GLR-2
GLR-2
    EATON(伊顿)
GLR-2 数据手册
Technical Data 2032 Effective December, 2015 Supersedes May, 2002 BUSSMANN SERIES GLR and HLR Non-rejecting, fast-acting fuse and inline fuse holders Catalog symbols: • GLR (Fuse) • HLR (Fuse holder) • Description: • Fast-acting, non-rejection style inline fuse and fuse holder system Specifications: Ratings • Volts • • Amps • • 300Vac or less 3/16-15A Interrupting rating • 10kA Agency information • GLR fuse • UL® Listed, Std. 248-14, 3/16-15A/300Vac, Guide JDYX, File E19180 • • CSA® Certified, C22.2 No. 248.14, 0-10A/300Vac, Class 1422-01, File 53787 HLR fuse holder • UL Recognized, 12A, 300Vac, Guide IZLT2, File E14853 • CSA Certified, 12A, 300Vac, Class 6225-01, File 47235 HLR-2A and HLR-2L fuse holders • UL Recognized, 15A, 300Vac, Guide IZLT2, File E14853 • CSA Certified, 15A, 300Vac, Class 6225-01, File 47235 A fuseholder • CSA Certified, 10A, 300Vac, Class 6225-01, File 47235 GLR fuse catalog numbers Fuse (amps) GLR-3/16 GLR-1-6/10 GLR-1/2 GLR-2 GLR-1 GLR-3 GLR-1-1/2 GLR-4 GLR-5 GLR-6 GLR-7 GLR-8 GLR-9 GLR-10 GLR-12 GLR-15* * Must be used with the HLR-2A holder rated to 15A. HLR fuse holder catalog numbers Catalog No. Description Holder with installed linseide HLR terminal wire for 3/16 to 12 amp GLR fuses Holder with installed lineside and HLR-2A loadside terminal wires for 3/16 to 15 amp GLR fuses Holder with uninstalled lineside HLR-2L and loadside terminal wires for 3/16 to 15 amp GLR fuses Holder without lineside or loadside A termianl wires for for 3/16 to 15 amp GLR fuses Technical Data 2032 Non-rejecting, fast-acting GLR fuse and HLR in-line fuse holders Effective December 2015 Features: Dimensions - in (mm): • GLR fuse and knob are an integral one-piece unit. There are no replacement knobs (caps) GLR fuse • Units can be panel mounted with a separate steel clip. For knockout hole mounting (see dimensions), order catalog number BK/A-104. For the keyhole punch type hole mounting, order catalog number 6374 for panels 0.043” to 0.062” thick, or catalog number 4909 for panels 0.030” to 0.042” thick. HLR fuse holder • The HLR holder comes with 6 inches of red #18 insulated solid copper wire attached to the lineside terminal, customer inserts a #18 insulated solid copper wire into loadside terminal • Order holder catalog number HLR-2A to obtain 6 inches of black #18 insulated solid copper wire pre-installed in the loadside terminal • Order catalog number HLR-2L to obtain 6 inches of black #18 insulated solid copper wire packaged loose (uninstalled) • An alternative to the HLR fuse holder is the “A” fuse holder. The “A” fuse holder comes WITHOUT leads. The customer inserts #18 insulated solid copper wire into the lineside and the loadside terminals. The “A” fuse holder has the same body dimensions, utilizes the same mounting hole, and takes the same mounting clips as the HLR, HLR-2A and HLR-2L • 2 Do not put tension on the fuse holder’s lineside terminal Eaton.com/bussmannseries 0.63" (15.9) 2.250” (57.1) 0.850” (21.6) 0.720” (18.3) Lineside terminal lead 0.850” 21.6) CL Loadside terminal lead Mounting holes 0.870” (22.1) 0.255” (6.5) 0.635” (16.1) 0.740” 18.8) 0.410” (10.4) Knockout hole Keyhole punch Non-rejecting, fast-acting GLR fuse and HLR in-line fuse holders Technical Data 2032 Effective December 2015 15 7 10 5 2 100 1 1.5 Time-current characteristic curves — average melt Amp Amp Rating rating Time Timein inseconds Seconds 10 1 200 Current in amps 100 10 0.1 0.01 1 0.1 Eaton.com/bussmannseries 3 Non-rejecting, fast-acting GLR fuse and HLR in-line fuse holders Technical Data 2032 Effective December 2015 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2032 – BU-MC15051 December 2015 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
GLR-2 价格&库存
很抱歉,暂时无法提供与“GLR-2”相匹配的价格&库存,您可以联系我们找货
GLR-2
    • 5+54.689125+6.85812
    • 10+50.4632510+6.32819
    • 15+48.1454215+6.03753
    • 25+45.3718225+5.68972
    • 35+43.6296235+5.47124
    • 50+41.8545350+5.24864
    • 125+37.60317125+4.71551
    • 250+34.66110250+4.34657
    • 500+31.93367500+4.00455
    库存:50
