645-001
645-001
    GREENLEECOMMUNICATIONS(格林利)
645-001 数据手册
CARBIDE CUTTER SETS INCLUDING 7/8" - 2 1/2" FASTER. SAFER. EASIER.® GREENLEE’S CARBIDE CUTTERS CONTINUE TO DELIVER THE LOWEST COST PER HOLE! EVERYTHING YOU NEED TO GET THE JOB DONE • Complete solutions for 1/2” to 2” conduit • Fast, accurate holes in stainless steel, mild steel, iron, copper, brass, aluminium, fiberglass and plastic sheet • Longer tool life - less friction, torque and heat CARBIDE CUTTER SET CAT. NO. 628 - INCLUDES 7/8" - 2 1/2" CUTTERS FASTER SAFER EASIER • Split point, cobalt-steel pilot drill eliminates walking and penetrates quickly • Flange Stop for Safety – prevents over-drilling • Optimized carbide design requires less force • Reduced torque minimizes muscle exertion • Ejector spring allows automatic slug removal with every cut • Precision engineered tungsten carbide teeth for fast cutting of round; burr-free holes PRODUCTS SHOWN AT ACTUAL SIZE 7/8" 1 3/8" 1 1/8" 2" 1 3/4" 2 1/2" QUICK CHANGE CARBIDE CUTTER SET Change cutter sizes with a simple push and turn. Reduce cost by replacing cutter heads only. CAT. NO. 648 - INCLUDES 7/8" - 2 1/2" CUTTERS FASTER SAFER EASIER • Split point, cobalt-steel pilot drill eliminates walking and penetrates quickly • Flange Stop for Safety – prevents over-drilling • Optimized carbide design requires less force • Reduced torque minimizes muscle exertion • Ejector spring allows automatic slug removal with every cut • Precision engineered tungsten carbide teeth for fast cutting of round; burr-free holes PRODUCTS SHOWN AT ACTUAL SIZE 2 1/2" 2" 1 3/4" 1 3/8" 1 1/8" 7/8" QUICK CHANGE CARBIDE HOLE CUTTERS PIPE/CONDUIT HOLE SIZE CAT. NO. INCH MM 645-5/8 5/8" 645-11/16 11/16" 17.5 645-3/4 3/4" 19.0 645-13/16 13/16" 20.6 645-7/8 7/8" 22.2 645-1 1" 25.4 645-1-1/16 1-1/16" 27.0 645-1-1/8 1-1/8" 28.6 645-1-7/32 1-7/32" 31.0 ENTRANCE TAP 648 SET 660 SET 655 SET 15.9 645-1-1/4 1-1/4" 31.8 645-1-5/16 1-5/16" 33.3 645-1-3/8 1-3/8" 34.9 645-1-7/16 1-7/16" 36.5 3/8" 1/2" 1/2" 3/4" ● ● ● 3/4" 1" ● ● ● ● ● ● 1" CAT. NO. 645-1-1/2 1-1/2" 38.1 645-1-3/4 1-3/4" 44.4 1-1/4" 1-1/2" 645-2 2" 50.8 645-2-1/8 2-1/8" 54.0 645-2-1/4 2-1/4" 57.2 645-2-3/8 2-3/8" 60.3 645-2-1/2 2-1/2" 63.5 645-2-5/8 2-5/8" 66.7 645-3 3" 76.2 QUICK CHANGE ARBORS FOR 645 CUTTERS 1-1/4" 1-1/2" ● ● ● ● HOLE SIZE 648 SET 660 SET 655 SET ● ● 645-011 Up to 2" ● 645-022 2-1/2" - 3" ● REPLACEMENT PILOT DRILLS FOR 645 ARBORS 2" 645-001 Up to 2" Use with 645-011 Arbor 645-002 2-1/2" - 3" Use with 645-022 Arbor ● 2" 2-1/2" 2-1/2" CARBIDE HOLE CUTTERS PIPE/CONDUIT HOLE SIZE CAT. NO. INCH MM ENTRANCE TAP 628 SET 635 SET 625-3/4 3/4" 19.0 3/8" 1/2" 625-7/8 7/8" 22.2 1/2" 3/4" ● ● 1" 25.4 3/4" 1" ● ● ● ● 625-1 625-1-1/8 1-1/8" 28.6 625-1-7/32 1-7/32" 31.0 625-1-3/8 1-3/8" 34.9 1" 625-1-1/2 1-1/2" 38.1 625-1-3/4 1-3/4" 44.4 1-1/4" ● 2" 50.8 1-1/2" ● 2-1/2" 63.5 2" ● 625-2 625-2-1/2 1-1/4" REPLACEMENT PILOT DRILLS FOR 625 CUTTERS 625-001 Use with 625 Cutters up to 2" ● 625-002 Use with 625-2-1/2" Only ● ● ORDERING INFORMATION CAT. NO. 628 648 UPC DESCRIPTION 06400 Carbide Cutter Set, 8pc 06401 Carbide Cutter Set, Quick Change, 8pc # SIZES HOLE SIZES PIPE/CONDUIT SIZES 6 7/8", 1-1/8", 1-3/8", 1-3/4", 2", 2-1/2" 1/2", 3/4", 1", 1-1/4", 1-1/2", 2" Lubrication during drilling helps extend the life of cutting tools. Greenlee recommends the use of 462 Series Cutting Oil, available in quart (462-Q) and gallon (462-1) sizes. www.greenlee.com MA6518 03/16 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2016 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc.
645-001 价格&库存
很抱歉,暂时无法提供与“645-001”相匹配的价格&库存,您可以联系我们找货
