BK/ATC-20ID
BK/ATC-20ID
    EATON(伊顿)
BK/ATC-20ID 数据手册
Automotive Blade Fuses ATC® Series Fast-Acting Time-Current Characteristic Curves - Average Melt 3 4 5 7.5 10 15 20 25 30 40 AMP RATING 100 Also available with open fuse indication in ratings from 3 to 40A. Contact factory for details TIME IN SECONDS 10 Catalog Symbol: ATC Fast-Acting Ratings: Volts: 32Vdc Amps: 1 to 40A Interrupting: 1000A Agency Approvals: UL Recognized, (3-40A) Guide JFHR2, File E56412 Ordering: Specify packaging and product code: 1 .1 Fuse Body Color Code Black Gray Violet Pink Tan Brown Red Blue Yellow Clear Green Blue/Green Amber 100 .01 1,000 Product Number ATC-1 ATC-2 ATC-3 ATC-4 ATC-5 ATC-7 1/2 ATC-10 ATC-15 ATC-20 ATC-25 ATC-30 ATC-35 ATC-40 Dimensions: mm (in) 1 Catalog Numbers (amps) 10 Blank = five (5) fuses packed in a tin “BK” prefix = 2000 fuses packed in a carton CURRENT IN AMPS 11.7 (0.460) 19.3 (0.760) 12.5 (0.492) 4.13 (0.163) 14.6 (0.575) 16.7 (0.657) Recommended Cooper Bussmann Fuse Holders* 5.25 (0.207) 19.1 (0.752) 6.67 (0.263) Part No. HHC HHF HHD HHG HHD-C HHR HHS ATC-FHID Description Yellow fuse holder Black fuse holder w/cover Black fuse holder Black fuse holder w/cover Cover Only Heavy duty, water resistant fuse holder Self-stripping fuse holder Illuminating fuse holder Fuse Range 1-20A 1-20A 1-30A 1-30A — 1-30A 1-20A 1-20A Lead Wire Size #16 #14 #12 #12 — #12 #18 to #14 #16 *Also used in Cooper Bussmann 1A5600 Fuse Clips (0-20A) The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 0809 BU-SB09723 Page 1 of 1 Data Sheet 2009 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cooper Bussmann: BK/ATC-7-1/2 BK/ATC-25 ATC-1 BK/ATC-40 BK/ATC-20 BK/ATC-3 BK/ATC-10 BK/ATC-30 BK/ATC-4 ATC-2 ATC-35 BK/ATC-15 BK/ATC-5 BK/ATC-1 BK/ATC-2 BK/ATC-35 ATC-7-1/2RLD VP/ATC-25ID BP/ATC-5ID VP/ATC-10ID BK/ATC-15ID BK/ATC-30ID BP/ATC-5 BP/ATC-15ID BP/ATC-40 BP/ATC-3 BP/ATC-25ID BP/ATC40ID BP/ATC-30ID BP/ATC-30 BK/ATC-20ID BP/ATC-10ID BK/ATC-25ID BP/ATC-7-1/2 BP/ATC-7-1/2ID BP/ATC-3ID BP/ATC-20 BP/ATC-10 VP/ATC-20ID BP/ATC-20ID BP/ATC-35ID BP/ATC-4 BP/ATC-25 VP/ATC30ID BP/ATC-15 VP/ATC-15ID ATC-5BC BK/ATC-10ID
BK/ATC-20ID 价格&库存
很抱歉,暂时无法提供与“BK/ATC-20ID”相匹配的价格&库存,您可以联系我们找货
BK/ATC-20ID
  • 50+67.1029350+8.70655
