BK/GMC-V-6.3A
BK/GMC-V-6.3A
    EATON(伊顿)
    BK/GMC V 6.3A
BK/GMC-V-6.3A 数据手册
5mm x 20mm Fuses GMC Series Medium Time Delay, Glass Tube Description • Medium time delay, low breaking capacity • 5mm x 20mm physical size • Glass tube, nickel-plated brass endcap construction • Optional axial leads are .032" x 1.5" copper tinned • Designed to UL/CSA 248-14 ELECTRICAL CHARACTERISTICS Rated Current % of Amp Rating Opening Time 100% None 63mA - 10A 135% 60 minutes maximum 200% 2 minutes maximum Dimensions Agency Information • UL Listed, Guide JDYX, File E19180, 63mA-6.3A • UL Recognized Card: (7A-8A) Guide JDYX2, File E19180 • CSA Certified, Class 1422-01, File E65063, 63mA-6.3A Ordering • Specify product code, option code and packaging code mm ⁄(inches) 38.10mm 0m (± ±.38) .3 5.54mm (±.20) (± 21.10mm 0m (±.81) 81 ±0.5) 5.2mm (+0.1/-0.2) 38.10mm 0m (±.38) 38 .81 (REF) SPECIFICATIONS Product Code GMC-63mA GMC-80mA GMC-100mA GMC-125mA GMC-150mA GMC-160mA GMC-200mA GMC-250mA GMC-300mA GMC-315mA GMC-400mA GMC-500mA GMC-600mA GMC-630mA GMC-700mA GMC-750mA GMC-800mA GMC-1A GMC-1.25A GMC-1.5A GMC-1.6A GMC-2A GMC-2.5A GMC-3A GMC-3.15A GMC-3.5A GMC-4A GMC-5A GMC-6A GMC-6.3A GMC-7A GMC-8A GMC-10A * ** † ‡ Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 125V 125V 125V 125V 125V 125V 125V 125V AC Interrupting Rating* 250V 125V 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 10,000A 10,000A 10,000A 10,000A 10,000A 200A 200A 200A Typical DC Cold Resistance (ohms)** 10.350 4.775 3.400 2.555 2.295 1.395 0.965 0.838 0.685 0.615 0.335 0.282 0.246 0.213 0.213 0.180 0.156 0.098 0.076 0.067 0.043 0.035 0.026 0.025 0.022 0.019 0.014 0.013 0.012 0.012 0.009 0.007 Typical Pre-Arc I2t AC† 0.0027 0.0050 0.0094 0.014 0.022 0.022 0.032 0.046 0.081 0.081 0.18 0.41 0.60 0.66 0.85 0.85 0.85 1.8 3.4 5.4 5.8 8.9 13 19 23 25 36 58 88 110 150 200 300 Maximum Voltage Drop (mV)‡ 1400 1400 1200 1000 800 730 650 490 580 480 510 370 360 360 340 320 290 250 200 190 160 130 130 130 130 130 120 120 120 120 120 110 110 Interrupting ratings: Interrupting ratings for 63mA - 6.3A were measured at 70% - 80% power factor on AC. The interrupting ratings for 7A - 10A were measured at 100% power factor on AC. DC Cold Resistance (Measured at
BK/GMC-V-6.3A 价格&库存
很抱歉,暂时无法提供与“BK/GMC-V-6.3A”相匹配的价格&库存,您可以联系我们找货
BK/GMC-V-6.3A
  • 16+67.37107
  • 35+64.57805
库存:98
