PON15
PON15
    EATON(伊顿)
PON15 数据手册
Bussmann® Type “P” and “D” Fuses CDN/CDS PON Standard Code Fuses Dimensional Data A B Ferrule Design–1 through 60 Amperes C A D B F Catalog Symbol: CDN (250V), CDS (600V), and PON (250V) Type “P” and “D” Fuses Agency Approvals: CSA Certified, Class 1421-01, File 53787 Time-Delay CSA Type “D” Volts Cat. No. Amp Ratings CDN CDS General Information: • Standard dimension fuses with 10kA minimum interrupting rating. 10 70, 80, 90, 100 5 110, 125, 150, 175, 200, 225, 250, 300, 350, 400, 450, 500, 600 1 Below 10A use FRS-R 10, 12, 15, 20, 25, 30, 35, 40, 45, 50, 60 600V E Ctn. Qty. Below 10A use FRN-R 10, 12, 15, 20, 25, 30, 35, 40, 45, 50, 60 250V Knife Blade–70 through 600 Amperes 10 70, 80, 90, 100 5 110, 125, 150, 175, 200, 225, 250, 300, 350, 400, 450, 500, 600 1 One-Time CSA Type “P” Volts 250V Cat. No. PON Amp Ratings Ctn. Qty. 15, 20, 25, 30, 35, 40, 45, 50, 60 (CSA “P”) A Catalog Number and Volts CDN PON 250 VAC CDS 600V 08-01-18 SB98107 Rev. A Amps 1-30 35-60 70-100 110-200 225-400 450-600 1-30 35-60 70-100 110-200 225-400 450-600 Overall Inches (mm) 2.0 (50.8) 3.0 (76.2) 5.88 (149.4) 7.3 (185.4) 8.63 (219.2) 10.38 (263.7) 5.0 (127.0) 5.5 (139.7) 7.88 (200.2) 9.63 (244.6) 11.63 (295.4) 13.38 (339.9) 10 B Max. Diameter Inches (mm) .56 (14.3) .81 (20.6) — — — — — — — — .81 (20.6) 1.06 (27.0) 1.16 (29.46) 1.66 (42.16) 2.38 (60.45) 2.88 (73.15) C Min. Blade Length Inches (mm) — — — — 1.0 (25.4) 1.38 (34.9) 1.88 (47.6) 2.25 (57.2) — — — — — — — — — — — — D Min. Barrel Length Inches (mm) — — — — — — 4.13 (104.8) 4.63 (117.5) 5.19 (131.8) — — — — — — — — — — — — E Blade Thickness Inches (mm) — — — — .13 (3.2) .19 (4.8) .25 (6.4) .25 (6.4) — — — — .13 (3.2) .19 (4.8) .25 (6.4) .25 (6.4) F Blade Width Inches (mm) — — — — .75 (19.1) 1.13 (28.6) 1.63 (41.3) 2 (50.8) — — — — .75 (19.1) 1.13 (28.6) 1.63 (41.3) 2 (50.8) Form No. CDN, CDS, and PON Page 1 of 3 BIF Doc #4126 Bussmann® Type “P” and “D” Fuses CDN/CDS PON Standard Code Fuses AMPERE RATING 600 400 200 100 60 300 30 AMPERE RATING 10 15 Average Time/Current Curves Cat. No. CDS 600VAC 600 400 200 100 60 30 1,000 10 15 Average Time/Current Curves Cat. No. CDN 250VAC 100 100 TIME IN SECONDS TIME IN SECONDS 10 10 1 1 .1 .1 Rev. A 40,000 10,000 1,000 100 10 CURRENT IN AMPERES 10,000 1,000 CURRENT IN AMPERES .01 08-01-18 SB98107 100 10 .01 Form No. CDN, CDS, and PON Page 2 of 3 BIF Doc #4126 Bussmann® Type “P” and “D” Fuses CDN/CDS PON Standard Code Fuses AMPERE RATING 60A 30A 15A Average Time/Current Curves Cat. No. PON 250VAC 100 TIME IN SECONDS 10 1 RMS SYMMETRICAL CURRENT IN AMPERES 10,000 100 20 .01 1,000 .1 The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 08-01-18 SB98107 Rev. A Form No. CDN, CDS, and PON Page 3 of 3 BIF Doc #4126
PON15 价格&库存
很抱歉,暂时无法提供与“PON15”相匹配的价格&库存,您可以联系我们找货
