825-7/8
825-7/8
    GREENLEECOMMUNICATIONS(格林利)
    HOLESAW VARIABLE PITCH
825-7/8 数据手册
New & Improved Hole Saws Engineered To Be The Best! Applications Greenlee is proud to introduce our new and improved Hole Saws. These Hole Saws were designed to cut faster, last longer and provide even greater value than before. The new and improved Greenlee Hole Saw cuts up to 30% faster than the competition – saving you time and money on the job. 3 The new robust tooth design is made from a higher quality steel that's fully hardened for a stronger, more durable saw that's tough enough to cut through the most demanding cutting applications. Electrical Box Reasons to buy Greenlee's New & Improved Hole Saws A key feature of Greenlee Hole Saws has always been its oxide finish. The oxide finish resists rust and chip build-up for easier cutting. There is no paint on the saw that melts while cutting – so there’s no paint gum-up or possible smoke when heated. 1 Angled Metal In addition to the oxide finish, the Greenlee Hole Saws are clearly marked for easy size identification and includes the part number for convenient reorder reference. Finally, Greenlee Hole Saws can be used with the Greenlee removable depth stop (826S) for added protection when cutting in areas where wires may be present, and with the Quick Change arbor for fast and easy changeovers. Give them a try and you will see that we have made a great product even better. Just more ways Greenlee is there with you, helping get the job done faster, safer and easier. TIME = MONEY on the jobsite. Cuts 30% Faster Than The Competition! *! Cut Times By Brand: 1-1/8" Hole Saw 10.00 FASTEST TIME IN BOTH TESTS Seconds 8.00 6.00 Greenlee® Milwaukee® Klein® Lenox® Ideal® 4.00 2.00 0.00 Average of first 5 cuts Average of cuts 101-105 Holes Cut Wood *Based on independent testing 1-1/8" hole saw, 14 guage steel, 800 rpm, 50lb load measured at cutting surface. 2 Stronger & more durable than ever before. 4-6 variable pitch for smoother cutting Teeth stay sharp longer for faster, cleaner cuts Saws clearly marked for easy size identification Thicker backplate for a more rigid longer lasting saw 3 More Features Fully hardened tooth for stronger, more durable saw Added Safety with removable depth stop (#826S) Oxide finish resists rust and chip buildup for easier cutting Fast and easy changeovers using Quick Change Arbor Only Greenlee offers these exclusive features & accessories to make the job faster, safer and easier. • Quick Change Arbor • Removable Depth Stop • Oxide Finish See Back For Ordering Information. Ordering Information = Replacement Part = Accessory Cat No. UPC Description 825-9/16 19131 HOLESAW,VARIABLE PITCH (9/16") Qty 1 KITS 825-5/8 19132 HOLESAW,VARIABLE PITCH (5/8") 1 825-11/16 19133 HOLESAW,VARIABLE PITCH (11/16") 1 825-3/4 19134 HOLESAW,VARIABLE PITCH (3/4") 825-13/16 19135 825-7/8 UPC Description Qty 830PG 29209 HOLESAW SET 1 830Q 2806 HOLESAW KIT (830Q) 1 1 830QS 10915 HOLESAW KIT 1 HOLESAW,VARIABLE PITCH (13/16") 1 830S 10912 HOLESAW SET 1 19136 HOLESAW,VARIABLE PITCH (7/8") 1 830 19192 HOLESAW SET 1 825-15/16 19137 HOLESAW,VARIABLE PITCH (15/16") 1 834 19913 HOLESAW SET 1 825-1 19138 HOLESAW,VARIABLE PITCH (1") 1 835 27538 HOLESAW KIT 1 825-1-1/16 19140 HOLESAW,VARIABLE PITCH (1 1/16") 1 889 3478 HOLESAW KIT,PLUMBERS (889) 1 825-1-1/8 19141 HOLESAW,VARIABLE PITCH (1 1/8). 1 890 3479 HOLESAW KIT,INDUSTRIAL MAINT (89 1 825-1-3/16 19143 HOLESAW,VARIABLE PITCH (1 3/16") 1 891 3480 HOLESAW KIT-ELECTRICIAN/PLUMBER( 1 825-1-1/4 19144 HOLESAW,VARIABLE PITCH (1 1/4") 1 825-1-5/16 19145 HOLESAW,VARIABLE PITCH (1 5/16") 1 825-1-3/8 19146 HOLESAW,VARIABLE PITCH (1 3/8) 1 825-1-7/16 19147 HOLESAW,VARIABLE PITCH (1 7/16") 1 826S 12787 HOLESAW STOP-3 PAK (POP) 1 825-1-1/2 19148 HOLESAW,VARIABLE PITCH (1 1/2") 1 825-1-9/16 19149 HOLESAW,VARIABLE PITCH (1 9/16") 1 38522 38522 ARBOR, .312 HEX (PKGD) 1 825-1-5/8 19150 HOLESAW,VARIABLE PITCH (1 5/8") 1 2800 2800 ARBOR, QUICK CHANGE-5/16 1 825-1-11/16 19151 HOLESAW,VARIABLE PITCH (1 11/16" 1 2801 2801 ARBOR, QUICK CHANGE-7/16 1 825-1-3/4 19152 HOLESAW,VARIABLE PITCH (1 3/4) 1 37154 37154 ARBOR,3/8" SHANK W/3 FLATS (PKGD 1 825-1-13/16 19153 HOLESAW,VARIABLE PITCH (1 13/16" 1 37156 37156 ARBOR,HOLESAW 1/2 SHANK W/3 FLAT 1 825-1-7/8 19154 HOLESAW,VARIABLE PITCH (1 7/8") 1 38506 38506 ARBOR,HOLESAW 1/2" SHANK W/3 FLA 1 825-2 19155 HOLESAW,VARIABLE PITCH (2") 1 37155 37155 ARBOR,HOLESAW 7/16 HEX (PKGD,371 1 825-2-1/16 19157 HOLESAW,VARIABLE PITCH (2 1/16") 1 37157 37157 ARBOR,HOLESAW SMALL (PKGD, 37157 1 825-2-1/8 19158 HOLESAW,VARIABLE PITCH (2 1/8") 1 38507 38507 ARBOR,HOLESAW-SMALL 1 825-2-1/4 19159 HOLESAW,VARIABLE PITCH (2 1/4") 1 38524 38524 ARBOR-.312 HEX BLST PKGD 1 825-2-5/16 19160 HOLESAW,VARIABLE PITCH (2 5/16") 1 38505 38505 ARBOR-HOLESAW .437 HEX 1 825-2-3/8 19161 HOLESAW,VARIABLE PITCH (2 3/8") 1 38504 38504 ARBOR-HOLESAW 3/8" SHANK W/3 FLA 1 825-2-1/2 19162 HOLESAW,VARIABLE PITCH (2 1/2") 1 39873 39873 DRILL,PILOT (39873). 1 825-2-9/16 19163 HOLESAW,VARIABLE PITCH (2 9/16") 1 37623 37623 DRILL-PILOT (HOLESAW). 1 825-2-5/8 19164 HOLESAW,VARIABLE PITCH (2 5/8") 1 39893 39893 DRILL-PILOT .250X3.25LG. 1 825-2-3/4 19165 HOLESAW,VARIABLE PITCH (2 3/4") 1 38526 38526 DRILL-PILOT PKGD 1 825-2-7/8 19166 HOLESAW,VARIABLE PITCH (2 7/8") 1 825-3 19167 HOLESAW,VARIABLE PITCH (3"). 1 825-3-1/8 19168 HOLESAW,VARIABLE PITCH (3 1/8") 1 825-3-1/4 19169 HOLESAW,VARIABLE PITCH (3 1/4") 1 825-3-3/8 19170 HOLESAW,VARIABLE PITCH (3 3/8") 1 825-3-1/2 19171 HOLESAW,VARIABLE PITCH (3 1/2") 1 825-3-5/8 19172 HOLESAW,VARIABLE PITCH (3 5/8") 1 825-3-3/4 19174 HOLESAW,VARIABLE PITCH (3 3/4") 1 825-3-7/8 19175 HOLESAW,VARIABLE PITCH (3 7/8") 1 825-4 19176 HOLESAW,VARIABLE PITCH (4") 1 825-4-1/8 19177 HOLESAW,VARIABLE PITCH (4 1/8") 1 825-4-1/4 19178 HOLESAW,VARIABLE PITCH (4 1/4") 1 825-4-3/8 19179 HOLESAW,VARIBLE PITCH (4 3/8") 1 825-4-1/2 19180 HOLESAW,VARIABLE PITCH (4 1/2") 1 825-4-3/4 19181 HOLESAW,VARIABLE PITCH (4.75") 1 825-5 19182 HOLESAW,VARIABLE PITCH (5") 1 825-5-1/2 19183 HOLESAW,VARIABLE PITCH (5.5") 1 825-6 19184 HOLESAW,VARIABLE PITCH (6") 1 825-68 36169 HOLESAW,VARIABLE PITCH (68,0 MM) 1 825-74 36170 HOLESAW,VARIABLE PITCH (70,0 MM) 1 www.greenlee.com MA-5456 1/10 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2009 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc. Cat No. ACCESSORIES New clamshell packaging provides more merchandising visibility
825-7/8 价格&库存
很抱歉,暂时无法提供与“825-7/8”相匹配的价格&库存,您可以联系我们找货
    • 1+91.460651+11.88959
