W-DUMMY
W-DUMMY
    EATON(伊顿)
W-DUMMY 数据手册
BUSSMANN Effective May 2016 Supersedes June 2003 Technical Data 1036 SERIES Edison base plug fuses – fast-acting, 125 volts, 1/2–12 amps Recommended fuse holders Catalog numbers SOU SRU SSU SOW SRW SSW SOX Catalog symbol: • W - (amps) SRX Description: Bussmann® series fast-acting Edison base plug fuse. Specifications: Ratings • Volts — 125 Vac or less • Amps — 1/2 to 12 A • Interrupting rating — 10 kA RMS Sym Agency Information • UL® Listed, Std. 248-11, Guide JEFV, File E12112 • CE Catalog numbers (amps) W - 1/2 W-5 W-1 W-6 W - 1-8/10 W - 6-1/2 W-2 W-7 W - 2-1/2 W-8 W-3 W - 10 W-4 W - 12 Type box 2 1/4” handy 2 3/4” handy 4” octagon Catalog numbers SOY SRY SSY SSY-RL STY SCY SOY-B Type box 4” square Single gang SSN Package quantity and weight Quantity Weight Amp ratings Per box Per card Per box Per 5 cards 15 to 30 A 4 1 0.96 1.20 W-15, W-20, W-25, and W-30 plug fuses obsoleted suggest replacing with either T-(amp) or TL-(amp) plug fuses Both the T and TL Bussmann series plug fuses offer similar short-circuit protection to the W plug fuses. In addition, the T and TL plug fuses offer time-delay performance for overload currents (typically between one and six times the rated current of the fuse). For most applications, this feature is preferred to allow harmless inrush currents to pass without causing the fuse to open unnecessarily. The TL plug fuses (data sheet No. 1035) utilize a loaded link construction and provide medium-duty performance. The T plug fuses (data sheet No. 1034) utilize the advanced dual-element design for heavy-duty performance. This construction makes the T plug fuses the preferred selection. For additional information, please see the applicable data sheets. Features: • For lighting, heating or other circuits that do not contain electric motors • Edison base size • These fuses thread into fuse receptacles or Bussmann series box cover units • The general purpose (W) fuse has no time-delay feature and should not be used in circuits that contain motors Technical Data 1036 Edison base plug fuses fast-acting, 125 volts, 1/2-12 amps  Effective May 2016 10 6 100 3 1 Time-current curve – average melt Amp rating Time in seconds Time in seconds 10 1 200 100 1 0.4 0.01 10 0.1 Current in amps The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1036 – SB03177 May 2016 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
W-DUMMY 价格&库存
很抱歉,暂时无法提供与“W-DUMMY”相匹配的价格&库存,您可以联系我们找货
