Effective December 2015
Supersedes April 2014
Technical Data 2011
BUSSMANN
SERIES
BAF 13⁄32˝ x 1-1/2˝ 250Vac fast-acting
supplemental fuses
Catalog symbol – color code
Dimensions - in (mm):
BAF
Green (250Vac max, 1/4 to 30A)
Description:
0.41"
(10.3)
Fast-acting, supplemental fuse.
For superior protection, Eaton recommends
upgrading to Bussmann series Low-Peak™
Class CC fuses. See data sheet No. 1023.
1.5"
(38.1)
Features:
Specifications:
Color coded green for 250Vac maximum
voltage rating
Fiber tube construction
Ratings
Nickel-plated endcaps.
250Vac
1/4 to 30A
Fuse amp
range
Interrupting rating
at system voltage
Agency
information
250
Vac
UL®
125
Vac
CSA®
1/4 to 1
35A
10kA
X
1-1/2 to 2-1/2
100A
10kA
X
3
100A
10kA
X
X
4 to 10
200A
10kA
X
X
12 to 15
750A
10kA
X
X
20 to 30
200A
10kA
Agency information
CE
UL Listed, Std. 248-14, 250Vac (3 to 15A)
Guide JDYX, File E19180
CSA Certified, 250Vac (1/4 to 15A)
Class 1422-01, File 53787
Catalog numbers (amps
BAF-1⁄4
BAF-1⁄2
BAF-6⁄10
BAF-8⁄10
BAF-1
BAF-1-1⁄2
BAF-1-8⁄10
BAF-2
BAF-2-1⁄2
BAF-3
BAF-4
BAF-5
BAF-6
BAF-6-1⁄4
BAF-7
BAF-8
BAF-9
BAF-10
Carton quantity
Amps
1/4 to 30
Qty.
10
BAF-12
BAF-15
BAF-20
BAF-25
BAF-30
Typical applications
General purpose circuits
Lighting circuit protection
Meter circuits
Recommended fuse blocks/fuse
holders
Catalog
Description
symbol
Blocks
BMM
1-, 2- and 3-pole
modular blocks with
optional covers
Data sheet
No.
10235
DIN-Rail holders / switches
CCP-_-30M
1-, 2- and 3-pole
switch
1157
CHM
1-, 2- and 3-pole
3185
Optima NG
3-pole protection
module
1109
Optima
3-pole holder
1102
Optima
3-pole holder +
switch
1103
Panel mount holders
HPM and HPM-D
1-pole holder
2112
HPC-D
1-pole holder
2109
HPS2
2-pole holder
2140
HPF, HPF-C and
HPF-WT
1-pole holder
2114
HPS
1-pole holder
2113
HPG and HPD
1-pole holder
2108
HEB
1-pole holder
2127
HEX
2-pole holder
2126
PCB fuseclips
2132
In-line holders
Fuseclips
1A3400, 5956
and 5960
Fuse covers
CVR(I)-CCM(-QC)
Finger-safe fuse cover 10235
Technical Data 2011
BAF
250Vac fast-acting supplemental fuses
30
15
100
3
1
Time-current characteristic curves – total clear:
Amp rating
Amp
Rating
Time in seconds
Time in Seconds
10
1
0.1
Current in Amps
200
Current in amps
100
10
1
0.4
0.01
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 1011 – BU-SB14288
December 2015
Eaton, Bussmann and Low-Peak are
valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BAF-15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+186.5335710+24.24052
