Effective June 2017
Supersedes May 2005
Technical Data 2033
GLQ (fuse) HLQ (fuse holder)
Specialty fuse, fast-acting, size rejecting
Catalog symbol: GLQ (fuse) HLQ (fuse holder)
Fast-acting rejection style
Ampere Rating: 1-10 Amperes
Voltage Rating: 300 Volts AC or less
Interrupting Rating: 10,000 Amperes
Product features
• Size of GLQ fuse varies with ampere rating.
• GLQ fuses mount in HLQ size rejecting carriers
(prevents overfusing).
• Fuse and knob are an integral one-piece unit. There
are no replacement knobs (caps).
• HLQ carrier comes with 6· of #18 red insulated
solid copper wire attached to the line side.
• Customer inserts a #18 insulated solid copper wire
into load side receptacle.
• Units can be panel mounted with a separate steel
clip. For the knockout hole (see above), choose
#BK/A-104. For the keyhole punch type hole,
choose #6374 for panels .043” to .062” thick, or
#4909 for panels .030” to .042” thick.
• Do not put tension on line (rear) terminal of fuseholder.
Electrical Ratings for Type GLQ Fuses and Rejection
Style Carriers
Fuse
Carrier
Fuse
Carrier
GLQ-1
HLQ-1flꭧ
GLQ-3
HLQ-3¤Ω¡º
GLQ-1⁄Ω™
HLQ-1flꭧ
GLQ-4
HLQ-5
GLQ-1flꭧ
HLQ-1flꭧ
GLQ-5
HLQ-5
GLQ-2
HLQ-3¤Ω¡º
GLQ-9
HLQ-10
GLQ-2⁄Ω™
HLQ-3¤Ω¡º
GLQ-10
HLQ-10
CE logo denotes compliance with European Union Low Voltage Directive
(50-1000 Vac, 75-1500 Vdc). Refer to Data Sheet: 8002 or contact
Application Engineering at 636-527-1270 for more information.
Agency information
Fuse
• UL Listed, Std. 248-14, Guide JDYX, File E19180
• CSA Certified, C22.2 No. 248.14, Class 1422-01, File 53787
Fuse holder
• UL Recognized, Guide IZLT2, File E14853
CSA Certified, Class 6225-01, File 47235
Technical Data 2033
Effective June 2017
Dimensional Data
10
15
5
1
1.5
100
2
Time-Current Characteristic Curves–Average Melt
FUSE
AMPERE
RATING
0.63"
(15.9mm)
2.250''
57.15mm
.850''
21.59mm
.720''
18.29mm
Line Lead
.850''
21.59mm
MOUNTING HOLE
.870''
22.10mm
C
L
TIME IN SECONDS
10
FUSE AND CARRIER
1
Load Lead
.255''
6.48mm
.1
.635''
16.13mm
.740''
18.80mm
.410''
10.41mm
Keyhole Punch
200
100
10
1
.01
.1
Knockout Hole
CURRENT IN AMPERES
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/electronics
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 2033 SB02233
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“GLQ-1”相匹配的价格&库存,您可以联系我们找货
