Effective May 2016
Supersedes December 1998
Technical Data 1033
BUSSMANN
SERIES
Rejection base plug fuses – time-delay,
125 volts, 15-30 amps
Catalog numbers (amps)
SL - 15
SL - 20
SL - 25
SL - 30
Package quantity and weight
SL - (amps)
BP/SL - (amps)
SL - (amps)PK4
Weight
Per
box
Per
card
Per
box
Per 5
cards
15 to 30 A
4
3
0.20
0.995
Features:
Catalog symbol:
Quantity
Amp
ratings
Description:
Bussmann® series time-delay, loaded link
rejection base plug fuse.
Specifications:
Ratings
Volts — 125 Vac or less
Amps — 15 to 30 A
Interrupting Rating — 10 kA RMS Sym
Agency Information
UL® Listed, Std. 248-11 Guide JEFV, File
E12112
CE
Edison base adaptors
Adaptor
Accepts
fuses
SA - 15
SL - 15
SA - 20
SL - 20
SA - 30
SL - 30 to SL - 20
Medium duty time-delay rejection base fuse
No-interchangeablility prevents installing
a higher amp fuse than the circuit was
designed for
Has ability to withstand typical motor
starting surges
Use in residential or light-duty motor circuits
These fuses thread into SA adaptors
Technical Data 1033
time-delay 125 volts, 15—30 amps
Effective May 2016
Time-current curve – average melt
15
30
Amp
rating
100
Time in seconds
10
1
2000
1000
100
10
0.01
4
0.1
Current in amps
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1033 – SB98107
May 2016
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Follow us on social media to get the
Eaton trademarks without prior written
latest product and support information.
consent of Eaton.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
很抱歉,暂时无法提供与“SL-20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+125.691861+15.76200
- 4+104.713714+13.13130
- 12+96.8358412+12.14340
- 52+80.5490152+10.10100
- 100+74.44145100+9.33510
- 252+66.91764252+8.39160
- 500+61.78375500+7.74780
- 1000+56.915401000+7.13730
- 国内价格 香港价格
- 4+113.766714+14.26657
