X32015
X32015
    EATON(伊顿)
    TB3/WHITECOVERMFGR
X32015 数据手册
Marking Options & Accessories Double Row Terminal Blocks (TB100, TB200, TB300, TB345 SERIES) Single & Double Row Filtered Connectors Marking Options Standard Marking L1 1 2 3 3 2 1 L2 L3 1 2 3 L4 L5 L6 Euro-MAG Series PCB – Spring Clamp 1 2 3 Note: Blocks marked on both sides require a different code for each side. Example Style L1 on one side of the block requires Style L2 on the other side to ensure common terminal marking. To order, add appropriate suffix (L1, L2, L3, L4, L5 and/or L6) to block part number in the proper sequence. 1 2 3 3 2 1 Standard markings are applied directly to the side(s) of a block. Standard color is white. Standard height is .125”. RED BLK BLU 3 4 134 20A 134 G GND M 300V MAX A OUT PUT 3AC 5 MAS TER Base & Rail Mount Connectors K MB Special markings are available at an additional charge for preparation. Production charges for setup, handling and marking are the same as for standard marking. Drawing(s) must be submitted to ensure accuracy of part required. Consult factory for price and delivery. INPUT Special Marking Note: Marking is not available on TB400 Series Covers Covers prevent personnel, screws and foreign items from contacting live terminals. Available in white or clear plastic. Two cover clips supplied with each cover. Cover width is 1.31 inches. Power Distribution Blocks All covers must be ordered separately. Consult factory for special legends. Example: 10 position cover, white, TB100 Series, no legends . . . Part No. is X12010. Part Numbering System Series Cover Strip Poles X 02 to 36 (TB100) 02 to 30 (TB200/TB200HB) 02 to 24 (TB300/TB345) Part Number DD1 – TB100 Series DD2 – TB200 Series DD2HB – TB200HB Series DD3 – TB300 Series Note: Covers are not available on TB400 Series. 35 WIRE MANAGEMENT PRODUCTS 120 - TB100/white 119 - TB100/clear 220 - TB200 - white 220HB - TB200HB - white 219 - TB200 - clear 219HB - TB200HB - clear 320 - TB300 & TB345 - white 319 - TB300 & TB345 - clear Cover Clips – Bulk Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Eaton: X11910 X12007 X21904 X31904 X31908 X31918 X31924 X11906 X21904HB X11903 X11907 X11908 X31910 X22008 X22003 X32015 X12010 X11905 X22004 X11909 X12016 X21916 X12006 X31903 X32010 X12003 X31917 X22003HB X12021 X32003 X21906 X31920 X31909 X21910 X31906 X22002HB X11922 X31912 X11904 X21925 X22008HB X11916 X32007 X21912HB X31907 X32012 X32018 X21920 X21907 X32005 X11912 X21924 X21909 X22014 X32016 X22012 X21903HB X22010HB X11915 X12008 X32008 X21913 X32020 X21910HB X21902 X31905 X32004 X21903 X12005 X21912 X12012 X22002 X22012HB X12014 X21905 X32013 X12004 X21930 X32024 X12024 X32006 X22013 X11902 X22006 X32002 X12002 X22010 X21908 X31914 X22020 X31902 X21908HB X22022 X21906HB X31913 X31915 X11932
X32015 价格&库存
很抱歉,暂时无法提供与“X32015”相匹配的价格&库存,您可以联系我们找货
