AGC-V-6-1J0295
AGC-V-6-1J0295
    EATON(伊顿)
AGC-V-6-1J0295 数据手册
Technical Data 2543 Effective May 2017 Supersedes November 2016 AGC 1/4” x 1 1⁄4” Fast-acting glass tube fuses Agency information • • • • UL Listed Card: AGC 1⁄20-10 UL Recognition Card: AGC 11-40 CSA Component Acceptance Card (Class No. 1422 30) CSA Certification Card (Class No. 1422 01) Environmental data • Shock: 1⁄20 - 3⁄4A – MIL-STD-202, Method 213, Test Condition I; 1 - 30A –MIL-STD-202, Method 207, (HI Shock) • Vibration: 1⁄20 - 30A – MIL-STD-202,Method 204, Test Condition A (Except 5g, 500Hz) Product features • • • • • Fast-acting Optional axial leads available 1⁄4” x 1 1⁄4” (6.3 x 32mm) physical size Glass tube, nickel-plated brass endcap construction UL Listed product meets standard 248-14 Part Number AGC- 1⁄20 -R AGC- 1⁄10 -R AGC- 1⁄8-R AGC- 3⁄16 -R AGC- 2⁄10 -R AGC- 1⁄4-R AGC- 3⁄10 -R AGC- 3⁄8-R AGC- 1⁄2-R AGC- 3⁄4-R AGC-1-R AGC-1- 1⁄4-R AGC-1- 1⁄2-R AGC-2-R AGC-2- 1⁄4-R AGC-2- 1⁄2-R AGC-3-R AGC-4-R AGC-5-R AGC-6-R AGC-7-R AGC-7- 1⁄2-R AGC-8-R AGC-9-R AGC-10-R AGC-12-R AGC-14-R AGC-15-R AGC-20-R AGC-25-R AGC-30-R AGC-35-R AGC-40-R AC Voltage Rating 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 32 32 32 32 32 32 32 32 Ordering • Specify packaging code prefix, part number and option code suffix (if applicable) SPECIFICATIONS AC Interrupting Rating (amps) Typical DC Cold Resistance* (Ω) 250 125 32 4.500 35 10,000 — 12.565 35 10,000 — 6.800 35 10,000 — 4.900 35 10,000 — 3.360 35 10,000 — 2.300 35 10,000 — 1.670 35 10,000 — 1.203 35 10,000 — 0.615 35 10,000 — 0.312 35 10,000 — 0.190 35 10,000 — 0.145 100 10,000 — 0.115 100 10,000 — 0.078 100 10,000 — 0.067 100 10,000 — 0.057 100 10,000 — 0.045 100 10,000 — 0.030 200 10,000 — 0.024 200 10,000 — 0.020 200 10,000 — 0.017 200 10,000 — 0.0146 200 10,000 — 0.014 200 10,000 — 0.012 200 10,000 — 0.008 200 10,000 — 0.0070 — — 1000 0.0062 — — 1000 0.006 — — 1000 0.004 — — 1000 0.003 — — 1000 0.002 — — 1000 0.0014 1000 — — 0.0019 — — 1000 * DC Cold Resistance (Measured at ≤10% of rated current) † Typical Melting I 2t (A 2Sec) (I 2t was measured at listed interrupting rating and rated voltage.) ‡ Typical Voltage Drop (Voltage drop was measured at 25°C ambient temperature at rated current) Typical Melting I2t† AC 0.00773 0.000787 0.00131 0.00637 0.00435 0.0148 0.0208 0.0321 0.269 0.815 1.615 0.018 0.0149 0.00509 0.00588 0.00879 0.0167 0.0305 0.045 0.071 0.105 — 0.152 0.21 0.492 — — 0.566 1.438 2.109 3.807 — — Typical Voltage Drop‡ 0.67 6.00 4.67 4.12 4.51 0.89 2.88 4.59 0.59 0.37 0.31 0.35 0.27 0.28 0.26 0.31 0.25 0.22 0.23 0.23 0.23 — 0.19 0.18 0.20 — — 0.14 0.12 0.11 0.12 — — AGC 1/4” x 1 1⁄4” Fast-acting glass tube fuses Technical Data 2543 Effective May 2017 Time-Current Curves CURRENT IN AMPERES 1-1/2 2 2-1/2 3 4 3/4 1 2/10 1/4 3/10 3/8 1/2 CURRENT IN AMPERES TIME IN SECONDS 1/10 1/8 1/16 TIME IN SECONDS Dimensions - mm/in Packaging Code Prefix Code BK BK1 Description 100 pieces of fuses packed into a cardboard carton with flaps folded 1000 pieces of fuses packed into a cardboard carton with flaps folded Code B V -R Description Board Washable - Hermetically sealed to withstand aqueous cleaning Axial leads - copper tinned wire with nickel-plated brass overcaps RoHS Compliant Option Code Suffix Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2543 May 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cooper Bussmann: AGC-1-1-2-R AGC-1-1-4-R AGC-1-200 AGC-1-2-10-R AGC-1-3-4-R AGC-1-50 AGC-15-100-R AGC-1-6-10-R AGC-1-8-10-R AGC-1-8-R AGC-2-10-R AGC-2-1-2-R AGC-2-1-4-R AGC-3-10-R AGC-3-1-2-R AGC-3-16-R AGC3-2-10-R AGC-3-4-R AGC-3-8-R AGC-4-10-R AGC-4-1-2-R AGC-6-10-R AGC-6-1-4-R AGC-7-1-2-R AGC-8-10-R AGC-V-1-100 AGC-V-1-10-R AGC-V-1-16-R AGC-V-1-32 AGC-V-1-4-R AGC-V-15-100-R AGC-V-175-1000R AGC-V-1-8-R AGC-V-2-10-R AGC-V-3-10-R AGC-V-3-1-2-R AGC-V-3-16-R AGC-V-3-4-R AGC-V-3-8-R AGC-V-410-R AGC-V-6-10-R AGC-V-8-10-R BK-AGC-1-4-R Eaton: BK/AGC-4/10 BK/AGC-V-1-6/10 BK/AGC-V-1/8 BK/AGC-V-9 BK/AGC-3/4 BK/AGC-V-2-1/4 BK/AGC-30 BK/AGC9 BK/AGC-5 BK/AGC-V-5 BK/AGC-V-10 BK/AGC-V-30 BK/AGC-V-3-2/10 BK/AGC-V-1-1/2 BK/AGC-2/10 BK/AGC-V-15 BK/AGC-V-3 BK/AGC-3-2/10 BK/AGC-V-4/10 BK/AGC-V-2-1/2 AGC-45/100 BK/AGC-2-1/2 BK/AGC-V-8 BK/AGC-V-6-1/4 BK/AGC-1/10 BK/AGC-35 BK/AGC-3/16 BK/AGC-50 BK/AGC-3-1/2 BK/AGC-1-1/4 BK/AGC-7 BK/AGC-1/2 BK/AGC-1/8 BK/AGC-6 BK/AGC-8/10 BK/AGC-V-2 AGC-1/20 BK/AGC-V-3/16 BK/AGC175/1000R BK/AGC-9-R BK/AGC-8/10-R BK/AGC-8-R BK/AGC-7-R BK/AGC-7-1/2-R BK/AGC-30-R BK/AGC-6-R BK/AGC-4/10-R BK/AGC-5-R BK/AGC-6-1/4-R BK/AGC-6/10-R BK/AGC-3/4-R BK/AGC-3/8-R BK/AGC-1-3/4-R BK/AGC-3/16-R BK/AGC-4-R AGC-45/100-R AGC-1/20-R BK/AGC-1-1/4-R BK/AGC-1-6/10-R BK/AGC-1-8/10-R BK/AGC-1-R BK/AGC-1/10-R BK/AGC-1/2-R BK/AGC-20-R BK/AGC-3-R BK/AGC-1-1/2-R BK/AGC-1/8-R BK/AGC-3-2/10-R BK/AGC-25-R BK/AGC-3/10-R BK/AGC-2/10-R BK/AGC-2-R BK/AGC-2-1/4-R BK/AGC-2-1/2-R BK/AGC-15/100-R BK/AGC-15-R BK/AGC-10-R BK/AGC-3-1/2-R BK/AGC-8 BK/AGC-V-2/10 BK/AGC-V-1-8/10 BK/AGC-1/16 AGC-175/1000-R AGC-4-R AGC-V-1-1/2-R AGC-V-1-1/4-R AGC-V-1-6/10-R AGC-V-1-8/10-R AGC-V-2-1/2-R AGC-V-2-1/4-R AGC-V-3-2/10-R AGC-V-6-1/4-R AGC-V-7-1/2-R BK/AGC-V-.175R BK/AGC-V-1/16-R BK/AGC-V-1/4-R BK/AGC-V-1/8-R BK/AGC-V-10-R BK/AGC-V-15-R BK/AGC-V-1-R
AGC-V-6-1J0295 价格&库存
很抱歉,暂时无法提供与“AGC-V-6-1J0295”相匹配的价格&库存,您可以联系我们找货
AGC-V-6-1J0295
