84538
84538
    GREENLEECOMMUNICATIONS(格林利)
    BIT 5/16X4
84538 数据手册
BIT 5/16X4 Fast Spiral Bits Cat No: 84538 UPC No: 783310845386 Description • • • • Steel bit with carbide tip Use in concrete, block, brick, stone, wallboard and plaster Fast spiral for use in conventional power drills Available in sizes rangingfrom 3/16 IN - 1/2 IN (4.8 - 12.7 mm) Specifications • • • • • • • • Application : Use In Concrete, Block, Brick, Stone, Wallboard And Plaster, Conventional Power Drills Drill Size : 5/16 IN (7.900 MM) Material : Steel With Carbide Tip Overall Length : 4.000 IN Shank Size : 1/4 IN (6.400 MM) Twist Length : 2-1/2 IN (63.000 MM) Type : Fast Spiral Weight : 0.060 LB (27.000 GM)
84538 价格&库存
很抱歉,暂时无法提供与“84538”相匹配的价格&库存,您可以联系我们找货
