KU6-WWCNUV
KU6-WWCNUV
    EATON(伊顿)
KU6-WWCNUV 数据手册
Connectors Base Mount Double Row Terminal Blocks Series KU Specifications Description: Base mount double row terminal blocks. Ratings: Volts: — 600V Amps: — 60A* Center Spacing: 0.625” (15.88mm) Number of Poles: 2- to 12-poles Wire Range: #6-22 AWG Cu Screw Size: #10-32 Torque Rating: 20 lb-in. Distance Between Barriers: 0.437” (11.09mm) Mounting: Base mount Material: Molded base: Black, UL rated 94V1 Nuclear Grade Noryl Terminal plating: Nickel over brass Operating Temperature: 105°C max. Agency Information: UL File E62622, CSA File 47235 Series KU - in (mm) B 0.62 (15.9) * 60A rating achieved with #6 copper wire crimped to ring terminal. KU A 2.50 3.12 3.75 4.37 5.00 5.62 6.25 6.87 7.50 8.12 8.75 B 1.62 2.25 2.87 3.50 4.12 4.75 5.37 6.00 6.62 7.25 7.87 KUX Only A 2.00 2.62 3.25 3.87 4.50 5.12 5.75 6.37 7.00 7.62 8.25 #10 screw clearance 1.25 (31.8) 0.43 (11.1) 0.50 (12.7) A Connectors Poles 02 03 04 05 06 07 08 09 10 11 12 1.50 (38.1) 2.00 (50.8) Dimensions - in 1” = 25.4mm. Catalog Number Build-A-Code Series Poles Screw Options Covers Marking Strip 02 to 12 00 = Screws shipped bulk W = Brass washer head, nickel-plated P = Steel screw w/pressure plate zinc-plated B = Brass washer head, no plating BP = Brass philslot, nickel-plated WC = Top cover & 2 end plates MT = Matte finish NU = Numbered 1 to 12, horizontal NUV = Numbered 1 to 12, vertical PT = Marker strip for cover 02 to 12 00 = Screws shipped bulk W = Brass washer head, nickel-plated P = Steel screw w/pressure plate zinc-plated B = Brass washer head, no plating BP = Brass philslot, nickel-plated WC = Top cover & 2 end plates PT* = Marker strip for cover – KU = Standard block KUH = Block KUX = Short block KURL = Standard w/removable link KUXRL = Short block w/removable link Catalog Number - SC Series KUSC = Standard w/shorting strap & 4 shorting screws KUXSC = Short block w/shorting strap & 4 Shorting screws *Requires WC cover option Accessories MTMU## Molded Marking Tape Matte Finish NUM## Molded Marking Tape JU12 Jumper 12 Circuits NUE End Piece for NUC NUC## Cover For more information, visit www.cooperbussmann.com 321 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Eaton: JU12 KUSC6BPWCPT KUH6B KUX4-W KUXSC6-WC KU2 KU8-NLMT KUSC4 KUSC6-WCPT KUXSC4-W KUXSC6-WWCPT KUX6-WWCMT KUXSC8 KUX4 KU3 KUSC2 KUSC2-WC KUX8 KU6 KUX6 KUSC6 KUSC8WC KUXSC4 KUX12-MT KUX4-MT KUX4-WMT KUSC6-W KUXSC6 NUM12 KUSC8 KUXRL4 KUXSC6-W KU12-WC-MT NUE NUC4 KUXSC8-WWCPT KUXRL2-BP KUSC02-WWCMT KUSC4-PWC KUXSC6-PWC KUX03P KURL4-BP KU4-MT KUX-12P KUXRL6-00WCNUV KUX12-W KUH12A KUX8-WNUV KUXSC6-B KU6NLMT KU8-WMT KUTH KUXSC4-00 KU12-NLMT KUSC8-W KU8 KU06-WC-MT KU4 KUXSC4-GE KU12-MT KU10-WC-MT KUH12C KUSC4-WCNL KUSC6-00W KURL8 KUX12-WC KUSC4-W KUX12-00 KUH12B KUX8-W KUH6C KUXSC4-WPT KUXRL2 KUXRL6-BP KU4-BPWCMT KUXSC8-BPWC KUX8-MT KU10WWC KURL12BP KU6-WC KU8-MT KU12-WNUV KUXSC6-00 KU4-WMT KU12-WC KUH6A KUX6-MT KU6-WWCNUV KUSC6-WC KUX-06P KUXSC6-WPT KUX6-W KU12-WMT KU6-BPWCMT KUX8-BP KUXSC8-WPT KUX8-WMT KUXRL4-BP KUX12-BP KUSC4-WC
KU6-WWCNUV
物料型号:KU系列端子块
器件简介:基础安装的双排端子块,适用于多种应用。
引脚分配:支持2至12极的端子块配置。
参数特性: - 电压等级:600V - 电流等级:60A(使用#6 AWG铜线并压接至环形端子时) - 中心间距:0.625英寸(15.88mm) - 适用电线范围:#6-22 AWG铜线 - 螺丝尺寸:#10-32 - 扭矩等级:20 lb-in. - 隔板间距离:0.437英寸(11.09mm) - 材料:模制底座(黑色,UL评级94V1,核级Noryl),端子镀层(镍层覆盖黄铜) - 最高工作温度:105°C
功能详解:文档提供了端子块的详细尺寸和安装选项,包括不同极数的端子块尺寸,螺丝选项,以及是否配备短接条和标记条。
应用信息:适用于需要基础安装的电气连接应用。
封装信息:提供了不同配置的端子块型号和目录号,以及配件信息,如成型标记带和端子块盖。
KU6-WWCNUV 价格&库存
很抱歉,暂时无法提供与“KU6-WWCNUV”相匹配的价格&库存,您可以联系我们找货
