 0.2 DZN-2R5D335H5T 10×20 0.2 350 2.5 4.7 0.3 DZN-2R5D475H5T 10×20 0.1 400 2.5 5.6 0.3 DZN-2R5D565H5T 10×20 0.1 350 2.5 6.8 0.4 DZN-2R5D685H6T 10×25 0.1 300 2.5 10 0.5 DZN-2R5D106H8T 10×35 0.1 200 2.5 10 0.5 DZN-2R5D106Z6ST 12.5×25 0.1 200 2.5 15 0.7 DZN-2R5D156Z8ST 12.5×35 0.1 150 2.5 15 0.7 DZN-2R5D156J5T 16×20 0.1 150 2.5 22 0.8 DZN-2R5D226J6T 16×25 0.1 120 2.5 33 0.8 DZN-2R5D336J8T 16×35.5 0.1 100 2.5 40 0.8 DZN-2R5D406K9T 18×40 0.1 75 2.5 50 1.0 DZN-2R5D506T 25×40 0.03 60 2.5 100 1.0 DZN-2R5D107S37T 25×50 0.03 50 2.5 200 2.0 DZN-2R5D207S57T 35×50 0.03 40 We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required. Standard Ratings (Series DZN 2.7V) Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h ELNA Parts No. φD×L (mm) Internal resistance (Ω max.) at 1kHz Internal resistance (mΩ max.) (DCR) 2.7 1 0.2 DZN-2R7D105F4T 6.3×14 0.4 1500 2.7 1 0.2 DZN-2R7D105G3T 8×12 0.3 1000 2.7 2.7 0.3 DZN-2R7D275G5ST 8×20 0.3 500 2.7 3.3 0.3 DZN-2R7D335H5T 10×20 0.2 350 2.7 4.7 0.4 DZN-2R7D475H5T 10×20 0.1 400 2.7 5.6 0.4 DZN-2R7D565H5T 10×20 0.1 350 2.7 6.8 0.5 DZN-2R7D685H6T 10×25 0.1 300 2.7 10 0.6 DZN-2R7D106H8T 10×35 0.1 200 2.7 10 0.6 DZN-2R7D106Z6ST 12.5×25 0.1 200 2.7 15 0.8 DZN-2R7D156Z8ST 12.5×35 0.1 150 2.7 15 0.8 DZN-2R7D156J6T 16×25 0.1 150 2.7 22 1.0 DZN-2R7D226J7T 16×31.5 0.1 120 2.7 33 1.0 DZN-2R7D336J9T 16×40 0.1 100 We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required. EDLC NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 215 CAT.No.2015/2016E
DZN-2R5D155H3T 价格&库存
很抱歉,暂时无法提供与“DZN-2R5D155H3T”相匹配的价格&库存,您可以联系我们找货
