GLQ-9
GLQ-9
    EATON(伊顿)
GLQ-9 数据手册
Effective June 2017 Supersedes May 2005 Technical Data 2033 GLQ (fuse) HLQ (fuse holder) Specialty fuse, fast-acting, size rejecting Catalog symbol: GLQ (fuse) HLQ (fuse holder) Fast-acting rejection style Ampere Rating: 1-10 Amperes Voltage Rating: 300 Volts AC or less Interrupting Rating: 10,000 Amperes Product features • Size of GLQ fuse varies with ampere rating. • GLQ fuses mount in HLQ size rejecting carriers (prevents overfusing). • Fuse and knob are an integral one-piece unit. There are no replacement knobs (caps). • HLQ carrier comes with 6· of #18 red insulated solid copper wire attached to the line side. • Customer inserts a #18 insulated solid copper wire into load side receptacle. • Units can be panel mounted with a separate steel clip. For the knockout hole (see above), choose #BK/A-104. For the keyhole punch type hole, choose #6374 for panels .043” to .062” thick, or #4909 for panels .030” to .042” thick. • Do not put tension on line (rear) terminal of fuseholder. Electrical Ratings for Type GLQ Fuses and Rejection Style Carriers Fuse Carrier Fuse Carrier GLQ-1 HLQ-1flΩ¡º GLQ-3 HLQ-3¤Ω¡º GLQ-1⁄Ω™ HLQ-1flΩ¡º GLQ-4 HLQ-5 GLQ-1flΩ¡º HLQ-1flΩ¡º GLQ-5 HLQ-5 GLQ-2 HLQ-3¤Ω¡º GLQ-9 HLQ-10 GLQ-2⁄Ω™ HLQ-3¤Ω¡º GLQ-10 HLQ-10 CE logo denotes compliance with European Union Low Voltage Directive (50-1000 Vac, 75-1500 Vdc). Refer to Data Sheet: 8002 or contact Application Engineering at 636-527-1270 for more information. Agency information Fuse • UL Listed, Std. 248-14, Guide JDYX, File E19180 • CSA Certified, C22.2 No. 248.14, Class 1422-01, File 53787 Fuse holder • UL Recognized, Guide IZLT2, File E14853 CSA Certified, Class 6225-01, File 47235 GLQ (fuse) HLQ (fuse holder) Specialty fuse, fast-acting, size rejecting Technical Data 2033 Effective June 2017 Dimensional Data 10 15 5 1 1.5 100 2 Time-Current Characteristic Curves–Average Melt FUSE AMPERE RATING 0.63" (15.9mm) 2.250'' 57.15mm .850'' 21.59mm .720'' 18.29mm Line Lead .850'' 21.59mm MOUNTING HOLE .870'' 22.10mm C L TIME IN SECONDS 10 FUSE AND CARRIER 1 Load Lead .255'' 6.48mm .1 .635'' 16.13mm .740'' 18.80mm .410'' 10.41mm Keyhole Punch 200 100 10 1 .01 .1 Knockout Hole CURRENT IN AMPERES Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2033 SB02233 June 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
GLQ-9 价格&库存
很抱歉,暂时无法提供与“GLQ-9”相匹配的价格&库存,您可以联系我们找货
GLQ-9
    • 5+91.947285+11.89479
